Results 1 to 13 of 13
Thread: Modern tail strobe for PA-12
    Aug 2017
    9
    Looking for a tailtop strobe for a PA-12. I would like something lightweight that doesn't need a big can on top of the tail. LED would be nice. Anyone know of anything available? Larry
    5,331
    Strobe or beacon? Whelen's approved LED beacons are really good. The best I could find when I was looking, and that included all the exp stuff.
    Aug 2017
    9
    Looked at the beacons. Would really like to find something that would just mount in the top of the post w/o needing a can up there. Thank you . Larry
    5,331
    Here are a couple of low profile options but you’ll still need to add a base.
    https://aeroleds.com/sunbeacon-series-certified/
    http://www.aveoengineering.com/redbaron-mini/
    Aug 2017
    9
    I was surprised at only a 2.22" dia. Where do I find a base? I assume it would be a weld on base? Thanks, Larry
    5,331
    Mine’s from Atlee Dodge but Univair is the same thing and their parts are easier to search.
    http://www.univair.com/atlee-dodge/p...nting-bracket/
    Aug 2017
    9
    Thank you for your help. Will run this by the owner and see what he wants to do. Larry
    7,175
    I don't know how bright a strobe needs to be, but my J-3 has one of those battery operated xenon tube deals that Navy fliers carried in their vest pocket. I'll dig out a photo . . .
    3,276
    Use the Attlee Dodge fiberglass mount and a Whelen 70509 beacon. No welding to install the mount and no power supply for the beacon (power and ground wires only). Beacon weight is listed at .27 lbs. 14VDC and 28VDC versions along with choice of red, white, or red AND white lenses. This unit is actually lighter than some LED beacons.
    Thanks Larry Huntley thanked for this post
    3,153
    The top of the tail is the most effective location to mount a single beacon or strobe,
    but a big wart up there sure ruins the attractive lines of an airplane--
    whether it be a Cub, C180, or whatever.
    My C150TD had a low-profile Aeroflash strobe head up on top,
    it was frenched into the fin cap which minimized it's wartiness.
Name:	new paint 1 (2).JPG
    Likes bob turner, CharlieN liked this post
    5,331
    The point of the light is to be seen, not to be invisible. I want the most effective recognition light I can get. How it looks on the ground is not a concern.
    7,175
    Then you probably want the "Comet Flash" setup on your wingtips. Pretty effective. My Dec has them - expensive!
    5,331
    Whelen Orions on my wingtips. Those came with my kit. Tail and forward lighting were for me to find. I shopped and compared and made my choices. The new LED stuff is impressive.
  1. Nav lights, strobes, tail strobe
    By Longarm in forum Member to Member
    Last Post: 12-30-2017, 09:56 AM
  2. J-5 with modern starter and alternator
    By Clipwing_T in forum Cafe Supercub
    Last Post: 08-26-2012, 05:19 AM
  3. How does modern fabric hold up in hailstorms?
    By mountainflyingvideos in forum Cafe Supercub
    Last Post: 06-04-2006, 05:48 PM
