Results 1 to 2 of 2
Thread: Edo 2000's with PA-12 Rigging
    Jul 2012
    Montana
    456
    Freshly refurbished 1969 Edo 2000's with PA-12 rigging. Last fall I walnut blasted the floats and struts, leak tested with shop vacuum pressure hose and soapy water, then sealed all bubbled areas using shop vacuum suction. Primed with Omni 2 part epoxy primer, and painted with Randolph float lacquer. All new pump-out rubber plugs, all new locker 'O' rings, new suction pump included.
    2 Rudders, all cables, pulleys and swivels, speed fairings, nice spreader bar lifting harness. There are only 2 patches and only one small crinkle all are shown in the photos below. Bottoms in good shape as well. The last two photos show the bottoms after stripping but before priming and painting.
    Despite all my work refurbishing these, there's just not enough water near me to make it worth putting them on my 12, they haven't been outside or wet since refurbishing. Located in Helena MT.
    $9,250.
    Doug, 406-431-8944
ID:	37284Click image for larger version.
ID:	37285Click image for larger version.
ID:	37286Click image for larger version.
ID:	37287Click image for larger version.
ID:	37288Click image for larger version.
ID:	37289Click image for larger version.
ID:	37290Click image for larger version.
ID:	37291Click image for larger version.
ID:	37292Click image for larger version.
ID:	37293Click image for larger version.
    Jul 2012
    Montana
    456
    Sold, headed to a new happy home I hope in Spokane
  1. EDO 2000 18 rigging on a pa-12 ?
    By eslboat in forum Modifications
    Last Post: 06-08-2006, 05:40 AM
Tags for this Thread
