Results 1 to 16 of 16
Thread: PA18 lower Cowl support rod
    24
ID:	34431Click image for larger version.
    I am as you can see hopefully finishing up on a 10 year project. Currently working on attaching the carbon fiber cowling, all seems to fit well, but the instructions for the cowl call for attaching lower cowl support arm. I scratch built this plane from northland drawings, and found a support rod at Univair, but have no idea how it attaches to the cowl. I called the cowl maker and he said he thought it went from an exhaust pipe to the lower channel of the lower cowl opening for the door. It holds the cowl in the correct vertical position. I did not think it a good idea to attach an engine part to the cowl. If some one has a picture of this and how it attaches, it would get me started again.
    BC
    11,357
    clamps on engine mount, then to the lower rails about 15 inches forward
    Nov 2002
    Fargo
    728
ID:	34434Goes from the engine mount to a bolt through the lower cowl channel
    9,300
    In the picture there is a silver brace to the exhaust pipe from the header- that one supports the exhaust.
    The brace you ask about is behind that and horizontal, black in color, and connects to the engine mount just below the muffler and crosses forward and attaches just under the forward heat muff.
    24
    Thanks all, I zoomed in on the picture and saw the black tube you are talking about. This is a one piece lower cowl and does not use the rails. Will have to make up something to attach to. Still it does not seem at the angle it is, that is would help much vertically, but will try it.
    BC
    10,477
    That black tube would be more effective if it were attached further up on the engine mount in a more vertical position. It is supposed to be supporting the down loads of the cowl. The one in the picture is not doing that.
    Bill Rusk's Avatar
    Sandpoint, Idaho
    5,339
    There is a picture and a tip here (it is the sixth picture down)
    http://www.supercub.org/forum/showth...l=1#post686232
    Hope this helps
    Very Blessed.
    Nov 2002
    Fargo
    728
    I agree that it would have more strength up higher but with the thrustline mod it would push the nosebowl down without cutting the tube shorter.
    S2D's Avatar
    Montana
    4,207
    Quote Originally Posted by PA-22/20-160 View Post
    Guess that's something Mark should include with his STC.
    Doesn't look like its doing much there.
    Thanks AkPA/18 thanked for this post
    5,429
    Here’s a view of mine. The engine mount is stationary so it’s a solid attach point. I’d like to hear more about your composite cowl.
    2,103
    SK2
    Adjust the clamp on the engine mount to fit cowl as needed. I agree more vertical is better.
    Thanks 62E thanked for this post
    Nov 2002
    Fargo
    728
    I looked back at some other pictures of installs I've done over the years and it looks like I've alway had the brace parallel with the exhaust pipe going into the muffler. Looked at the other side and it has a more appropriate angle so it looks like I'll have to go freeze my ass off tomorrow and get that adjusted so I can sleep better.
    Nov 2002
    Fargo
    728
    Mark could spell it out word for word and not that he didn't but the world would just make a better idiot and make it null and void anyways.
    19,897
    I have never cut the lower cowl rail support rods on any of the Thrustline modifications I have installed.
    This is my airplane.
    One I am building
    24
    I completely understand now what is meant by lower cowl support. Thanks for all the replies and photos. the carbon fiber cowl is from Selkirk Aviation, very nice workmanship, great customer support, but the instructions they send along with the cowl assumes you are replacing an aluminum cowl, not building new. They list the weight of the total package at 12.5 lbs. You receive the cowl primed, and ready to paint.
    Thanks again Bruce
    Nov 2002
    Fargo
    728
    Only -26f outside this morning but I was able to fix without having to cut anything, only had to re-shim the latches.Click image for larger version.
  1. Lower tail brace support bracket help AD 81-06-08
    By Alaska_Rallyer in forum Cafe Supercub
    Last Post: 07-20-2013, 06:44 AM
  2. Cowl Support
    By C-YQK in forum Modifications
    Last Post: 02-26-2010, 08:25 AM
  3. Jack screw lower support
    By Marty57 in forum Experimental Cubs
    Last Post: 04-20-2006, 10:53 AM
