Results 1 to 12 of 12
Thread: Torquing prop bolts
    May 2014
    607
    Torquing prop bolts
    What’s the consensus on getting accurate torque reading on prop bolts?
    I've been told that lube will give a false (over torque) reading.
    My experience with dry (no lube), the bolts start “creaking” when getting tight making it difficult to get an accurate reading.
    Some recommend parafin wax (?)
    whats the correct procedure?
    Thanks for your input,
    Doug.
    10,584
    Read the instructions. No oil most likely
    2,625
    What Mike said. Standard hardware torques are usually dry. If lube is required, installation instructions will say so and indicate the correct lube to use.
    PerryB's Avatar
    Aug 2007
    Northern Calif.
    1,849
    I like to clean the lugs with a brass rifle bore brush using a low speed drill, and a brass toothbrush on the bolt threads. This gets them shiny clean without any thread wear, and I've never had any creaking or sticking. They draw down quite smooth when dry this way.
    Thanks Oliver thanked for this post
    May 2014
    607
    Catto mentions parafin wax, but also uses Belleville washers for install.
    McCauley, to my knowledge, makes no mention of thread treatment prior to prop install.
    My small block Chevy build manual suggests lube with “light oil” on torqued bolts.
    Is there no standard recommendation that would allow us all to arrive at a common value when torquing a bolt? Especially a prop bolt?
    PerryB's Avatar
    Aug 2007
    Northern Calif.
    1,849
    Quote Originally Posted by Oliver View Post
    I think the parafin wax is for the lugs so they slip into the the counter-bores easier, and if they're using Belleville's that's something new since I got mine. When I bought my Catto they didn't even provide bolts or a crush plate. Those had to be sourced from Saber mfg. Of course none of this was disclosed until AFTER I had my prop. They build a wonderful prop, but I've never been impressed with how the front end of that place is run. -- Sorry, venting....
    2,625
    Or . . . you could read the instructions from the manufacturer.
    McCauley for instance, has different requirements for different installations. Some installations use dry torque, some use oil on the threads, and some require grease. Just do a search for service bulletin SB227B. It calls for 'light oil' for some and Mil-T-83483 grease for others. Also a big warning to never use dry torques when a lube is called out OR lubed torques when dry is called out.
    There is no one way to torque all prop bolts.
    Thanks Oliver, Cub Builder, Charlie Longley thanked for this post
    18,983
    Never see the belville washers on the Catto. I always start the prop bolts by hand, snug with a speed handle and then torque and had no issues.
    Thanks tedwaltman1 thanked for this post
    Likes chewy, Chicken Hawk liked this post
    May 2014
    607
    Spent a little time in the hangar today fooling around with a torque wrench and prop bolts.
    As per sb227b (thanks Web) clean and dry threads on Lycoming.
    With a very accurate and calibrated (Snap On) digital torque wrench, discovered that friction between dry washers, bolt head and spinner mounting plate can produce significant friction and false readings
    lubticating washer surfaces eliminates bolt “creaking” also minimizes galling and crushing alum spinner mount.
    That is my consensus on getting accurate prop bolt torque and my 2c for what it’s worth.
    18,983
    Were you using the Piper washers or AN washers? Interesting to know that the noise is from the washers.
    2,789
    …..McCauley for instance, has different requirements for different installations. Some installations use dry torque, some use oil on the threads, and some require grease. Just do a search for service bulletin SB227B. It calls for 'light oil' for some and Mil-T-83483 grease for others.....
    Both my Cessna 100 series service manual and my McCauley C200/400 series operators manual call out for "clean and dry threads",
    as does the paperwork that came along with the STC to install this prop.
    But when I got my C201 back from overhaul, the prop shop supplied me a little tube of milspec grease and explicit instruction for lubing the nuts & studs before torquing.
    I still have some of the grease left, but unfortunately now I can't find those darn instructions.
    EDIT: Thanks for posting the link to that SB , Web.
    Think I'll print it out and put it with my prop STC info.
    It indicates that torque instructions are on a sticker on the prop itself, which I kinda recall now.
    May 2014
    607
    Using hardware provided from Dominion with Borer prop.
    bolts, AN970 and AN960 washers with bolts.
    Catto provides 24 belville washers and 6 AN960’s with their crush plate hardware kit.
    maybe a recent thing,
    torquing with belville washers (4 per bolt) is where I had the biggest issue with erratic readings from creaking bolts, assumed it was threads in the bolts/prop hub but not the case.
  1. O-320 vs O-360 prop bolts
    By Blackdog in forum Modifications
    Last Post: 09-25-2016, 12:23 AM
  2. Need prop bolts
    By Tango Cub in forum Cafe Supercub
    Last Post: 04-30-2011, 10:55 AM
  3. Prop bolts???
    Last Post: 10-02-2005, 05:00 PM
  4. Prop Bolts
    By arcticace in forum Super Cub Sick Bay
    Last Post: 05-09-2003, 10:04 AM
