Results 1 to 35 of 35
Thread: No electrical system, which road to take with a radio install?
    Nov 2015
    6
    We are finishing up the complete restoration of our 1952 L-18C and and I am looking for ideas on the best radio/intercom to install. It has no electrical so we are considering a wind generator to keep the battery charged. My mechanic recommended the Flightline FL760 and said he could install it in the wing root. Anybody else without electrical systems have any ideas or any pictures of their set up? Is a wind generator worth it? Thanks for the info.
    9,170
    I saw a really nice install in a J-3 at Twin Oaks in Hillsboro Oregon. Give the airport a call and see if they would send you a picture of Bob's.
    I don't know how much time you plan to fly each day, but consider a solar panel for charging instead of the wind generator. While the wind gens are neat, it would be much more simple to put a solar panel in with zip ties. If you are flying lots you can put a charger on at night also.
    Simple is probably better!
    Likes mike mcs repair, gravytime, Jonnyo liked this post
    Nov 2003
    Thun Field, Washington
    785
    Simple is better. I run a handheld Terra "Blue Brick" radio, a Garmin GPS and an intercom with an Earth X 16AH battery mounted under the seat.
    It gets plugged into a maintainer once a month, maybe. The solar charger would probably work, too. Depends on how talkative you get.
    Likes FdxLou, mike mcs repair, gravytime, Jonnyo liked this post
    nd
    3,406
    yep, consider no charger at all, maybe a aa battery pack backup just in case, and a small motorcyle type battery, it will go a long time. maybe bob t will tell about his setup.
    Thanks chewy thanked for this post
    Cub Special Ed's Avatar
    Oct 2016
    MT/SD
    457
    I have an icomm radio, intercomm system, and a b&c sd8 alternator (which only weighs about 1.5#) on my pa11.
    "There are 3 kinds of men. The one that learns by reading. The few who learn by observation. The rest of them have to pee on the electric fence for themselves." Will Rogers
    Nov 2003
    785
    But then, in the big city, you have an engine driven charging system and have to comply with all the big boy rules.
    JP's Avatar
    Mar 2003
    The Big Woods of Maine
    3,204
    Quote Originally Posted by Carey Gray View Post
    I have an A5, an intercom and a Garmin 510 all source to a compact rechargeable 12 volt cell in the baggage compartment. The set up works really well and one can go for 2 to 3 days without recharging.
    Sent from my SM-G930R4 using SuperCub.Org mobile app
    JP Russell--The Cub Therapist
    1947 PA-11 Cub Special
    www.bloomerrussellbeaupain.com
    nd
    3,406
    my next com radio. is going to be a garmin gtr-200
    6,912
    I have installed three GTR-200 radios - two Cubs and a Stearman. I am pleased.
    The Garmin takes a lot more juice than does my SL-40. We got seven tach hours at first on a 7 AH battery. But then either all my batteries got weak at the same time, or the radio got more demanding, and we started getting only one tach hour per charge. My SL-40 goes for five hours on the same battery.
    Right now we are running two 7 AH batteries in series for 24 volts and getting 12 tach hours of continuous pattern work between charges. I consider that ok.
    It has one other flaw - not enough RF squelch. Other than those two things, the GTR-200 is the very best aircraft radio I have ever used. And installation is almost trivial - you do need a professional grade crimper and some knowledge of shielding.
    Oh - best thing? With David Clark 10-13.4 headsets and Oregon Aero muffs (outer hole taped over) the internal intercom cannot be beat! Even at full power in the Stearman. No need for the leather muffs in the open J-3. Just perfect!
    Wanna picture?
    Thanks Brandsman thanked for this post
    10,683
    Whatever you wind up with, you’ll need an external antenna. I used a 121.5 MHz ELT antenna taken off an airplane. With the Icom A-5 it worked great with a Lo ion battery, no charger. Antenna mounted on left wing root fairing.
    6,912
    I agree with MTV
    But I discovered an exception. One of my students has a Chief with the newer Icom portable. The antenna got taped to the windshield - a desperate attempt by me to have at least some communications during a transcontinental flight. Somehow it worked! This kid is flying in the LA basin with it, in and out of SMO, and getting really good service from SoCal. No transponder! Brand new Sport license.
