Page 1 of 4 123 ... LastLast
Results 1 to 40 of 150
Thread: Leaking port fuel tank on landing and left rudder slip
    Jun 2018
    England
    488
    Since day one, (4 months ago) my PA12 has had a fuel leak from the port tank, when landing, when the tank is relatively full (90%+).
    The fuel filler cap has a homemade cork seal, which I've never liked and want to replace with a rubber one and I've kind of suspected the leak is coming from the tank filler, so I've fed from the port tank mainly and landed with it <75% full, which has meant no leaks........
    On a test flight today, to re-test the fixed:
    Charging system
    ASI
    CHT
    Trim
    in addition to the main test item-the new diaphragm in the starboard brake master cylinder (all tests went pretty much perfectly!!) I practiced some slips, left aileron/right rudder went perfectly, as did right aileron/left rudder UNTIL I noticed the stream of blue fluid (fuel) hitting the port perspexes!!!! Clearly fuel leaking from the port tank!!!! The tank was about 60%+ full, but it looked like someone was throwing buckets of fuel at the port windows!!!
    Has anyone had a similar experience and was it the tank filler, or something more sinister?!!!
    Also, another question please-the fuel selector is VERY stiff to turn, any tips for freeing it up please??
    Thanks!!!
    Philly
    11,297
    Quote Originally Posted by Philly5G View Post
    Charging system
    ASI
    CHT
    Trim
    Thanks!!!
    Philly
    Fuel selector need to be taken apart and cleaned. Best to just buy the new style one from Dakota cub, it comes with stc to give you both position.
    Open tank lid and look before you burn up.
    Get a GOOD annual inspection done.
    7,171
    What Mike says. We recently had a Dakota Cub tank leak. Some reasonably experienced folks were sure it was the quick drain or the rubber hoses. It turned out to be a welded seam on the back edge. Tank removal/replacement was fairly easy, but I farmed out the actual removal and installation to a couple of very young and agile A&Ps. I did the easy stuff, like opening, finding the leak, closing, test flight.
    Owner's wife is much happier - no gas smell in the cockpit. Yow!
    Likes mike mcs repair, Philly5G liked this post
    texmex's Avatar
    Aug 2008
    Hanging Rock, Australia.
    354
    Re very stiff fuel selector, there is a Piper Service Instruction (or bulletin or letter or whatever) on it.
    But what Mike says. Last year when I sold our Cub, I put a new Dakota fuel selector in. What a beautiful bit of gear. I walked away thinking why didn't I do that 17 years earlier.
    3,612
    +2 Find the leak before further flight!
    10,992
    Charging system
    ASI
    CHT
    Trim
    Thanks!!!
    Philly
    Are the tanks original terne plate? If so, Iíd suspect a crack in the tank. Those tanks can be very hard to repair, or at least hard to keep repaired.
    Jun 2018
    England
    488
    Thank you for that Mike!! GREAT advice and I'm on my way to the the airfield a bit later to open the lid and take a good look at the tank!!!!
    I love the look of the Dakota fuel selector.
    On the annual inspection, I bought this aircraft with about 6 months remaining on the (signed off) mandatory annual inspection and it had flown a handful of hours since that inspection. I knew it was a TLC fixer upper and needed a new radio and some work on the tailwheel steering locking, but the list of faults I've found and am working through is, shall we politely say, "rather a surprise" on a supposedly signed off aircraft.
    Cheers
    Philly
    55-PA18A's Avatar
    Dillingham, Alaska
    639
    Philly,
    Please let us know what you find about the leak. All too often requests for advice are responded to, but we don't get feedback on the results. It helps all of us.
    Jim
    7,171
    Um - an IA would be wise to fill all fuel tanks and check for leaks, but it isn't done often. The aircraft I mentioned above - I signed the annual, then the owner filled the tanks for a trip, and I happened to see rivulets of blue dye on the fuselage. Trip canceled.
