Results 1 to 9 of 9
Thread: Sky-Tec starter solenoid
    Bearhawk Builder's Avatar
    Aug 2012
    In the woods
    806
    Just thought I would post this here regarding the Sky-Tec fly weight starters and what I have found (from an internet search) to be a fairly common problem with the solenoid going bad. My starter in the Bearhawk has been acting up for a while now and I thought it might just need lubing with silicone. Lubing the shaft seemed to cure the problem for a short time but it always returned to the original problem of just clinking at the push of the start button every third try or so. After some research I found the solenoid is a Ford part number for a 2005 Crown Victoria. Napa part number ST421 at $22.75. You'll see in the pictures the solenoid is an exact match. Changed it out and life is good! Experimental only of course but I hope it helps someone out.
ID:	38474Click image for larger version.
ID:	38475Click image for larger version.
    Thanks n40ff thanked for this post
    20,754
    What model Sky-Tec starter is this for?
    Aug 2012
    In the woods
    806
    149-12pm
    20,754
    Have had good luck with those on 150 hp O-320s but O-360 eat them up. Using the NL on them with good results.
    Dec 2016
    Canyon, tx
    783
    122-NL??? I have a similar problem. Deleting the starter is what the cool kids would do. I’m not that cool....yet
    20,754
    Might as well get rid of the alternator too but you got all that stuff in the panel.
    Likes RaisedByWolves, mike mcs repair liked this post
    Dec 2016
    Canyon, tx
    783
    No kidding. If Henry Ford would have designed the space shuttle, it’s panel would have looked like mine
    20,754
    Nope, he wouldn't have wasted all that aluminum.
    Likes KevinJ liked this post
    PerryB's Avatar
    Aug 2007
    Chico, CA
    2,030
    Quote Originally Posted by Bearhawk Builder View Post
    Thats good to know, thanks. I have one on the shelf that's inop due to a faulty solenoid. Of course I would never consider putting this affordable, practical solution on my certified a/c.....
    Likes 180Marty, Bearhawk Builder, n40ff liked this post
  1. Mounting Starter Solenoid Upside Down
    By Darrel Starr in forum Cafe Supercub
    Last Post: 08-07-2014, 09:36 PM
  2. Starter solenoid keeps poping
    By N197BC in forum Member to Member
    Last Post: 11-22-2013, 07:36 PM
  3. Where to mount master and starter solenoid
    By bobnall in forum Tales of the PA18
    Last Post: 11-05-2005, 09:21 PM
