Results 1 to 17 of 17
Thread: Plug in LEDs
    Skycrawler's Avatar
    Mar 2016
    N. IDAHO
    14
    Plug in LEDs
    Hey all
    Looking to replace my Nav. light bulbs with LEDs .
    Just want a simple bulb replacement, not certified , fine with me.
    Suggestions type or brand ?
    Problems ?
    General info ?
    Likes Stick Wiggler liked this post
    sjohnson's Avatar
    May 2002
    Boise, ID
    675
    AeroLeds (an Idaho company)
    https://aeroleds.com/products/polari...eplacement-12/
    Not plug-in, but if you don't have ADS-B yet, consider Uavionix
    https://www.uavionix.com/products/skybeacon/
    Idaho drinks more wine per person than any other state in the country.
    skukum12's Avatar
    Feb 2004
    The Last Frontier
    1,104
    I tried a non certified set, will need to update with the brand later. They plugged in perfectly and are reasonably bright for the price paid.
    Two downsides however. They make noise in the headsets which I was told could be cured with short lengths of wire shroud. Secondly, the new clear lenses that came with them are made too thick. The lenses don't fit under the trailing cover plate. So I simply went back on with the original colored lenses which don't provide enough room for the LED itself and actually press against it and slightly push the bulb into the socket.
    I don't have an air to air report yet.
    "Always looking up"
    Skycrawler's Avatar
    Mar 2016
    N. IDAHO
    14
    Good info . Thanks
    Maybe better to spend the$ and get the cert. version?
    sjohnson's Avatar
    May 2002
    Boise, ID
    675
    AeroLeds?
    Sent from SuperCub.Org mobile app
    skukum12's Avatar
    Feb 2004
    The Last Frontier
    1,104
    Not Aero. See picture. I am not complaining mind you, just thought it a bit strange. Also it's been over 6 years since I purchased them, things may be better now.Click image for larger version.
    "Always looking up"
    2,644
    Check out part number 11-11374 in Aircraft Spruce.
    6,896
    For uncertified nav bulbs, just check out the automotive equivalent. The flash/nav lights seem to be about as easy to control as these new LED flashlights - you get to cycle through modes. I like to have one switch for nav, and another for strobes.
    19,049
    I installed these on my wing tips:
    https://www.aircraftspruce.com/catal...trobe11369.php
    and this on the tail:
    https://www.aircraftspruce.com/catal...trobe11371.php
    I have seen no TSO on bulbs. I do not use the strobe feature because it does not meet the requirement of a nav light when you do. They draw way less power which was great when I had a generator and just an added bonus now.
    These are probably better since they are 5 watts rather than 4 but were not out there or I did not see them when I got mine. I just noticed these are the ones Web recommended.
    https://www.aircraftspruce.com/catal...trobe11374.php
    https://www.aircraftspruce.com/catal...trobe11372.php
    Thanks Ruffair thanked for this post
    19,049
    Note, I have no noise issues but do not use the strobe feature.
    Feb 2015
    Anchorage
    33
    I use Whelen stuff...absolutely no drawbacks and they are made in the USA.
    4,885
    Whelen Orion nav/strobes on the tips, Whelen beacon on the rudder top, and an Aveo PosiStrobe on the rudder trailing edge. I can turn them all on with zero noise. The point of recognition lights is to be seen. Light it up!
    The only drawback with Whelen is the tail strobes have a big can that requires a big, deep hole to install it. Modification to the strobe attach plate is required. Aveo has a flush base. Aveo wins on that feature.
    AeroLED has a page for replacement bulbs on their website. https://aeroleds.com/bulb-replacement/
    2,839
    Quote Originally Posted by Skycrawler View Post
    Hey all Looking to replace my Nav. light bulbs with LEDs . Just want a simple bulb replacement, not certified , fine with me. ….
    Curious as to the goal--
    brighter output, reduced power draw, or ?
    How much juice does a regular nav light pull anyway?
    I know people who like to fly with the nav lights on all the time, even in daytime.
    FWIW I have never spotted another airplane in daylight by spotting the nav lights or the strobe.
    I have however often spotted another airplane due by their landing light, usually in flashing or wig-wag mode.
    6,896
    I converted my Cub to LEDs because I do not have an alternator/generator.
    Likes TCE liked this post
    19,049
    My goal was to have less current draw coming in at dusk with a generator. They don't charge at low rpm and tend to drain the battery. I also had an issue with a circuit breaker popping on my nav light circuit after a while. Cleaning connections, new bulbs and continuity check revealed no abnormality but since installing the LED nav light bulbs it has not been an issue. Some Super Cubs have a 7.5 amp circuit breaker and some 5 amps. The LEDs draw less than an amp.
    txpacer's Avatar
    Jun 2011
    Iowa Park, TX
    680
    I've had the same LED lights make noise in one plane, but not another. Grounding could be the answer.
    Feb 2015
    Anchorage
    33
    I have a new integrated set of Whelen strobes/navs. It mounts flush and is super bright. With the new led units there are no more cans when you mount them and no more power packs. It’s a pretty slick set up, but it ain’t cheap....but what is?
  1. Power Plug Options Besides Cig Lighter Plug?
    By behindpropellers in forum Modifications
    Last Post: 04-20-2005, 01:43 AM
  2. 12v Cig. plug
    By highroads in forum Modifications
    Last Post: 08-01-2004, 08:16 AM
  3. Power plug
    By CubCouper in forum Modifications
    Last Post: 12-21-2002, 02:08 AM