    Do your mechanic a favor - if you know of a problem, mention it.
    Thanks Philly5G, STaylor2 thanked for this post
    Jun 2018
    England
    488
    I work very closely with the Chief Engineer at the airfield where I'm based and discuss 100% of the issues with him and work the fixes under his supervision as required. To be honest, I wouldn't dream of buying such an aircraft without the expert help and support I have, both from a wanting to understand how the aircraft works IN DETAIL and keeping the costs under control angles. I did my Pitts S-1S and Andreasson BA4B in the same way and the questions I now need to ask are just on new issues and techniques, as I've already learned a LOT about aircraft from the other 2 projects and also my time in the Air Force as a Flight Systems Technician. I dread to think of the cost of doing the (extensive) work I've/we've done so far if I'd just taken it to an aircraft shop..........
    Thanks STaylor2 thanked for this post
    Jun 2018
    England
    488
    Quote Originally Posted by 55-PA18A View Post
    Philly,
    Jim
    THANK YOU Jim and everyone else who's commented on this post (and my other ones), it is BRILLIANT to be amongst so many good and happy to help people and I've literally just upgraded my subscription to paid "Friend", which hopefully is a tangible expression of my thanks and eagerness to belong and contribute I particularly appreciate the comments and concerns above on fixing before next flying
    On progress, I got the tank cover open yesterday, 75% of the screws were easy, but the rest were badly rusted and "graunched" and had to be Dremelled and then persuaded out Immediately it was obvious that there was a LOT of filler/tank fixing gloop at the aft/top right corner of the port tank, which of course is where the leak would be if it manifested on landing (high AOA) and right stick/left rudder slips as it does. Next step is to get the tank drained and out and off to the tank experts for either repair or replace. I couldn't see where the 2 tank straps ends meet and can be unfastened? Is it under the 2 inspection panels at the front and under the leading edges, or somewhere else? Or is there another way to release the tank from the straps? - I was also refitting the gascolator yesterday and ran out of time to check.
    Thanks sjohnson thanked for this post
    cubpilot2's Avatar
    May 2003
    Anchorage Alaska
    778
    Options for replacement of your tank discussed here if it comes to that.
    http://www.supercub.org/forum/showth...l-Tank-options
    Ed
    10,992
    Again, IF your tanks are the originals, they are soldered terne plate. Those tanks are okay once settled in, but difficult to repair. Years ago, I owned a 12 with these tanks, and one started to leak. Had a mechanic repair it and very carefully re installed it. Shortly it started to leak again. The mechanic had warned me and he was right. Replaced the tank with a Super Cub tank and never looked back. The next owner replaced the other tank not long after he bought it.
    So, if your tanks are originals, you may want to consider replacement vice repairs.
    FWIW.
    Thanks Philly5G, Eferr thanked for this post
    Jun 2018
    England
    488
    FWIW.
    thanks for this! and how do I tell if they’re original?!!
    Philly
    11,297
    Yes tank straps unbolt in front
    If you need replacement consider Dakota cub 24 gallon tanks. Some work to install. http://dakotacub.com/
    Or atlee 30 gallon tanks http://www.fadodge.com/
    11,297
    Originals are steel. Use a magnet
    TurboBeaver's Avatar
    Jun 2009
    Northern Maine
    799
    Consirning Terne Plate tanks in actual fact sorta like changing bungees.......... Lots of misconception about both of these on PA12,s .
    #1 rule on tanks if they have never been repaired over the
    Years they WILL leak. However IF you understand how to fix them they are actually quite easily repaired. The problem is when a leak is found modern day mechanics
    want to simply replace them........ Because they are often
    not firmilar with the correct way to fix them. They will 99%
    of the time try to fix JUST the spot thats leaking. It almost
    never works........... The tank needs to come out onto the bench and ALL the seams need to be resoldered with an old fashioned LARGE iron heated up with a torch. Reflux and release all the seam and reseal the tank is less than one hours work total time. Its common to get 10 years out
    Of one that is redone correctly........ Or spend $1500 for cub tank installed. We used to solder in two stubs of copper tubing
    In the end plate and install 18 sight gauges that are huge
    Safer set up. 100,s done and field approved. But doubt if
    You could ever get em approved today? So its like saying its simpler to install $3000 18 landing gear than change your bungees...........omg.
