Results 1 to 37 of 37
Thread: removing shock cords from PA-12
    Aug 2017
    9
    Yeah, I know, cut em. I am working on a PA-12 and have to remove the gear. Customer just installed new shock cords. Anybody know a way to get these off intact? Thanks for any thoughts, Larry
    Likes algonquin liked this post
    Colorguns's Avatar
    Dec 2013
    Bloomfield NY
    353
    Turbobeaver might have an idea?
    Doug
    PerryB's Avatar
    Aug 2007
    Chico, CA
    1,947
    However you go about it, you should tell the owner there is a new AD requiring all PA12's to be converted to 18 gear and they're grounded pending compliance.
    Likes mike mcs repair, irishfield, DENNY liked this post
    algonquin's Avatar
    Apr 2013
    Seldovia,Ak
    979
    I did one a few years ago so this is a bit foggy. I slipped a strap from a ratchet tie down in and worked it under. Tied a knot put a pry bar through and used the arch to pry against . When I got it over I think I needed a screw driver to move it clear and let it down gentle. You'll have to work it a bit but it worked good luck.
    10,905
    1. cost of new cord = 1X
    2. Labor to attempt to remove existing new ones = 3X
    3 if Step 2 don't go well, medical bills and loose of work time and/or life = 1243255X
    use knife...
    Aug 2017
    9
    use knife...
    Read Algonquin and thought about it. Sounds doable. Read Mike and decided his idea was prolly safer. Guess I cut em. Thanks to both, Larry
    Likes rmac, Steve Pierce liked this post
    Charlie Longley's Avatar
    Jan 2008
    Arlington, WA
    649
    Quote Originally Posted by Larry Huntley View Post
    Having done quite a few PA-12 shock cords. I prefer Mike's idea.
    R. JOHNSON's Avatar
    DODGEVILLE WI
    372
    I've installed them on a J-5 with an engine hoist and rope, don't think it'd be too difficult to go back off with them the same way.
    Jan 2008
    Arlington, WA
    649
    Quote Originally Posted by R. JOHNSON View Post
    Unlike a stock J-5 a stock PA-12 doesn’t have hydrosorbs. The shock cords are buried in the belly. It would be interesting getting an engine hoist in there. I use a modified handyman jack to install them.
    7,026
    There is a special tool, and even that doesn't work real well. I doubt I would even attempt a -12 without the tool.
    If cost is an issue, there are suppliers who sell out-of-date shocks for cheap. As far as I can tell, they are almost as good as fresh ones .
    - I have a 1955 Chevy bumper jack modified so J-3 struts can be undone without cutting and sort of safely redone in about 20 minutes per side max.
    19,366
    Quote Originally Posted by Charlie Longley View Post
    I thought the J5 had shock cords like a PA12. I thought the Pacer/ Tri-Pacer and the later Super Cubs and Pawnees were the only ones using hydrosorbs.
    Jan 2008
    Arlington, WA
    649
    I misspoke the J-5 has external shock struts and bungees similar to a J-3. The PA-12 has internal bungees and a rubber bumper.
    R. JOHNSON's Avatar
    DODGEVILLE WI
    372
    Was a J-5C, same as a PA-12 shock arrangement I believe. Raise the tail and take the door off.
    Jan 2008
    Arlington, WA
    649
    I didn't realize that. All the J-5's I've seen had external shock struts and bungees.
    PA-12 okie's Avatar
    May 2018
    5
    What cords does he have on them, and how many? I've have had a dickens of a time determining what should be on mine. I had new ones installed at a pre-buy annual, and the tag on them states 06-00826, which I've been able to cross reference as a 31322-05 and 1280HD. I've seen conflicting information as to how many of these should be on the plane. Piper Service Memo 12 states 6 each 31322-05's, however Univair states there should be 4 each 1280HD's. I've read posts on here that 6 each of the 1280HD's would be like welding your gear, and my back side concurs. I have never seen my gear flex....ever....and I live on a bumpy grass strip. So I think I'm reading that the recommended method of removal is via knife, but I'm wondering about the recoil and what technique to use to be done safely?
    stock PA-12, 0-235 configuration
    cubpilot2's Avatar
    May 2003
    Anchorage Alaska
    768
    Quote Originally Posted by PA-12 okie View Post
    I often use a hacksaw with fine tooth blade. Keeps you well back from the action....
    Ed
    Thanks PA-12 okie thanked for this post
    Likes PA-12 okie liked this post
    PA-12 okie's Avatar
    May 2018
    5
    That sounds like a reasonable technique. I'm hoping someone on here can help me determine the number I need. I currently have 6 of the 1280HD's and its stiff as a board. I'm beginning to suspect that I need only 4, and assume (I know) that I could cut one off each side without damaging the remaining ones? I'd sure like to see how nice it is to have suspension on my plane. I've heard after some use they soften up, but I've got 50hrs on these and no flex in suspension at all.
    If someone can verify that 4 is the correct quantity, please steer me to the references that I can provide to satisfy my IA!!
    machinist1's Avatar
    Apr 2006
    Shattuck, oklahoma
    34
    Changed my cords on my '47 -12 last year. I installed 3 1280's per side. Note that these are 1280's not 1280 HD's. Got them from Univair. Seems like they cost 35.00 or so a piece. The gear works just fine. Also I was faced with having to cut a set of cords off the left side after installing them due to the discovery of a crack on the gear assy. that required welding and recovering. I used a sharp utility knife/razor simply cut the cords on at a time. Go slowly and pay attention as they do let loose with a bit of force.