    I am still amazed. Must be a fluke. No ground plane at all. Lots of parasitics. Do what Mike says, and don't depend on luck.
    Likes FrankO liked this post
    1,865
    If the antenna is separated from the radio but remains connected with coax cable, the coax and radio case can be volunteered to be the other half off the antenna. They act like a typical ground plane might, but sometimes are not as good. Radio frequency current can find a way to flow on the outside of the coax unless suppressed. The length of the combined coax and radio can be critical for best performance at the frequencies we use in aircraft. And if the portable radio is attached via conductive mounts to the aircraft metal then that can add to the antenna setup, just as we do when holding the radio in our hands.
    So yes it works...RF often finds a way to get transmitted. There are signal strength meters that at a distance can measure differences in setups but few would bother to fine tune an installation. They'd rather spend time and money on other things for their aircraft.
    Likes Jonnyo liked this post
    9,656
    I agree with MTV
    Bob, What is below the antenna? How about the wraparound cowl and top of the instrument glare-shield? That is your ground plane.
    6,912
    Typically one would want a ground plane at the feed end of the antenna, not a foot away. The original owner had the rubber ducky taped horizontally to his front spar cover. He said it worked 60 miles out. I chose not to believe that and selected vertical polarization and not taped to a piece of aluminum. I taped it to the upper center of the windshield, fed with coax from the top.
    I did not expect it to work. El Paso was prepared to let me through nordo.
    1,865
    For example if the antenna is taped vertically to the windshield then nearby is usually some airframe metal - windshield frame or structural tubing. Remove the coax feed line's coax cover from a portion and put a metal clamp over the exposed shield and bolt it (metal to metal contact) to any existing fasteners. A hose clamp would also work. Now there's a counterpoise of sorts for the antenna to work against. If it hears ok it should transmit ok, but an SWR meter at the radio would know more about the system.
    2,683
    Quote Originally Posted by gravytime View Post
    Depends on what route you want to take.
    Panel mounted equipment will give you better performance. Radios like a Becker or a Microair (not a big fan of the FL760) will give good power out, easy volume and squelch control, and extras like monitoring a second frequency. They also mount in a small instrument hole, without a mounting tray. If you use an intercom such as the PM501/PM500EX, you'll get good power to the headsets, separate intercom volume control and intercom squelch control with an external knob. These small units use a quarter amp or less at rest and two to three amps while transmitting. So if you go with just a battery for power, recharge it after flying or swap it out with a fresh battery.
    If you go totally portable, you don't need to mount anything. Through the radio in your shirt pocket, or velcro the radio and intercom in handy spots. Run Duracell batteries and keep spares on board. The downside is usually less range on transmission, prone to be noisey, and lower power to the headsets.
    Either way you go, make sure to use an external, properly mounted antenna.
    Likes gravytime liked this post
    Nov 2015
    6
    Thanks for the info. I’ll take a look at Becker and Microair and probably skip the wind generator. Already planning an external antenna. Any recommendations for the best battery to power it?
    2,683
    Calculate the size according to the load you'll put on it. Look at AGM style batteries. Stands for absorbent glass mat. Very compact and hold a charge well.
    don
    723
    Don 't recommend Flightline. Mine worked great for 11 months. Then it smoked. No real service or warranty. Out the $800.
    6,912
    As to a specific battery - we have been using the Yuasa 7 ah cells. I think they are AGM. I had a failure yesterday, but it was 5 years old. The one driving my SL-40 has six tach hours on it, continuous pattern work. I keep two fully charged spares on the workbench, and one in the Cub.
    But - we are using the PC-545 for the J-3 starters. They give between 50 and 75 starts per charge - I guess depending on how carefully I charge them. I am going to bite the bullet and get an Odyssey charger, just to make sure.
    And I am giving consideration to using the 545 as the radio source, or maybe as a backup. All it will take is a fuse, a DPDT switch, and me getting off the couch. We have been using the Odysseys for two years, almost, with zero problems.