    Thanks flylowslow thanked for this post
    Jun 2018
    England
    488
    Thanks everyone, looks like itís time to get the tank out!!
    Iíve been searching for the PA-12 maintenance manual, but no luck so far. Iíve bought the Univair parts list and downloaded a PA-18 instructional build doc, both of which have been some help.
    My plan was/is to remove the left tank and while itís being repaired/replaced just use the right tank BUT on taking off the wing root panel to be able to open the tank flap, I saw there were two pipes. From the univair parts list drawing, the rear one looks to be the feed and the front one some kind of combination of vent and MAYBE some kind of tanks contents levelling connection?? Is this the case? (Sorry for the real newbie question!!) and if it IS the case, Iím assuming Iíll need to blank it off if flying with just one tank?
    If it IS a fuel levelling connection, this seems to imply that the Left/Right positions on the fuel selector are simply choosing which feed circuit is in use and NOT using that tank and keeping the other tank ďfullĒ??
    #IsAnythingEasy!!!
    Every day's a school day
    10,992
    There should be a forward and an aft fuel pickup. The vents are in the caps.
    I would not even consider flying one of these airplanes with one tank removed, especially not the left tank, which is generally uses for takeoff and landing. In any case, the FAA would never consider the airplane to be airworthy with one tank removed. Maybe under a ferry permit, but......
    Jun 2018
    England
    488
    Ok, 100% clear on no Flying with one tank!!! But is IS there some kind of cross feed? Which means the remaining tank will Flow its fuel across and onto the hangar floor when the left tankís removed?!!
    7,171
    I think Cub cross-feed only occurs with a "both" position on the fuel selector.
    When you pull the tank, be aware that if the diagonal wing brace tube bolts are tough to get to, you can probably un do the one at the butt rib, then rotate and slide the tank off the tube. The posters above alerted me to that fact in another thread, and it made what looked impossible at least doable.
    Also, after re-installing, getting those straps back together appears to be a two-man job.
    Jun 2009
    Northern Maine
    799
    In the original tanks there will only be Aft feed points. (Ditto for Wag Aero replacement ones as well)If yours has original tanks, the only fittings in the forward part of the tank is from the top, and that is for the balance tube. There will be a header tank by your left foot.
    If you desire a 18 style selector: instead of the factory double " On/Off" selectors. Then at that point you can ditch the header tank, But you will need to modify your tanks, with forward bottom of the tank feed points. If your "well placed"; just grab some 24gal Dakota tanks and their 4 way valve, at bout $5,000 plus installation??? Or on a more "streamlined budget". Solder up your seams, and live with the header tank.........
    3,612
    The stock PA-12 wings/tanks do not use that diagonal tube. There are drag and anti-drag brace wires under the tank saddle.
    2,063
    Bob
    The Right, Left, and Both will usually cross feed on both and off.
    Jun 2018
    England
    488
    Interesting as these tanks definitely have fuel type hoses front and rear and theyíre also drawn in the Univair parts catalogue. Thereís a cylinder, running horizontally the width of the fuselage to the rear of the firewall and below the instruments, which Iím guessing might be a header tank? But I canít get to the hangarvthis week to check the connections and confirm.
    I do have some pics and Iíll try to post them later
    Jun 2018
    England
    488
ID:	38493Click image for larger version.
ID:	38494Click image for larger version.
ID:	38495Click image for larger version.
ID:	38496Click image for larger version.
