Results 1 to 23 of 23
Thread: Push to talk button
    Dec 2011
    52
    Push to talk button
    All,
    I'm installing a radio in my cub that has never had one. Does anybody know of a ball for the stick that already has a PTT installed? If one exists where can a guy find one? To that end, do people like them on the ball or should I mount it elsewhere? What about the throttle ball? Thanks in advance!
    2,678
    Location will depend on the user. Everyone seem to have a favorite spot.
    I've never seen a factory produced ball with the switch installed. I make my own and drill the bolt in the stick to install them. The other option is the 'fighter pilot grip'. Fits over the stick and usually has a trigger switch and a couple of other pushbutton switches to use. If you install one of those, its mandatory that you make the swoosh sound of a jet as you fly.
    Thanks Hendoii thanked for this post
    Likes Ruffair, Hendoii, Willie liked this post
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,474
    Negative, tower!
    Likes Hendoii liked this post
    10,667
    we always just use the velcro on moveable buttons... slide it out of way when you are not using it
    1,825
    I have mine located at front of stick right below little finger. Very easy to use and keeps top of ball open in case I want to rest my hand on top or use wrist to fly as I am trying to mess around with both hands.
    Likes sjohnson, Steve Pierce, Hendoii liked this post
    Jul 2008
    176
    Ditto!
    txpacer's Avatar
    Jun 2011
    Iowa Park, TX
    684
    I've drilled the ball on the throttle for a ptt. The problem I'm getting in to is keeping the wires out of the way to avoid binding or pinching as the throttle moves. I think I've got it figured out, we'll see how it works.Click image for larger version.
    fobjob's Avatar
    Aug 2002
    Salt Lake City, Utah
    2,085
    I ran my switch wires the same way, and they abraided somewhat after 15 years, I guess that was long enough.....shoulda not depended on the tie wrap only, and added a blob of rtv or polyurethane to keep it from moving.
    Now, if someone could just come up with a way to not accidentally activating the switch while saying things that should not go out over the air.........
    Likes DENNY, Hendoii liked this post
    txpacer's Avatar
    Jun 2011
    Iowa Park, TX
    684
    I put a wrap of uhmw tape on it. As long as the tape says stuck, it should be ok.
    Cub Special Ed's Avatar
    Oct 2016
    MT/SD
    457
    2nd that
    "There are 3 kinds of men. The one that learns by reading. The few who learn by observation. The rest of them have to pee on the electric fence for themselves." Will Rogers
    6,909
    I have had them everywhere - all of the above. I prefer the top of the stick. I machine a piece of aluminum for a tight slip fit in the stick, and cut the top off the handlebar grip.
    one thing I have not figured out: how to keep the grip from sliding down when my students get a death grip on it.
    FdxLou's Avatar
    Apr 2004
    1,793
    Bob
    Try spraying hair spray inside the grip then slide it on and let it dry. Sticks like glue!
    Lou
    4,927
    My stick top has a trim switch. My PTT is what MCS Mike described. I pull it up in the airport environment and push it down for cruise. I can always reach it with my pinky if I need. In this case cheap wasn't the motivation. This PTT is precisely what I want, and it just happens to be cheap. Perfect!
    Ruffair's Avatar
    Jan 2008
    Lower Chena
    1,254
    How much talking on the radio you planning to do. might help determine where you put it. You’ve not had a radio in this cub before, a hand mic would probably suffice, except it’s harder to locate than a ptt.
    Real easy to toggle the ptt about anywhere you wanna put it for the two or three times you may use it, even in a class D (tower) environment.
    Clean and out of the way if it’s possible.
    There’s an old saying about flying first.... but you’ve already heard it...��
    19,088
    I prefer the switch below my little finger like Denny describes but have installed several of these for others.
    http://www.aircraftspruce.com/catalog/elpages/g101.php
    Likes wireweinie, FdxLou liked this post
    Dec 2011
    52
    As usual you guys are awesome! I sincerely appreciate everybody taking the time to help me out. It’s crazy the stuff you learn! I would have never thought to use hairspray!
    I think I’ll give the front of the stick method a try first and go from there. Thanks again!
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,474
    This is what real men use.
    You can pull the trigger and make GAU-8 noises!
    Likes Bender, Hendoii liked this post
    19,088
    Yuk, what do you need all that for in a Super Cub?
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,474
    You don't but it feels like home!
    2,678
    As stated above, think about how often you use your radio. One reason guys like a stick mounted switch is that you always have your hand on the stick. If the PTT switch is right there, you don't need to move your hand to talk on the radio. If you only fly out in the sticks and don't talk much, switch position is less important.
    Likes skywagon8a, Hendoii liked this post
    txpacer's Avatar
    Jun 2011
    Iowa Park, TX
    684
    There's a lot to be said for not talking much
    Likes KevinJ, nightflyer, Steve Pierce, Hendoii liked this post
    Ruffair's Avatar
    Jan 2008
    Lower Chena
    1,254
    Proly to pickle the Go-pro.... ������
    9,651
    Quote Originally Posted by Ruffair View Post
    Or the Wolf guns mounted on the wing struts.
  1. Push Button identification
    By Dbow in forum Cafe Supercub
    Last Post: 01-20-2013, 12:47 PM
  2. Replacing Push to Talk Button (wiring question)
    By barbwire in forum Tips and Tricks
    Last Post: 12-22-2011, 03:38 PM
  3. Push to talk buttons
    By WindOnHisNose in forum Tips and Tricks
    Last Post: 09-27-2005, 01:30 AM
