Thanks Thanks:  0
Results 1 to 5 of 5
Thread: Swamp Monster
    flyrite's Avatar
    Mar 2013
    Lyons,GA
    477
    Swamp Monster
    Started life in 76 as a woody pusher, I got it 23 years ago and after 1600 hrs. and 2 rebuilds ,started moding it for bush flying five years ago on the last rebuild .
    Spoiler boards slaved to the ailerons for slow speed roll control, mounted on 2 foot carbon fiber extensions ,End plates to control the span wise flow at slow speed's, VG's behind the slats, 8 inch gear extensions, 26 inch bush wheels, ABWClick image for larger version.
ID:	36478Click image for larger version.
ID:	36479Click image for larger version.
ID:	36480double puck brake calipers,
    Spades to lighten the ailerons, servo tabs on elevators because of the high thrust Line , Even though I've got a jackscrew on the horizontal stabilizer, J-3 tail .Flaps on belly, main lift struts, as well as 4' on each side of the T.E. all slaved to the belly flap .
    Olibuilt's Avatar
    Nov 2009
    Montreal, Canada
    822
    Cruise speed, stall speed, engine, weight, ...... Please continue to teach us on your non ordinary bird.
    flyrite's Avatar
    Mar 2013
    Lyons,GA
    477
    Cruise 70 mph, stalls power on something under 30, with 1700 RPM 33 , approach comfortably 38 to 40, touch down in low 30s. ROC 800 fpm, E.W. 810, C-90, no electric although it is a Dash 12 engine.
    Likes brown bear, Seaworthy liked this post
    cgoldy's Avatar
    Apr 2009
    Moogerah Queensland Australia
    406
    Wow!
    And the engine?
    flyrite's Avatar
    Mar 2013
    Lyons,GA
    477
    Quote Originally Posted by cgoldy View Post
    Wow!
    And the engine?
    Continental 90 hp, all of the mod's was fun to engineer. The toughest of them was working out the linkages on the flaps for the struts .that took some time and pondering. All the rest was pretty easy , The little plane lends itself to this kind of moding ,just a matter of covering your bases on the loading, then fabricating how you're going to mount them . It doesn't hurt to have a good friend that is an aeronautical engineer working for Gulfstream that has access to their computer programs for load testing!
    Likes Brandsman, Seaworthy liked this post
  1. Swamp Monster
    By flyrite in forum Everything Else (formerly:My Other Plane Is A....)
    Last Post: 10-04-2017, 10:51 AM
  2. Nav Monster BACK ON LINE
    By SteveE in forum Cafe Supercub
    Last Post: 07-19-2012, 04:48 PM
  3. Created a Monster
    By mongo in forum Cafe Supercub
    Last Post: 03-05-2011, 01:34 AM
  4. Monster Extended Gear
    By SuperCruzer in forum Experimental Cubs
    Last Post: 02-16-2011, 03:46 AM
