Results 1 to 18 of 18
Thread: Cannon Connector?
    Canada
    32
    Cannon Connector?
    Would any of my fellow members know the part number of the cannon connector that is in this picture?
    It is most likely a 4 pin (knowing 4 wires need to be connected) but I am struggling to find an accurate part number that will get me on my way to purchasing the correct assembly.
    Would anyone know where to purchase theses particular connector units?
    Thanks for your help.
    Cubnut
    2,572
    Unscrew the connector. There will be a part number on the skirt and/or molded into the rubber between the pins. If you have problems translating the number, give me a shout.
    Canada
    32
    Thanks. The picture was taken in Oshkosh in order for me to look at layout and such and never took note of that level of detail.
    I donít have a connector to check at the moment.
    Cubnut
    2,572
    What is the connector for? Do you just need a connector or do you need THAT connector?
    Canada
    32
    The connector is for seasonal quick connecting/disconnecting when the amphibs are installed and removed, possibly seasonally. Ease of use.
    Preferably similar function as above.
    4 pin
    Socket
    90 degree end
    Shallow - Flush type mount (on aircraft)
    Solid and able to withstand all weather elements
    Cubnut
    2,572
    Just for the warning lights or does it need to power a hydraulic pump?
    Canada
    32
    Gear position lighting 2 up and 2 down per side
    2,572
    I'll get back to you in a day or so with part numbers.
    Canada
    32
    Thatís great! Thank you very much.
    Cubnut
    Iflylower's Avatar
    Aug 2008
    Memphis, TN
    1,350
    I had that connector on my fluxgate on the 195
    Iflylower's Avatar
    Aug 2008
    Memphis, TN
    1,350
    Found it. Says AMP 206705-2 on it. 9 pin. Very stout.
ID:	35352   Click image for larger version.
    2,572
    That connector is made of composite materiel and is to large for this application. It's the same one Electronics International uses on their small gauges. He needs one of the smaller, metal, mil-spec, connectors.
    moneyburner's Avatar
    Mar 2003
    Western Washington
    958
    Likes windy liked this post
    2,572
    The best for this application would be an MS3472W10-06S for the belly and an MS3476W10-6P for the pigtail connector. Alternatives are MS3470 instead of an MS3472, as it will just be a smaller footprint (harder to put the hardware on). The 'W' for the olive drab finish can be replaced with an 'L' for stainless finish or an 'A' for black anodized finish. Use an M85049/31-10W (or L or A) grommet nut on the MS3472 connector as it will give max clearance for wires, between the connector and the floor. Use an M85049/52-10W (or L or A) as the 90* backshell for the MS3476 connector. Both of these have (6), 20 gauge size, crimp type pins/sockets and can be used indefinitely with a little care when extracting the pins and sockets.
    If you insist on using solder type connectors (not recommended) use an MS3100A14S-2S (smaller) or an MS3102A14S-2S (larger) for the belly. You'll probably need to leave the backshell off for clearance. Use an MS3108B14S-2P connector with an MS3057-8C strain relief for the pigtail. These will work best if you pot the back of the connector with some type of silicone compound to help seal out the weather. These are 4 pin connectors but are in a larger 16 gauge size as 20 gauge sizes are not available.
    Canada
    32
    Thank you for all your effort. I will check into these part numbers and seek availability. Great information, looks like what I need.
    I want to thank you again for helping me out!
    2,572
    No problem. Let us know how it works out for you.
    Thanks SJ thanked for this post
    18,832
    On a Wip install.
    Canada
    32
    Thanks Steve.
    Thatís what I need the connection info for....a wip install similar to what you have in the pic.
    Thanks for the helpful pic!
    Cubnut
  1. Cleaning Cannon Plugs
    By S2D in forum Tips and Tricks
    Last Post: 11-28-2016, 09:22 PM
  2. Silicone Induction Connector Hose C-90
    By Grant in forum Super Cub Sick Bay
    Last Post: 08-17-2015, 02:53 PM
  3. Hand Cannon Holster - Alaska
    By Barnstormer in forum Sportsman's Den
    Last Post: 11-22-2014, 03:20 AM
  4. 6-pin Lemo connector
    By Brent Bostwick in forum Products, Purchases, Reviews & Prices
    Last Post: 01-22-2007, 11:18 AM
