Results 1 to 6 of 6
Thread: RPM Loss
    Shogun65
    Feb 2015
    KMYF
    1
    RPM Loss
    How much rpm would you expect to lose on a super cub engin 0-320-A1A with climb prop 74DM6-0-58
    nanook's Avatar
    Aug 2002
    northern alaska
    1,690
    What did you have on before for a prop?
    10,216
    That is a cruise prop. A climb prop would have a 54 pitch. A standard (original) pitch would be 56.
    http://www.sensenich.com/files/docum...1349891787.pdf
    19,638
    50 rpm per inch. 58" is a climb prop on a Pacer or Tri-Pacer. Probably pretty poor climb on a Super Cub.
    Dec 2016
    Canyon, tx
    531
    + or - 2200ish rpm static with a 58 pitch and you won’t have to worry about your skirt blowing up on TO. (Narrow deck 320 and -12 however)
    3,111
    FWIW the O-320 STC for my old C150TD called for a 74x58 Sensenich.
    Too much prop IMHO.
    I ended up with a new one, pitched on the strong side of 54.
    Much more satisfactory.
    As far as climb vs cruise goes,
    I'd rather be a few minutes late than a few feet too low at the wrong time on climbout.
  1. Oil Quantity Loss
    By clouds in forum Cafe Supercub
    Last Post: 11-20-2009, 06:59 PM
  2. Loss to Alaska
    By mit greb in forum Cafe Supercub
    Last Post: 07-13-2004, 02:07 AM