    As you can also see, this is the kind of dirt Iíve found behind each panel Iíve taken off, easy to wash off and no apparent corrosion, just not a nice sight
    Jun 2018
    England
    488
    Didnít take a before shot, but this is the after, after replacing the fuel selector to gascolator pipe and gascolator and cleaning off the same type of crud as in the tank picsClick image for larger version.
    Jun 2018
    England
    488
    Bob
    Thanks Denny, does this mean I need to drain BOTH tanks before removing either?
    2,063
    It depends on the type of selector you have and if someone modified it in the past. If you have a left/right/off/off you should be able to isolate right or left tank at the valve, but the balance tube is another issue. You said the selector was stiff so I would drain both tanks and pull lube/replace the fuel selector while the tank is getting fixed. I had mine pulled and lubed and it is smooth as silk. I prefer a prefer a left/right/off/off valve (no both) myself. Lots of modified PA12/18 fuel systems out and about so my advice may not work on yours.
    Jun 2018
    England
    488
    Thanks Denny, I'm starting to wonder about this fuel system. The aeroplane was used for aerial photography in Portugal, so extra big tanks would make sense, does anyone recognise the tank from the part of it visible in the pic? It has "corrugations" inset and running from left to right, maybe 4" apart?
    I'm also wondering whether the "header tank" under the panel really is a header, as looking at the fuel pipes going to the selector, they seem to come direct from the wings, although I haven't traced the front pipes through yet..........
    2,063
    That dip in the fuel line before it enters the valve looks like a great place for water to collect. Might want to address that while you are working on it.
    Jun 2009
    Northern Maine
    799
    That one picture looks like someone has already tryed J B Weld or similar on the back of that tank! That mess should
    Be all cleaned up if your going to resolder your tanks.???
    Again that was a try at a quick fix without pulling the tank?
    Sure hope this whole airplane isnt the same as the fuel system? My header tank is mounted vertically. And I am not certain some of the other ser number 12,s ever had them mounted horizontally or not. Previous 12 I owned had a 4 way Cub Selector with forward added pickup outlets with no header tank. The one I have now is completely original with left tank original, right tank is
    WagAero.
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,632
    JB Weld and Duct Tape. Fixes anything!
    Jun 2018
    England
    488
    WagAero.
    Yes, the definite plan is to get the tank out and properly repair/replace, Iím hoping thereís an easy way to cap off the cross pipe, so no need to drain the other tank too?
    Fortunately the rest of the aircraft is NOT like that tank, although there is dirt under the upper panels which Iím removing as I go. In fact itís pretty good in general and the bits that need attention are getting it, or have already had it over the last few months
    Jun 2018
    England
    488
    As we say in England - ďIf duct tape doesnít fix it, use more duct tapeĒ!!!! But on this occasion Iím resisting the duct tape urge and getting the tank gurus involved
    Jun 2018
    England
    488
    WagAero.
    Does this tank look like an original one TurboBeaver? Or is it difficult to tell visually? Cheers
    3,275
    Your antenna is in the skylight?!
    Sorry. Just the detail that caught my eye.
    11,297
    Original pa-12 mount location... before skylight
    Jun 2018
    England
    488
    Ha!! Thatís the way it looks, but itís actually mounted on a plate below the skylight. Pic from my only back seater trip in this aircraft Click image for larger version.
    Jun 2018
    England
    488
    Hey Mike, is there a diag or pic attached to this message? I canít see it if yes? Thanks P
  1. Fuel Cap Leaking - PA-11 wing tank
    By DavePA11 in forum Cafe Supercub
    Last Post: 08-28-2018, 09:19 PM
  2. Left Fuel Tank needed for PA-18
    By Steve's Aircraft (Brian) in forum Super Cub Sick Bay
    Last Post: 09-08-2015, 04:38 PM
  3. Exhaust Slip Joint Leaking
    By SJ in forum Super Cub Sick Bay
    Last Post: 06-13-2006, 02:08 PM
