Results 1 to 31 of 31
Thread: How to jack up a Cub
    windy's Avatar
    Dec 2005
    Utah
    631
    How do you jack up a Cub to change the tire if you can’t lift it by the lifting eyes on top of the wing?
    Has anyone used one of these Tribal jacks? Would Cub gear splay out and fall off of a jack like this one?
    I’ve seen a jack that can lift underneath the wing at the tie-down ring, but have no idea where to obtain such a jack.
    Thank you for for any suggestions.
    windy
    4,563
    Atlee's makes a wing jack that fits onto a Handyman. My wing rings aren't suitable for jacking so Mike made a fitting to attach the jack to Atlee Hurricane Ties. Very useful.
    http://www.fadodge.com/wing-jack/
    Thanks windy thanked for this post
    10,347
    Quote Originally Posted by windy View Post
    windy
    Wing jack is most common way,can even be a 2x6 wit a tee at bottom.
    Dakota cub also makes a weld on jack point for rear gear tube on fuselage
    Jul 2007
    222
    Could we see some pictures of a wing jack in action.
    Thanks algonquin thanked for this post
    9,058
    shove a 2x under lift strut attach point on wing, put a notch in a 2x6 for stability. Works fine for on/off tires.
    windy's Avatar
    Dec 2005
    Utah
    631
    Thank you Stewart & Mike. Any photos available?
    10,347
ID:	38588Click image for larger version.
    6,740
    I never had any trouble using a 1965 Mustang jack under the inner part of the axle where the shock strut bolts. I am older now, and use those Harbor Freight hydraulic jacks. I have three of them, used about once a decade to get the gear down on an amphib that has stopped in under 100 feet.
    but for gear leg removal, I use a rather larger and more stable wing crotch, with safety rope around the engine mount area. Chock the opposite wheel and the tail wheel. Additional safety can be had with the Mustang jack in the crotch of the vee - light pressure; it is not a lifting point. And you can tie the other wing.
    Sep 2012
    85
    First of all...., there needs to be a better way to search this sorta' stuff on here! I posted about my jack system a while back and it took me :20 to find it again!
    Windy..., look in "Tips and Tricks" and search "Airplane support". I made these jacks in an afternoon and they work really well. I made a couple more sets for a Super cub and a Carbon Cub and they work great! I use 'em whenever the airplane is parked in my t-hangar so as not to damage a wing in case of a flat tire when I'm not there. Also, it makes the bedliner job a snap! Good luck!
    Likes windy liked this post
    3,338
    $30 Harbor freight floor jack, just inboard of the tire. I had to make a wooden platform to go under it to reach with bigger tires. Simple, cheap, works fine with 8.50's and 26 Bushwheels, but 31's might be a little too wide. Haven't tried it with them.
    TurboBeaver's Avatar
    Jun 2009
    Northern Maine
    673
    This is not an approved method, (So called "Jack Down" method) But watched a fella that needed to change from
    8:50s few weeks ago and he had no jack?? Drove his Jeep under wing strut. Hooked a racheting strap onto the hooks
    In front bumper and up on wing tie ring and simply jacked that wing down, till it almost touched the hood of Jeep.
    Bingo! Had enough clearance on opposite tire to get the 31" tire on. Seamed to work fine. Probably too simple.So works with any size tires except 35s!!!!
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,410
    I use two of these. One under each wing just outboard of lift strut. I fabricated a 1 x 4 x 4 pad with 1/4 inch rubber on top for each one on my 180. Lift the tail up to near level before you start.
    https://www.northerntool.com/shop/to...1746_200641746
    9,795
    I use this. 2 cheap sissor Jack's and a 2x4. A 4x4 or a square steel tube might be needed for a heavier plane then my Cub
    PerryB's Avatar
    Aug 2007
    Northern Calif.
    1,798
    Same here, except in my case it's a late model Ford truck jack, but a similar scissors type jack all the same. Works great. Just don't use a Dodge jack. Bad things could happen.
    9,795
    When you have wide tires or skis a regular jack won't work
    Apr 2015
    Platinum
    248
    Cherry picker/engine hoist...lift at the firewall engine mount bushing.
    Sent from my iPad using Tapatalk Pro
    Likes phdigger123 liked this post
    9,795
    Quote Originally Posted by Mark_Moyle View Post
    That's too much work just to switch tires. I can switch from BWs to skis in 15 min
    texmex's Avatar
    Aug 2008
    Hanging Rock, Australia.
    332
    Eddie, how is this best done?
    I miss just being able to lift the tail in the C180 like I could in the Cub.
    I know it's SuperCub.org, but how about another thread, 'How to jack up a C180'. Lot's of photo's please.
    I was looking for some photos on another thread, re lifting by the lifting hooks.
    Sorry, back to the topic.
    9,294
    texmex, It's time to invest in a ceiling hoist for your hangar.
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,410
    I use an engine hoist with a strap.
    I have since extended the legs of the jacks. No more 2X6s.
    Quote Originally Posted by texmex View Post
    9,795
    I thought you bought a flying airplane?
    55-PA18A's Avatar
    Dillingham, Alaska
    587
    I've always just used a hydraulic bottle jack on the inside stub of the axle. Might need a couple pieces of 2x6 for blocking. Landes 2500s and 29-11-10 tires. Block the other tire (and parking brake) and tail wheel.
    Jim
    Jun 2009
    Northern Maine
    673
    Wow Eddie that music would give me the hebee geebees!
    4,563
    http://www.supercub.org/forum/showth...0-185-Jack-Pad
    2,627
    …….I miss just being able to lift the tail in the C180 like I could in the Cub. …..
    I keep a long (8 foot or so) 4x4 in the back of the hangar.
    With a guy on each end, put the center under the forward end of the tailwheel head.
    Raise it up, and roll a handy shop table under the tailwheel.
    A good quick way to add some height to the table is with an upside-down milk crate with a piece of stout plywood on top.
    Less teeter than the usual collection of 4x4 blocks etc used as cribbing.
    I've tried various jack points for raising the mains, both store-bought and home-made.
    Using both bottle jacks and floor jacks.
    What I use now is a nylon strap choker around the gear leg, down low, hooked to an engine hoist.
    Quick and easy, seems more secure than when I used jacks,
    and doesn't chew up the paint on the gear legs like my jack points usually do.
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,410
    Jeff Healey
    Different strokes!
    Sep 2012
    85
    All those rigs are too sketchy for me! This is what I came up with...., I can lift the airplane as much as I want with ease and it's as stable as a rock!Click image for larger version.
ID:	38656Click image for larger version.
ID:	38657Click image for larger version.
    JDWilliams's Avatar
    Aug 2018
    17
ID:	40789Click image for larger version.
    Likes av8rtom liked this post
    Sep 2012
    85
    So how slick is that?!
    JDWilliams's Avatar
    Aug 2018
    17
    Works great! Thanks of the idea!!
    Chicken Hawk's Avatar
    Feb 2015
    Southern NH & Eastern Maine
    239
    Quote Originally Posted by av8rtom View Post
    I think jack will get in the way of putting skis on.
    Likes mike mcs repair, cubdriver2 liked this post
  1. Jack Screw
    By OLDCROWE in forum Super Cub Sick Bay
    Last Post: 05-01-2009, 07:29 PM
  2. Jack Wilson
    By 55-PA18A in forum Cafe Supercub
    Last Post: 01-20-2004, 11:28 PM
