Results 1 to 8 of 8
Thread: Heavy Duty Axles - Airforms vs Cessna
    Mar 2018
    69
    I think it is long overdue to install a set of heavy duty axles. I was checking out the price and I am wondering if Cessna lowered their price. Their price is actually lower than Airforms. Is there any advantage to the Airforms axle, or is it the same as OEM?
    FdxLou's Avatar
    Apr 2004
    1,782
    I’ve always been told to go with Airforms for strength, etc. So I did. Just installed HD axles from McFarlane (Airforms) and ABI HD brakes on my ‘54 C-180. Great improvement over my single puck Cleveland’s.
    Lou
    2,625
    Looks like Spruce also has the Airforms steel axles, for a bit less money.
    FWIW I've heard reports of the old hollow aluminum axles failing, but doubt very many people still run those.
    Don't think I've ever heard of the solid aluminum axles failing.
    But steel seems like it'd be better yet.
    Oct 2018
    9
    Any further thoughts on this? I’m interested in the upgraded steel axles. We’re steel axles an factory option at any point?
    Seems like a couple more lbs well worth the comfort in strength.
    1441003-1
    298$/ea on cessnadirect.com
    0541124-1 axle for 918.90$/ea on cessnadirect.com
    from what I can tell 1441003-1 is the steel axle number but not sure based on price difference.
    thanks in advance
    Mar 2018
    69
    Quote Originally Posted by Experimental1911 View Post
    Any further thoughts on this? I’m interested in the upgraded steel axles. Were steel axles a factory option at any point?
    1441003-1
    thanks in advance
    The steel axles were always an option and were called 'heavy duty' (ref p/n 1441003-1). (As opposed to the "standard duty", solid Al ones - ref p/n 0541124-1.) I wound up picking up a set of NOS Cessna ones instead of the more expensive Airforms. (Thanks for lowering the price, Textron!)
    2,625
    1441003-1
    cessnadirect takes you to a Yingling website.
    Airpower Inc sells the same Cessna p/n 1441003-1 axle for about the same price ($295)
    http://www.airpowerinc.com/productca...&prodid=430141
    Spruce & Skygeek sell the Airforms steel axle for a bit more.
    Googled p/n 0541124-1 ….. looks like a solid aluminum axle?
    Not sure why those would cost more -- supply vs demand maybe?
    FWIW here's some used ones for $75 each:
    https://www.ebay.com/itm/0541124-1-C...-/252469147077
    Mar 2018
    69
    Cessnadirect is Yingling's ecommerce site. Lately, AirPower has been a couple of percent lower on price compared to Yingling, that's true.
    Dave Calkins's Avatar
    Jul 2002
    Anchorage, Alaska
    5,362
    The Cessna steel axles have a machined bearing stop.
    This must be removed for Airglas straight ski installations, with a sleeve bearing stop installed in its place for the wheel installation FYI
    I dont recall if Airforms has the machined stop per Cessna or supplies a sleeve stop. sorry I dont have a photo (a thousand words).
  1. HEAVY DUTY TAILDRAGGER
    By Seaworthy in forum Cafe Supercub
    Last Post: 12-31-2006, 12:12 PM
  2. heavy duty header tanks
    By M1 in forum Modifications
    Last Post: 04-15-2004, 07:55 PM
  3. Heavy Duty Fork Ends
    By Dale Strong in forum Modifications
    Last Post: 04-16-2003, 08:04 AM
