Results 1 to 26 of 26
Thread: Carb Airbox Repair....
    Feb 2018
    5
    Hi All,
    I'm slowly picking away at some issues discovered with my newly acquired J-3 Cub. I decided to pull the carb. and send it to Uni-Tech for rebuild as it seemed to be leaking fuel on the hangar floor not related to the primer. Anyway, after removing the airbox, I found that the shaft is very sloppy due to wear. I see that Wag Aero has a rebuild kit that adds riveted end plates holding bearing and a new shaft. What I don't get is that the butterfly in my existing box is brazed to the shaft and cannot be (easily) removed. How are you supposed to attach a butterfly to the shaft included in the rebuild kit? Any other ideas for fixing my current airbox?
    Thanks!
    John M.
    55-PA18A's Avatar
    Dillingham, Alaska
    642
    Not familiar with a J-3 air box and how it might be different from an 18's air box, but isn't the butterfly just a piece of metal? Make a new one. Or, send to Atlee Dodge in Anchorage. They used to rebuild air boxes. Maybe they still do.
    Jim
    nd
    3,610
    show us a picture.
    SchulerJL's Avatar
    Aug 2009
    Peoria, Illinois
    582
    Give Randy a call, outstanding work on Carb Air boxes
    RANDY RUBBERT AIRCRAFT MAINTENANCE AND REPAIRReynolds, North Dakota
    (701) 847-3008
    1850 2nd Ave NeReynolds, ND 58275-9477
    Likes phdigger123, Mattpeed liked this post
    11,055
    Quote Originally Posted by SchulerJL View Post
    (701) 847-3008
    Randy does fantastic repairs on air boxes. Would be my first, second and third choice.
    Likes 12Geezer2, Mattpeed liked this post
    3,190
    A buddy of mine sent his C180 airbox to FA Dodge years ago,
    came back looking *better than new*.
    But $$$$$$$$$.
    aktango58's Avatar
    18AA
    9,301
    Air box and tailwheel...
    What does Bill Duncan say about tailwheels: they get ignored until they are gone.
    The importance of it, and the limited care they get for an often flimsy pice of metal, not hard to have them come back 'better than new'.
    Marty57's Avatar
    Jan 2005
    Nipomo, Ca
    1,406
    Give Lycon in Visalia Ca a call and see if they have what you need. When they showed me around last year, they had a pallet box full of air boxes they received when they bought out Greek AF inventory. They told be they would sell the air boxes if some one needed the parts and to give them a call.
    Marty
    N367PS
    www.marty2plus2.com
    3,190
    I think Wag or Spruce or Univair sells complete airbox assemblies.
    Dunno if PMA'd or not.
    I kinda recall they were similar if not identical to my old C170 airbox.
    algonquin's Avatar
    Apr 2013
    Seldovia,Ak
    1,030
    If the box for the C-180 was for a 53 or 54 they are very special and have a SS plate. I understand only one company makes the part and a new airbox is around $10,000.00 or so I've been told. This is second hand infro. So take it for what it is.
    WhiskeyMike's Avatar
    West Boxford MA
    940
    There are very specific requirements about the rivets and placement in air boxes. If it falls apart, the engine can easily quit. Use a good, reputable rebuilder.
    Aug 2017
    4
    Agreed.
    4,139
    Broke right where the reinforcing plate stoped. Got an almost new one the next day from the Hampton fly mart. Perfect timing
    flyrite's Avatar
    Mar 2013
    Lyons,GA
    505
    Quote Originally Posted by ezflyr View Post
    Hi All,
    Thanks!
    John M.
    John, just did the rebuild with the kit that you referenced. Not a hard job at all ,you will need to grind the brazing from the butterfly that attaches it to the bolt . As well as grind off the ends on the outside of the box that the bolt goes through , you won't need those anymore.
    Eferr's Avatar
    Aug 2018
    ID
    37
    Hoping to revive this. I seem to have lost a bearing on my carb airbox. I know there are repair kits for continentals, curious if I could just buy a kit and jimmy-rig the bearing onto the shaft of mine
    Cub Special Ed's Avatar
    Oct 2016
    MT/SD
    519
    Just had mine worked on by ted miller at black hills areo in spearfish sd.
    jrussl's Avatar
    Jul 2005
    Madison, WI
    564
    Check with Randy Rubbert.
    He or his son Logan did mine and it came back looking like new.
    (701) 847-3008
    1850 2nd Ave Ne
    As others have said, don't skimp on the airbox. Ingesting a piece of it into the engine might ruin your day.
    Jeff
    Likes Mattpeed liked this post
    flyrite's Avatar
    Mar 2013
    Lyons,GA
    505
    when you order a rebuild kit, it will come with two new bearings. The only part that is a little bit tough, is grinding the brazening loose from the rotating arm And then re-tac’n it backup inside the box itself everything else is very easy.
    12Geezer2's Avatar
    Jan 2006
    Eau Claire, WI
    1,086
    Quote Originally Posted by jrussl View Post
    (701) 847-3008
    1850 2nd Ave Ne
    Jeff
    Yes indeed---The Rubberts have YEARS of experience and really do an excellent job.---geezer Dan
    Eferr's Avatar
    Aug 2018
    ID
    37
    Soooo, I ended up sticking a rubber grommet in there. It fits like an f-ing glove and Iím gonna go ahead and call it a win at $0.15 fix. Figure Iíll have to be proactive and change it out in a couple years. I mean, whatís the worst that could happen?
    11,055
    Quote Originally Posted by Eferr View Post
    Soooo, I ended up sticking a rubber grommet in there. It fits like an f-ing glove and I’m gonna go ahead and call it a win at $0.15 fix. Figure I’ll have to be proactive and change it out in a couple years. I mean, what’s the worst that could happen?
    The engine could eat that O-Ring....or maybe something more important.
    windy's Avatar
    Dec 2005
    Utah
    706
    You can get brass bushings from McMaster Carr Aero that would be better than a rubber grommet that could get sucked into the engine
    Likes phdigger123 liked this post
    nd
    3,610
    rivet one of these bearings on before a oring.
    https://www.aircraftspruce.com/catal...clickkey=44327
    10,513
    The air box is subject to all of the vibrations an engine can generate which is why they wear out. You do not want to risk doing anything with something which could work it's way loose. If something as small as a screw or nut gets sucked into the engine, you will be extremely lucky if it just blows through and out the exhaust. It could get stuck under a valve or bounce around between the piston and cylinder head. If it jams an intake valve open, the engine could stop RIGHT NOW ! Just one intake valve being open can stop an engine. Been there, done that, in a Comanche.
    Your rubber grommet could get stuck under a valve.
    19,963
    The Continental box repair kit fits the Lycoming. I would be concerned about sucking that grommet into the engine. Should be able to braze a bushing in there.
    Thanks Eferr thanked for this post
    Eferr's Avatar
    Aug 2018
    ID
    37
    Ordered the o-300 repair solution. Hereís what The grommet looks like. It is a perfect fit, but the point is well taken.
    Likes skywagon8a, wireweinie liked this post
  1. Repair Kit Lycoming carb heat/air box
    By scubber in forum Super Cub Sick Bay
    Last Post: 11-21-2012, 12:05 AM
  2. carb heat airbox, where to buy
    By M1 in forum Super Cub Sick Bay
    Last Post: 04-14-2008, 09:40 PM
  3. Carb heat box repair
    By sekps in forum Cafe Supercub
    Last Post: 12-30-2003, 04:23 AM
