Results 1 to 9 of 9
Thread: Elevator balance cable spring
    Oct 2009
    Wanaka,NZ
    366
    Can anyone help with a part number for the top elevator balance cable Spring on a pa 18-105 please.Thanks Ron.
    Stew's Avatar
    Jul 2013
    Haywards Heath, UK
    125
    Elevator Balance Cable Spring
    Hi Ron
    Not an expert in these matters by any means.
    I would suggest 10940-2 (Univair U10940-002) but perhaps you could draw your own conclusions from Piper Drawing 12263, it has quite a lot of info in the notes about the various configurations.
    Kind regards
    Stew
Name:	12263_Bungee Installation.jpg
    Attached Files Attached Files
    Oct 2009
    Wanaka,NZ
    366
    Quote Originally Posted by Stew View Post
    Hi Ron
    Kind regards
    Stew
    Thankyou Stew,My son has just bought this cub and as yet I only have seen a small photograph of a broken Spring hanging down vertically in this area.The part you have itemised appears to be the one.In your opinion would there be any problem in ferrying this aircraft with this Spring broken?Regards,Ron.
    11,298
    Quote Originally Posted by ron View Post
    on HEAVY cubs that spring and cable gets removed.... it just to help keep the tail down, empty...
    Stew's Avatar
    Jul 2013
    Haywards Heath, UK
    125
    Hi Ron
    The only other spring in that area would be the trim cable tensioning spring (top right of drawing)..
    If that spring was dangling then the stabilizer trim would not function.
    Kind regards
    Stew
Name:	13000_Yoke Installation_Stabilizer Adjustment.jpg
    Thanks ron thanked for this post
    Apr 2017
    1
    If I have an electric trim why do I need the elevator (trim) tension spring?
    10,229
    Anyone know # for spring and cable on unbalanced elevators? Pa11/18-95 type
    Oct 2009
    Wanaka,NZ
    366
    Thanks everyone for your info.The spring in question was the upper elevator Spring.We replaced this and during the operation we disconnected the lower Spring.Now operating the aircraft on PK floats.The spring juggling has now made the takeoff a much lighter excercise��
    7,175
    Some Super Cubs can be flown without changing trim at all - a pleasant experience. Others absolutely need trim when making flap changes. I always assumed it had to do with how stretched-out that spring got. I suppose I should have looked to see if it was left out.
  1. Elevator Bungee Cable and Spring loose
    By EnglishNeil in forum Super Cub Sick Bay
    Last Post: 09-09-2016, 06:23 PM
  2. Replies: 7
    Last Post: 10-27-2010, 10:31 AM
  3. Elevator Balance Cable
    By Jim Miller in forum Experimental Cubs
    Last Post: 10-14-2010, 01:43 PM
  4. Elevator to jackscrew cable and spring.
    By Glenn5ft19 in forum Experimental Cubs
    Last Post: 01-02-2006, 01:04 AM
