Straight tail ski
spinner2
Montana
I have a dedicated 3200 tail wheel for Burl’s tail ski. When I put the skis on last month I found my tail wheel needed some maintenance. Not wanting to miss some ski flying time I removed the wheel and made a filler plate from .050” aluminum.
I took care care of the wheel problem last week and reinstalled it in the ski. I flew with it yesterday with the wheel in place and I sure noticed a difference in drag. A straight tail ski is like a free-castering tail wheel. Until you try it you don’t realize the difference.
It it has been at least 10 years since I flew without a tail ski of any kind so I don’t remember well what that was like. But I do remember that a tail ski was better.
Who knows maybe I will remove the wheel again? If I were to do it all over, I’d make the plate out of .125” UHMV.
This floor creeper worked well for moving it in and out of the hangar.
I cut cut a piece of 1/2” conduit to slip over the axle bolt so the nut could be tightened up snug.
It'd be pretty simple to make a plate that would slide in place under a deflated tire and would be held in place my reinflating the tire. Schneider skis used that method for their penetration skis, and Schneiders needed it.
Also and a skag of some type for better steering. When my 90 Cub was outside all winter I had it on straight skis with a Landis 250 tail ski (dish with a skag) which helps in taxing and taking off in deep snow with the small engine Cub.
No doubt that a straight tail ski will slide a bit better early on than a penetration ski, but the real key is to get that tail up out of the snow quickly. If you can live with a straight ski on the tail, that’s great.
Nice job ,keep us advised how it works in the field. I made my own too, heavy aluminum, and bronzed bushed small side pedestals. Used cable wire safety retainers just like you would on main skii. will try and post a pic
I like that idea. Wondering though if Burl's ski was low enough to allow a plate to slip between the ski and an un-inflated tire, I got down on the floor creeper and took a look. Nope. The rim of the wheel is about 1/4" above the ski surface. Not enough room to work like that.
Bummer. I’m busy enough that I haven’t installed my skis on the 180 yet. I’ll compare how the BBW version looks in that same profile. I think the BBW vesion has less drag in the snow so maybe that’s your answer. Its only money! 8)
Bob, I thought I would add a skeg if I go back to the plate. Maybe one from UHMW with a bit of width so if it drags on the asphalt it'll wear fairly well. I'm sure I won't make anymore changes this winter.
Mike, as you know, take-offs with skis is an AOA game and there's a sweet-spot between getting the the right angle and avoiding drag with the tail. That's where I noticed the big difference with the straight ski. With the tail wheel and the penetration hole in the ski, dragging in heavy snow, that sweet-spot window narrowed considerably.
