Page 4 of 6 FirstFirst ... 23456 LastLast
Results 121 to 160 of 201
Thread: I'm Back in a Spam Can!!
  1. #121
    9,562
    Job well done Eddie. Pay attention to your loaded CG. These planes tend to be nose heavy, which is why Cessna places the battery in the baggage compartment. Overall performance is much better with the CG more towards the rear than the front.
    Thanks Eddie Foy thanked for this post
  2. #122
    4,819
    I'm looking forward to your first flight pirep. I'm betting you'll have a big smile. Have fun!
  3. #123
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,454
    Depending on how the weighing goes, I will put ballast in the rear if necessary. I ditched some weight by deleting the vacuum but the 88 inch prop weighs a bit more. I am betting I shed 60 lbs off the last W&B.
  4. #124
    4,819
    The firewall mounted Odyssey saves an easy 15# and provides much better battery performance. You shouldn’t have any issue with CG. When I did it my plane had a 470 and an 88” 2 blade. I couldn’t tell any difference. Now it has an 86” 3 blade and it’s still easily within the envelope. You might enjoy how it flies with weight in the back but it shouldn’t be necessary.
  5. #125
    Aug 2015
    ME, ID, AK - what time of year is it?
    462
    Nose heavy empty CG is great, given the load hauling mission these birds typically fulfill. Rearward ballast? Great excuse to start putting together your survival bag w/backcountry gear. With spare water, should weigh in around 30-40 lbs if requisite axe, etc goes in.
    Looking like you've put together a really nice 180, Eddie. Enjoy!
  6. #126
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,454
    Weighed the 180 today. Don't have the final CG calc yet but the weight went from 1850 to 1666!! Very little interior and two seats. It pulls to the left badly during taxi. Measured the toe and it is way off. Have to order shims from Grove.
    Likes RaisedByWolves, FdxLou, Farmboy, hotrod180 liked this post
  7. #127
    3,857
    That’s quite the weight loss. Awesome! It should fly great.
  8. #128
    4,819
    What did you remove that accounts for 184#?
  9. #129
    Dec 2016
    Canyon, tx
    450
    Exwife?
    Likes S2D, RaisedByWolves, FdxLou, Rice farmer liked this post
  10. #130
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,454
    Most of the interior
    The bench seat
    About 40 lbs of abandoned wire, coax, and antennas
    Vac Pump
    Smaller Battery
    Very heavy avionics, autopilot, and radios
    About 20 lbs of dirt
    Dead skunk
    Who knows how accurate that 1850 was.
  11. #131
    Farmboy's Avatar
    Jan 2016
    Glens Falls, NY
    2,158
    The 1850 was probably without dirt and wire. Probably actually removed 200 lbs.
  12. #132
    9,562
    What did you do to it that caused this error? Did someone have the gear apart losing the shims along the way?
  13. #133
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,454
    I completely removed the gear and the whole sheebang. New brakes and wheels from ABI. I put it back together without shims for two reasons. They were in bad shape and I didn't label them well when I removed them. I knew that I would have to align the gear. I was not surprised that it did not track. New Grove shims on order.
  14. #134
    10,619
    Eddie,
    Get it shimmed right and you'll never look back and you'll never doubt that landing gear. My opinion: If you change a LOT of stuff, you really need to put the gear on grease plates and rig it properly.
    Once it's done, the gear will be honest and you'll know what to expect. I think too many folks make major changes and expect to just go ahead with the gear and shims they had before.
    Good time to re-rig the gear. PITA, and well worth every minute it takes to get it right.
  15. #135
    tptailwheel's Avatar
    Apr 2004
    vermillion sd
    146
    Mike is absolutely right as usual, do the work to make it track perfectly, it will pay big dividends. Don’t ask how I know this.
  16. #136
    L18C-95's Avatar
    May 2011
    London, UK
    463
    How light can a 185B with the simple fuel system be got down to? Would it beat Mr Foy’s excellent result?
  17. #137
    L18C-95's Avatar
    May 2011
    London, UK
    463
    Put another way Mr Foy’s aircraft is around 106 Lbs above the advertised bare bones 180H which is probably about as close to bare bones you might get
  18. #138
    2,791
    IMHO 1,666 is extremely light for a later model 180.
    Good job Eddie!
