Results 1 to 25 of 25
Thread: belly pod on floats
    Apr 2018
    29
    belly pod on floats
    Hi, I purchased a carbon belly pod from Carbon Concept LLC and I figure to install it on my sc this weekend. I just ask me how I'll fit the water rudders pickup tube, mine is on my left. My plan is to put a fuel bladder in the bellypod, my fuel pump, pipes are already installed. any advices? hint?
    thank you
    Bush4
    AkPA/18's Avatar
    Feb 2003
    Big Lake Ak
    634
    I did not want to cut the ty wrap but hopefully you can see what I did. Made a stainless strap on spreader bar with an eyebolt. Attached a cable and pulley to the eyebolt approx 15 in. Cut the end of the fuselage cable tube so the cable comes out straight
ID:	36492Click image for larger version.
    Mark
    http://thrustline.com/
    AkPA/18's Avatar
    Feb 2003
    Big Lake Ak
    634
    If you can blow this up it might help understand what I was trying to explain.
    Mark
    SteveE's Avatar
    Feb 2006
    Jenks, OK
    4,205
    I like that N number Mark. 4147Eaton.
    Sent from my iPhone using Tapatalk Pro
    Apr 2018
    29
    Thank you very much Mark! it's a good Idea, I was thinking to cut the tube and weld a piece of pipe between the flange and the elbow...
    aktango58's Avatar
    18AA
    9,057
    use stainless eyebolt from west marine
    Apr 2018
    29
    Aktango58, why stainless eyebolt? I already have some an eyebolt
    Nov 2015
    Pelham NH
    143
    Bush4,
    Look at AKPA/18's picture. stainless bands and rusty eye bolts. If you use stainless eye bolts it will be a lot easier to remove later and not damage the strut. Chip D.
    9,795
    Thanks eskimo77 thanked for this post
    Nov 2015
    Pelham NH
    143
    Glenn,
    I little blurry on the picture.
    Chip
    Apr 2018
    29
    I didnít knew that product... thank you Glen
    10,439
    Quote Originally Posted by bush4 View Post
    I didn’t knew that product... thank you Glen
    Par al ketone was my best friend when I flew an amphib Beaver in Kodiak.....great corrosion preventative. Mechanics in ANC used to hate seeing that thing come in for inspection....they had to remove all this stuff before they could find the plane.
    9,795
    Quote Originally Posted by Chip D View Post
    Glenn,
    Chip
    Sorry http://www.aircraftspruce.com/catalo...aralketone.php
    All we used a Rhinebeck to protect against corrosion. It's real thick at room temp so scrape some in a soup can and heat it up and you can brush it till it cools, then it stays where you put it. You can cut it with some mineral spirits if you want a thinner mix.
    Nov 2017
    Anchorage, AK
    15
    When I was in high school, I worked for a guide that had a Turbo Beaver on anfibs. When he first got it my job was to replace all the steel sheet metal screws with stainless screws, coat all of the exposed nuts, and bolt heads with Par-Al-Ketone. The Par-Al-Ketone did a great job of protecting the steel fasteners from the saltwater spray. Be careful and do not let it get to close to your favorite sneakers, it’s some black nasty gooey stuff.
    Apr 2018
    29
ID:	36597Click image for larger version.
    Almost done!!
    cruiser's Avatar
    May 2002
    South Glens Falls, NY
    1,440
    Corrosion X heavy duty will do a better job with a lot less mess.
    Apr 2018
    29
    Jobís done! Click image for larger version.
ID:	36708Click image for larger version.
ID:	36709Click image for larger version.
    Iíve cut a little hole in the bottom of the door and replaced the piano wire with another one in stainless and bend the end to make it easy to remove.
    cubpilot2's Avatar
    May 2003
    Anchorage Alaska
    724
    Looks like you rear wires barely missed the door hinge.
    Can you post a photo of how they look from the inside? ( how much in the way are they?)
    I'm wanting a pod for my float cub but the new Landis certified CF unit wont work due to wire interference with their door. I was bummed when they told me that as it good for 170 lbs.
    Ed
    18,654
    Job’s done! Click image for larger version.
    I’ve cut a little hole in the bottom of the door and replaced the piano wire with another one in stainless and bend the end to make it easy to remove.
    I thought your question was how to run the water rudder cable/tube? Looks like it is still hanging.
    aktango58's Avatar
    18AA
    9,057
    Steel actually comes off easier than stainless when flying salt water, just twist 1/2 turn and it falls off, or in two years it departs on it's own.
    all the coatings you put on can help, but using stainless takes less time, looks better, and my wife is not displeased when I forget to separate my work clothing from my 'been under the airplane' clothing in laundry.
    And before you start on doing my own laundry, then I hear about making a mess of her machine!
    Apr 2018
    29
    Steve, yes it hanging for now, Iíve ordered a couple a pulley with bracket from aircraft spruce but itís back order until may 1st... anyway, the lake are still frozen here. Iíll need to bend pieces of aluminum to hold the pulleys against the rear strut.
    Cubpilot2, yes Iíll take some pictures to show you how weíve fit it and how weíve mesure for the holes
    Aktango58, I never fly salt water. Iím about 200nm from salt water
    Thanks cubpilot2 thanked for this post
    Apr 2018
    29
ID:	36954Click image for larger version.
ID:	36955Click image for larger version.
ID:	36956Click image for larger version.
ID:	36957Click image for larger version.
ID:	36958Click image for larger version.
    Apr 2018
    29
    Cubpilot2, Now I have 2 piano wire to hold the door, easily removable
    cubpilot2's Avatar
    May 2003
    Anchorage Alaska
    724
    Thanks for the photos.
    I think that I would be a bit concerned about the hinge wearing into the brace wire if the pod were to shift any; perhaps from flight loads or the load you put in it.
    I would think that more clearance along with a rubber sleeve over the wire would be a good thing.
    You don’t want any wear / cuts on those highly stressed wires!
    Spoke with Randy at the trade show and he mentioned something about a split door for floats. Something to think about.
    Ed
    Apr 2018
    29
    We have though about split door but how to seal the gap? And anyway, itís easier to load and unload the pod by removing the piano wire from the hinge rather than struggle with the door against the struts bolts ends...
    I have a bunch of rubber grommets I can put around the brace wire. I donít know if aluminum and/or carbon fibre could damage stainless wire... I have about 1/8 inch loose all around the brace wire.
  1. I Got Your Belly Pod Right HERE!
    By SJ in forum Video Vault
    Last Post: 12-30-2014, 10:57 AM
  2. EX Belly Pod
    By cubdriver2 in forum Cafe Supercub
    Last Post: 12-13-2013, 07:30 AM
  3. To Belly bod or not to Belly pod, that is the question
    By Fortysix12 in forum Cafe Supercub
    Last Post: 10-19-2006, 04:43 PM
