Page 2 of 2 FirstFirst 12
Results 41 to 57 of 57
Thread: Grove 10" wheels/8" brakes for 35 ABW and 31 Desser
  1. #41
    Dec 2007
    alaska
    19
    did anyone get a close look at the beringer wheel/tire combo at the trade show? The disc actually floats on the rim held in place by 40 or 50 tiny bolts.
    Still looking for interested folks for the Grove 10" rim by 8" brake. we need a couple more commits to order.
    Again this is a simple R&R setup. remove your 6" wheels/brakes and install the 10" wheels/brakes. better brakes, lighter, simple
    Thanks Bender thanked for this post
  2. #42
    Dec 2007
    alaska
    19
    need one more taker to get these made.
    Likes Bowie, N9PW liked this post
  3. #43
    Schwarz's Avatar
    Oct 2016
    Abilene, Texas
    47
    Interesting discussion, OP thanks for starting it. Always planned on doubling up the calipers on my 185, but sold it before I did.
    I will be installing the Beringer 10" wheel and 10" brake system on the SQ2 as soon as it becomes available. Looks like they are mounting the caliper up top so that should eliminate any tire rub.
    I'll also be installing their master cylinders and parking brake (which I don't currently have).
    http://www.beringer-aero.com/en/file...-supercub-.pdf
    Hey Phil, any idea when these are going to be available?
    Thanks, Wes.
  4. #44
    Mauleguy's Avatar
    Aug 2002
    674
    A much simpler solution would be to machine a brake disc that mounts to ABW wheel and uses the outer bolt pattern, you need that larger bolt pattern to transfer the energy for the larger brake disc. Much cheaper option then spending 3K for a set of wheels that already are being made and on lots of airplanes. The torque plate could be included and still be a fraction of the cost. Use the calipers you have now like Mike says.
    If there are enough people interested Airframes may even be willing to look at the modification.
  5. #45
    Dec 2007
    alaska
    19
    I made the assumption that if using an 8" disc I would need an 8" caliper. Has anyone out there ever mounted a 6" caliper on an 8" disc? I guess it could work but it just doesn't sound right. It would wear a bit different but I suppose it would work. Anybody done It??
    I think engineering and machining that 8" disc (and the torque plate) to use with the 6" caliper may be expensive too.
    I"m building right now and have a set of 6" wheels and brakes. I'm getting the 35" tires and was exploring options for 10" wheels with bigger brakes without re-inventing the wheel...... If anyone could comment on the possibility of getting a disc engineered lets look into it.
    $2200 for the ABW wheels
    $3000 for the grove wheels with bigger brakes/calipers included
    I haven't purchased the ABW wheels yet so the cost for me would be $800 minus what I could get if I sold my 6" wheels/brakes.
    Grove is making similar wheels right now. these would be a bit narrower (and lighter) to accommodate the 35" ABW tires.
  6. #46
    Aktahoe's Avatar
    Sep 2010
    Truckee, Alaska
    253
    The Groves made for the 6" wheel is the exact same as the ABI or Cleveland's. They also work on the 10" wheel perfectly. I literally just went through this. The aluminum brakes however are lighter by a lb each. Magnesium corrodes much easier.
  7. #47
    Aktahoe's Avatar
    Sep 2010
    Truckee, Alaska
    253
    Those are the 1 3/4 double puck Groves that were on the 6" rim with 31's. There now on the 10" rim with 35s. There great!
    AKT
  8. #48
    Mauleguy's Avatar
    Aug 2002
    674
    AKtahoe, I don't think this is what the thread is about unless I am reading your post wrong.
    cub-size12, I know that the 6" caliper will work on the larger 8" disc, I have seen it done. Price is going to be a factor for you because I would not be interested in making the parts for 800.00 but if enough people wanted this mod I think the price could get down in this range.
  9. #49
    Dec 2007
    alaska
    19
    aktahoe
    its good to know I have a fallback plan for my 6" grove brakes. Now I know the ABW disc on the 10" rim will fit the grove calipers. Did you have any modifications or was it a plug and play? thx
    Mauleguy
    exactly, trying to cobble things together can be a long road and bumps can get expensive. With the Grove setup it is "off the shelf" and makes replacing broke parts easier and quicker.
    My intent here was to find out if there was any interest in an alternative with bigger brakes. We will see 8" or 10" brakes eventually. I just don't have a warm fuzzy with the beringer setup. They make a very nice looking setup, but what works good on the track may not be the answer for the sand, rocks, stumps and bumps. If I can get this through and word gets around I think guys will start to see the benefits. we are experimental which is very liberating.
  10. #50
    Aktahoe's Avatar
    Sep 2010
    Truckee, Alaska
    253
    Quote Originally Posted by cub-size12 View Post
    aktahoe
    Mauleguy
    It was plug and play. Very simple. Here's a pic of the Groves that we're on the 6" rim now on the 10" with 35's. Also shown is the ABI set that I ordered thinking my Groves would not work.
    Grove and ABI
    Clevelands on the 180 with 31's - with Grove ABI. Picture makes the Grove look a bit bigger but there not.
    Anyhow sorry to drift here.
    AKT
  11. #51
    5,129
    It’s plug and play because both wheels share the same torque plates. Enlarge the disc diameter and that’s no longer true.
    Likes Aktahoe liked this post
  12. #52
    Mauleguy's Avatar
    Aug 2002
    674
    The reason I mentioned if enough people were interested I am sure someone like myself could machine a kit that would be a plug and play with all the Alaskan Bushweel 10" wheel kits that are already out there. In my case with the experimental Maule A.K.A. Bushwacker I probably would not mind having a bigger brake disc.
    On cubs/carbon cubs etc. I am not sure it would be a good thing for most people, you would probably see a lot more cubs upside down because of the extra braking power. I have not flown many cubs that I think boy I wish I had more braking power!
  13. #53
    Dec 2013
    Maryland
    31
    I’ve been on waitlist with grove for these for a few months now. Any updates on timeline or is there still not enough demand?
    Using Tapatalk
  14. #54
    Dec 2007
    alaska
    19
    Quote Originally Posted by N9PW View Post
    If anyone interested is this set up please send me a PM so that I can coordinate with Grove for the purchase
  15. #55
    Dec 2013
    Maryland
    31
    Count me in. Flo knows I’m looking for a set. I have their “10x10” setup my 29” ribbed airstreaks, so looking for wheels, rotors, and 1-1/4” torque plates to step up to 35s.
    Using Tapatalk
  16. #56
    Jul 2015
    1
    Interested. Sent you a pm
    Mike
  17. #57
    Dec 2013
    Maryland
    31
    Mine showed up last week!!!
    Using Tapatalk
  1. Grove 8" wheels
    By dirthog4 in forum Cafe Supercub
    Last Post: 06-15-2017, 08:38 AM
  2. Grove Wheels & Brakes, Desser 850x6 Tires
    By wjohnson720 in forum Products, Purchases, Reviews & Prices
    Last Post: 05-22-2017, 01:07 PM