    Farmboy's Avatar
    Jan 2016
    Glens Falls, NY
    2,186
    I installed a GTR-200 as Bob did and loved it as well. I do believe it likes power though and if you’re the talkative sort (flying with friends) it will start transmitting “with reduced power” as the battery voltage drops.
    I’m a believer in a wind generator, but on the experimental side.
    9,972
    Still using my 25 YO Icom 21 in my J4
    10,683
    I wouldn’t necessarily eliminate the wind generator. Consider your mission. If you’ll spend many nights away from home, the wind generator could eliminate some angst re: battery life. If you’re likely to spend most nights at home where you can plug in to a battery maintainer, maybe not on the generator.
    I think if if I were to do it again, I’d install a wind generator.
    9,656
    Here is a homemade wind generator which puts out 15+ amps. Total installed weight 5 lbs. Works like a charm.
    Likes Farmboy, cubdriver2 liked this post
    9,170
    But you never turn it on!
    Pete, nice set up. What type of an alternator or generator did you find for that?
    I still like Solar panels for just infrequent or small radio use- less moving parts and easy to replace at any auto store.
    Great ideas all!
    9,656
    It's a dynamo and regulator from a Kubota tractor with a homemade propeller made from three layers of 3/4" plywood.
    Farmboy's Avatar
    Jan 2016
    Glens Falls, NY
    2,186
    George, complete thread about the Kubota Dynamo and my prop selection under the ambiguous title Solar Chargers -
    http://www.supercub.org/forum/showth...Solar-Chargers
    6,912
    I have flown several Cubs with wind generators. Giant pain for pattern work - we had to charge the big Odyssey before every flight. In contrast, my SL-40 just passed seven tach hours sucking on a 7 ah motorcycle battery. The big problem is the speed at which the generator begins putting out enough voltage, and the giant sucking sound at the master solenoid.
    9,656
    Bob, Must be the type of wind generator you are using. Mine will put out juice by only running up the engine.
    Likes Farmboy liked this post
    Farmboy's Avatar
    Jan 2016
    Glens Falls, NY
    2,186
    And likewise with my version of the same unit, output was alive about rotation. Once I installed it I never charged or removed the battery again. And I ran a small battery.
    This unit is _not_ the 1940's vintage generators with 2 amps output at 80 mph. Those collector items only belong in a bin or wall mounted for art.
    Charlie Aileron's Avatar
    Aug 2002
    4GA4 Chatsworth, Georgia
    333
    Becker radio and PS engineering intercom installed in right wing root panel. Wind driven alternator mounted on cabane, battery under front seat.Click image for larger version.
Name:	Com, intercom.JPG
ID:	38700Click image for larger version.
Name:	Wind driven alternator.JPG
    Charles Aaron
    Thanks stknrddr, gravytime thanked for this post
    Likes cubscout, gravytime, hotrod180 liked this post
    Nov 2015
    6
    Quote Originally Posted by Charlie Aileron View Post
    Nice set up Charlie. What battery are you running?
    10,683
    Many years ago, I installed a motorcycle battery in a J-3 and a small solar panel inside the skylight. Ran a King 97 just fine. Plane parked outdoors, though.
    2,683
    It's a math problem. It all depends on the load on the battery (time the radio is 'on') vs time that the panel is exposed to sunlight. Both vary greatly. Occasionally an aircraft may be flown several hours each day with the radio in use at all times. Others times the aircraft may be parked for days or weeks with the radio shut down. As for the solar panel, you may live in the desert where you get about 20 minutes of cloud cover each year, so your panel will be producing almost continuously. But if you live in the midwest, in the fall or winter your daylight is very limited. Or up here it can be non existent.
    You'll have to calculate if a solar panel will work for you and for your operation in your present conditions.
    1,865
    A portable or easily removed battery can be charged some while driving to and from the airport. Vehicles usually have 12v power ports (cigar lighters for the aged) that can be used with the right adapter and a couple of alligator clips. Good for a day or two of use if the amp demand is low.
  1. Electrical system on -95
    By nesincg in forum Cafe Supercub
    Last Post: 09-17-2010, 07:18 AM
  2. Electrical system
    By butch in forum Cafe Supercub
    Last Post: 01-31-2005, 10:36 PM
