Results 1 to 13 of 13
Thread: Toe in? How Much, if any?
    Sep 2016
    137
    Putting a new gear on and I’m am curious about the methodology ( if there is any) to initially set the shock struts.
    I have to have them custom welded from Airframes, so the ones pictured are adjustable.
    Logic is telling me I want more toe in, since there is going to be more squatting of the suspension when loaded.
ID:	38736Click image for larger version.
    Charlie Longley's Avatar
    Jan 2008
    Arlington, WA
    694
    You’re talking negative camber right? You can’t adjust toe in on a Cub easily. I would do a slight negative camber. If you do too much you’ll be rotating your tires pretty often.
    19,821
    From your previous post I think you are using 6" Atlee Dodge gear? Can Steve Kracke give you the dimensions or lower shock struts? Toe in will not be effected by the shock struts, it should be zero or a little in according to Piper drawings. I think you are wanting camber which I would say 90 degrees.
    19,821
    Most Cubs are neutral I believe.
    Thanks Charlie Longley, barrow pilot thanked for this post
    5,327
    If you camber is a little positive on the shop floor it’ll usually neutralize when you taxi. If you set it neutral when static it’ll be negative when rolling.
    Sep 2016
    137
    Definitely on the positive side right now as can be seen in the picture. Will adjust to neutral after work tonight.
    And Steve who is this Mr. Kracke, I would gladly reach out for any knowledge he might have.
    19,821
    Quote Originally Posted by Nodak33 View Post
    General Manager at Atlee Dodge.
    nanook's Avatar
    Aug 2002
    northern alaska
    1,692
    You might want to use greased plates under the tires, and put a load in it. 6” is tippy with positive camber.
    Jan 2008
    Arlington, WA
    694
    Oops I meant positive camber.
    7,169
    Just in case - I find that toe in can reliably be measured with a tape measure and two guys, if you have ribbed tires. Just go front to back on the tires. The measurements should be identical, but up to a half inch total difference front to back seems ok. At 3/4" I notice a little instability on roll out. I have only seen zero and positive toe in - never negative. Positive toe in will cause negative camber when you are pulling it into the hangar.
    Likes STaylor2 liked this post
    Sep 2016
    137
ID:	38779Click image for larger version.
ID:	38780Click image for larger version.
ID:	38781Click image for larger version.
    I appreciate the feedback from all of you. Sincerely.
    Made some calls to some 12 guys up north, they all said the same thing. Set at neutral. Can’t go wrong unless tire pressures are different. Sullivan got back to me finally and is sending the stc.
    Temporary Shock struts are measured out at 24” to get the neutral camber and I just have to set the nuts and ship back to Airframes for them to weld up the actual useable shock struts now.
    Still need to get new brake lines and I don’t know where to get the 6” ext certed safety cables either.
    19,821
    3,153
    On a cessna anyway, i like some positive camber.
    Handles well (assuming toe-in is correct), looks right,
    AND gets me more life out of the tires.
    Provided i take the tire off the wheel & turn it at annual time.
    Likes Nodak33 liked this post
