Results 1 to 23 of 23
Thread: prop won't cycle.
    S2D's Avatar
    May 2002
    Montana
    4,061
    prop won't cycle.
    Have an IO-520 that the prop wont cycle completely. put another old prop governor on it and it got worse.
    I just dug up two more governors, but if neither of them work, I have to suspect the transfer collar inside the engine. Been so many years since I've seen this problem, but I seem to remember that there was a way to check the collar with pressure. Any Ideas before I have to pull the engine apart??
    10,428
    cracked crankshaft at transfer collar.... check oil screen, ours was PACKED TIGHT full of metal and hard to get out
    4,661
    Scroll down to the section about the oil transfer system.
    https://www.avweb.com/news/maint/pro..._195565-1.html
    Thanks S2D thanked for this post
    10,428
    spiral crack a transfer collar hole in crank, it actually "opens up" under load
    Apr 2017
    ND
    86
    Let me preface this by saying, “I don’t know anything about this topic.”
    I was a new to aviation, just out building time, and low time wonder.
    i remember a C210 that had a jerky and surging prop. I happened to be the guy that took the prop to the prop shop, and I recall the maintenance facility showing me the red with rust internal workings of the prop.
    jon s. blocker's Avatar
    Oct 2002
    corpus christi, tx
    211
    I had the inside crankshaft journal plug, on my 0360 come unseated, and the prop would not cycle because the preasure was going out the back side of the front crankshaft journal. Had to remove the prop, replace the rear plug and restake the plug. Very simple but had to figure out why the prop would not cycle since everything else worked. Just a thought. Jon
    4,661
    That 1/8” pipe plug behind the oil tube inside the crank is Lycoming specific. And frustrating!
    Oct 2002
    corpus christi, tx
    211
    Thought it probably was, but it was just a shot in the dark. I made a tool that slide down inside the shaft, past the offset oil stand tube, to replace and stake the plug behind it. I guess a one time tool, who else would have that kind of luck, Jon
    nanook's Avatar
    Aug 2002
    northern alaska
    1,649
    Make sure the drive spline is not worn/stripped, before you get too far into it...
    S2D's Avatar
    May 2002
    Montana
    4,061
    Thanks for the replies. Another governor didn't cure it, so looks like a teardown is the only option.
    9,381
    I didn't hear you say that you had tried another prop.
    S2D's Avatar
    May 2002
    Montana
    4,061
    Yea, I suppose I better just in case it's sticking.
    180Marty's Avatar
    May 2004
    Paullina, Ia
    2,025
    Let us know what you find. I always thought the half moon key and gear on the camshaft looked kind of mickey mouse.
    S2D's Avatar
    May 2002
    Montana
    4,061
    Will do . It does cycle some . Better when it's cold. Got worse when we had to switch from 100w to Phillips 20-50 cause our supplier ran out of 55s of aeroshell
    10,428
    Did this happen over a long time or all of a sudden. Ours was pilot flying along and Bang went flat pitch. He limped to a sand dune. We went down to try to diagnose next day. Fine on ground, but half way through patch went flat pitch again. Changed governor same thing. 3rd test flight engine went over 3000 rpm shook, threw the alternator belt off. Stepfather graves propeller and pushed fore and aft and said crankshaft cracked. Was the second one he'd been flying in that broke. Oil screen was packed tight by then
    S2D's Avatar
    May 2002
    Montana
    4,061
    Not sudden but over a short period of time .
    10,428
    Cracked crank. What did oil screen look like?
    S2D's Avatar
    May 2002
    Montana
    4,061
    Clean
    10,428
    prop won't cycle.
    DING!! Lightbulb in my head just turned on. If cracked crank through hole in crank at transfer collar, you will be able to LOOK INSIDE crankshaft with propeller removed and see crack
    4,661
    Isn't there an old service bulletin about IO-520 transfer collars? I can find one from 1978 but it seems like there was a more recent one.
    S2D's Avatar
    May 2002
    Montana
    4,061
    Well I'd have never guessed. Turned out to be the propeller after all. Swapped props and it works fine.
    9,381
    Lucky you!
    10,428
    Sludge? Wonder if a flush will help? No idea.
  1. The Cycle of Aircraft Ownership
    By SJ in forum Lighter than Air - Flying Humor
    Last Post: 06-23-2009, 05:31 PM
  2. re-cycle your airplane engines
    By J5Ron in forum Everything Else (formerly:My Other Plane Is A....)
    Last Post: 08-15-2008, 05:01 PM
  3. Correct prop torque for McCauley prop
    By OVEREASYGUY in forum Super Cub Sick Bay
    Last Post: 03-07-2006, 03:35 PM