    PA-12 okie's Avatar
    May 2018
    5
    Shattuck...Hey another Okie with a 12?! I'm at Guthrie. Thanks for the info...that's exactly what I needed to hear. Now....since I know mine are the 1280HD's....I'm thinking of cutting one off each side to see how they operate.
    Jul 2012
    Montana
    437
    Don't forget to replace or at the very least inspect the rubber bumper pad on each side when you have the bungees off. you'll be glad you did so you don't have to fix a flattened cracked cross tube that the gear closes against. You can imagine why I know this:
    http://www.univair.com/piper/piper-p...-bumper-block/
    machinist1's Avatar
    Apr 2006
    Shattuck, oklahoma
    34
    Way up here in N.W. Oklahoma. Been flying out of WWR for 12 years now. Always glad to hear about -12's in Oklahoma. Seems like there was a post about running (2) 1280HD cords per side and it believe it was a working combination. Like me know what you discover. Also agree with MT12 on the bumpers, definitely need to be changed when doing the cords.....
    39-J3's Avatar
    Sep 2008
    Maine
    553
    Is there an STC to put 18 gear on a PA-12? I was looking at a 12 on floats a while back but was turned off when I heard all that they had to go through to remove the landing gear and install the floats.
    Larry.
    Jul 2012
    Montana
    437
    Yes, atlee dodge has the stc for 18 gear on a 12, and not so coincidently I have a set of Edo 2000's for a 12 for sale. As it turns out theres just not that much water in Montana
    10,905
    Quote Originally Posted by 39-J3 View Post
    Is there an STC to put 18 gear on a PA-12?..
    Larry.
    there are a few different STC's...
    Jan 2008
    Arlington, WA
    649
    Quote Originally Posted by MT12 View Post
    There’s water near Seattle. How much do you want for the 2000’s?
    Jul 2012
    Montana
    437
    Freshly blasted with walnuts shells, leak tested and sealed, fresh float laquer, double rudders, all hardware, $9250, 406.431.8944. I'm on the road this weekend will post ad and pic's on Tuesday
    PA-12 okie's Avatar
    May 2018
    5
    So just as a follow-up and for that next guy that needs to know. The cutting off of one per side was a non-event. I tied several loops of 1/4" nylon rope all the way around both sides, then took a utility knife and started at the outside edge of the outside cord. Just slowly and gently nicking it will cut the individual rubber bands easily. once you get about 3/4 of the way through it, it starts to release itself and since mine were tied when it released, it just sprung a inch or 2. Nothing violent, or damaging. It took a little finagling to thread it back out, but it wasn't difficult. I have yet to fly it and see how much difference it made, but it had to have helped. When I install new chords next time, I'll go with 3 per side of the 1280 non HD's.
    Now once I get my new tanks installed and new sealed struts on, I should be flying again!! Thanks to all of you for your input, helpful as always!
    evroosevelt's Avatar
    Dec 2009
    Wilsonville, AL
    153
    What is the AD number for the PA-12 gear removal?
    Jul 2010
    Elizabeth, WV
    568
    No such AD. It was an inside joke. Some folks would just rather work on 18 gear.
    Oct 2008
    Johannesburg, South Africa
    59
    3 x 1280 HD each side sure sounds like overkill on a PA-12. I have an Auster J/5G 4 place with a 2500lb gross weight that takes a total of 4 1280 HD bungees - very similar arrangement to PA-12 - swine of a job fitting them.
    'There can be no liberty unless there is economic liberty".
    Margaret Thatcher
    Jan 2017
    Utah/Alaska
    123
    I have a modified bumper jack and use a strap, put the strap around the bungee, jack up the jack, push the bungee over the mount and then down jack.
    7,026
    Picture? Just in case I ever have to help again? My buddy rented a special tool, and it really didn't work well at all.
    Jul 2010
    Elizabeth, WV
    568
    Quote Originally Posted by astjp2 View Post
    I also have a modified bumper jack. We used quarter inch nylon rope through the bungee and cut the loop after the bungee was installed cause we weren't ever gonna get that knot untied. One loop broke on our very first attempt. Two loops worked for first and second bungees. When two loops broke on the third bungee my fat ass ended up in the rear seat and I was desperately clinging to the jack with both hands cause I thought either it had gone through the instrument panel or I was now dead from the explosion. Amazingly scary how much force it took to get the third bungee installed. Installing PA12 bungees is serious business and you could get hurt or things could get tore up.
    Thanks JDWilliams thanked for this post
    TurboBeaver's Avatar
    Jun 2009
    Northern Maine
    755
    Well this is either a massive load??? Or what a Cruiser looks like with only ONE bungee on each side......
    Do NOT try this at home! Lol.
    Likes Charlie Longley liked this post
    PerryB's Avatar
    Aug 2007
    Chico, CA
    1,947
    You've heard of Tango Cubs? That's a Limbo Cub. That's how it fits under the hangar door.
    Likes windy liked this post
    Jun 2009
    Northern Maine
    755
    Perry for real low doors we can do this! LoLClick image for larger version.
    PerryB's Avatar
    Aug 2007
    Chico, CA
    1,947
    Oh yeah, just roll it in on the creeper.
  1. shock cords
    By capav8 in forum Experimental Cubs
    Last Post: 01-30-2011, 01:45 AM
  2. Shock Cords
    By MULESKINNER in forum Cafe Supercub
    Last Post: 11-24-2006, 11:15 PM
  3. Shock cords
    By Swedcub in forum Cafe Supercub
    Last Post: 11-12-2004, 02:16 PM
