flyrite
Lyons,GA
Started life in 76 as a woody pusher, I got it 23 years ago and after 1600 hrs. and 2 rebuilds ,started moding it for bush flying five years ago on the last rebuild .
Spoiler boards slaved to the ailerons for slow speed roll control, mounted on 2 foot carbon fiber extensions ,End plates to control the span wise flow at slow speed's, VG's behind the slats, 8 inch gear extensions, 26 inch bush wheels, ABWdouble puck brake calipers,
Spades to lighten the ailerons, servo tabs on elevators because of the high thrust Line , Even though I've got a jackscrew on the horizontal stabilizer, J-3 tail .Flaps on belly, main lift struts, as well as 4' on each side of the T.E. all slaved to the belly flap .