  19. #139
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,454
    CG came out at 34.92! Still working on gear toe in. Flight in a week or so.
  20. #140
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,454
  21. #141
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,454
    Ready to slip the surlies! Taxies straight as an arrow. First flight Tuesday!
    Thanks Steve Pierce, tripper thanked for this post
    Likes Chicken Hawk, RaisedByWolves, FdxLou liked this post
  22. #142
    aktango58's Avatar
    18AA
    9,131
    That is LIGHT!! Great job!!
    Nice that your friends helped you out with air fresheners, a dead skunk is just a great way to move CG back for landing
    Amazing how fast weight adds up, especially when pulling wire that had been disconnected years ago.
  23. #143
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,454
    Maiden voyage complete. Sorry Pierce but I made 5 decent landings and no unplanned 180s. Airplane flies nice and straight.
    Likes Chicken Hawk, hotrod180 liked this post
  24. #144
    18,989
    Video proof? Did you take someone with or did you cowboy it? Congrats, I can picture the big grin on your face.
  25. #145
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,454
    ALone and unafraid!
  26. #146
    Meanwhile,...
    5,083
    Did you go actually around the pattern or just do 5 stop and goes on that little bitty 6,300' grass runway?
  27. #147
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,454
    2.1 Stall series and the whole smear. G5 shows 45 indicated when it mushes and nose drops. Pretty benign. Actually three flights for a total of 2.1
    Likes FdxLou liked this post
  28. #148
    FdxLou's Avatar
    Apr 2004
    1,788
    Eddie
    Does that mean we will be able to see your SkyStud at SnF?
    Ill be there camping in Vintage from Sunday to Friday. Hope to see you.
    Anyone else going?
    Lou
  29. #149
    18,989
    Quote Originally Posted by FdxLou View Post
    Eddie
    Anyone else going?
    Lou
    Yep.
    http://www.supercub.org/forum/showth...Sun-n-Fun-2019
  30. #150
    FdxLou's Avatar
    Apr 2004
    1,788
    Thanks SP. Missed it.
    Lou
  31. #151
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,454
    Just when I thought I was out of the woods. I now have a weeping left tank. My IA suggested Floats and Fuel Cells. Theirs are $950 each.
    Any other suggestions for bladders. Mine has the 32.5 gallons/ 30 useable ones.
  32. #152
    9,562
    Those are the ones that I used recently. Mine are the long range tanks and it took me 10 hours labor each. I hope you have long arms.
    Thanks Eddie Foy, windy thanked for this post
  33. #153
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,454
  34. #154
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,454
    6 Ft 4
  35. #155
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,454
    Looks like two new bladders, sending units from McFarlane, and new quick drains. I am spending my ungrateful children's inheritance. Need to have it back together for Gastons. Sun N Fun is out.
    What tape is used on the inside.
    Likes RaisedByWolves, mike mcs repair liked this post
  36. #156
    Nov 2006
    60
    Any good supplier will include all of the hardware, gaskets, and one roll of tape per bladder that they send you.
    Likes skywagon8a, FdxLou liked this post
  37. #157
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,454
    Removed both bladders this morning. One was from 86 and the other from 91. It wasn't too bad but both front screens have seen better days. $250 each from Burl.
    Now the real fun begins. Removing old tape and retapeing. Then getting all the snaps snapped. I do have long arms.
    Pray for me. I have a better understanding of why mechanics hate this job.
  38. #158
    9,562
    If the old tape is still in good condition there is no need to redo it.
  39. #159
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    3,454
    That is the pray for me part. I haven't inspected the tape yet.
  40. #160
    3,857
    Will it hold up for another 30+ years?
    When I was in A&P school I worked after school at an FBO. My first job was bladders on an early 210. Owner of the shop said if you do this job of re taping and installing the bladders , and don’t quit, you’ll probably make it.
    Last time I did one they sent a box of bandaids with there logo on it.
    Likes Steve Pierce, hotrod180, Barnstormer liked this post
  1. J-3 Back seat, hurts back. Any improvments?
    By Ruffair in forum Everything Else (formerly:My Other Plane Is A....)
    Last Post: 04-24-2013, 03:29 PM
  2. News (or) Spam
    By NimpoCub in forum In The News
    Last Post: 03-21-2009, 10:43 AM
