Results 1 to 24 of 24
Thread: Steve's booster brakes
    WindOnHisNose's Avatar
    Lino Lakes MN (MY18)
    4,585
    After much research we installed Steve's booster brake cylinders several years ago. Recently, in cold weather, Santa provided a PIREP indicating that he had absolutely no braking action on the right brake, not great braking on the left. I took a look when he returned the Cub and found really low brake fluid levels in both brake cylinders.
    I was planning to venture to the hangar to bleed the brakes but Steve Lewis recalls reading that there has been a problem with the O-rings on Steve's brakes and that new O-rings need to be installed.
    Before I proceed I would like to hear from you folks as to your experiences with this. Your input is greatly appreciated. I did a search of threads here and couldn't find useful information that might address this.
    Happy New Year!
    Randy
    Likes cubnut liked this post
    Aug 2002
    277
    Happy New Year Randy,
    I have Steve’s boosters on the 12 for about the last 8 years with zero problems. I have never heard of an o-ring problem. Only problem has been caliper piston o-rings.
    Mark
    Thanks WindOnHisNose thanked for this post
    4,585
    Mark, thanks for the reply! How did you determine that the caliper piston o-rings were the problem? Probably a stupid question.
    Randy
    Aug 2002
    277
    The brake pedal would go right to the floor and some brake fluid on the bottom side of caliper.
    I believe Dakota Cub brakes had a o-ring problem. The o-ring was getting cut on a machined port.
    Mark
    geoaspen's Avatar
    Nov 2007
    Snowmass Vlg CO
    139
    I have Steve's boosters and Cleavlands on my PA12. Never a problem with the boosters leaking, but I allowed the brake pads to wear enough (don't ask) to allow the pistons to out run the barrel at the brake end. By the time I realized what was happening, I had issues with a landing thresh hold light.
    21,305
    You still need to check the fluid level annually and top off the reservoirs.
    Likes mike mcs repair, bob turner liked this post
    Rick Papp's Avatar
    Bristolville, Ohio
    757
    Randy, I would give Steve’s a call. It seems that several years ago I replaced some plunger and gasket parts in the booster assembly due to some design flaw in the angle that day push into the cylinder. I could be wrong because it was a few years ago and my memory aint as good as it used to be. Rick
    Never stay level!!!!!
    10,869
    Randy, in Doctor speak what Steve is saying is that even though the ultrasound says it's a boy you still need to turn them over when you deliver them and check the hardware before filling out the birth certificate.
    Likes WindOnHisNose, siegel185 liked this post
    White City, Oregon
    967
    The only part that is inside the master cylinder that can have the potential to fail is the Stat Seal... I can count on one hand how many of those have failed and every one has been due to user error or installation... Several years ago we did a design change to the main shaft and made it into a two piece design... I sent out service kits to every unit I had on record with instructions to change out the shafts... it also came with a new piston and o-ring but we wound up going back to the original piston design...
    I think mmr hit the nail as to your potential problem as being at the calipers... Especially since you have stated that your reservoirs were very low with fluid... check the calipers, change out the o-rings there, check your pads and re-bleed the system..
    For anyone that has parking brake valves installed on the master cylinder, one quick test you can perform is to hold the brake valve closed with one hand and depress the brake pedal with your other hand... the brake should come up solid almost immediately... if not, or it bleeds down, then that before mentioned stat seal is bad... if it locks up solid then you have a problem beyond the master cylinder...
    As always, call me if you have any more questions..
    Brian..
    4,585
    Thank you, Brian. I will be in touch. Have a great New Year!
    Randy
    7,638
    I occasionally have leak or air problems with similar master cylinders. One Cub was always low - I could find no leaks anywhere. Replaced gear legs (fabric problem) tightened all fittings really good, and now I am on the six month check-the-fluid routine. Fixed!
    One insidious problem - there have been a couple Cubs that I could not bleed with reservoir systems. I even set up a simulator to see what I was doing wrong. Only thing I could figure is somebody put an expansion loop in the gear leg. Bleeding is usually trivial!
    2,517
    Caliper rebuild is pretty simple, I heard of a pilot that left the inner pad off the caliper when he put it on and noticed the no right brake thing on testing. Once caliper is off, wrap with rag and use small blast of air to get pucks out. Clean bore and new o-rings put it back together. Airframes has the o-rings, order extra set in case you screw up.
    White City, Oregon
    967
    Stock brake lines are a pain... I really like using one stainless braided line from the master all the way to the caliper... only two points to leak from instead of up to 6 or more...
    Put one of my cylinders in a Tri-Pacer recently... usually they are not that difficult to bleed out but this thing fought me for two days... wound up replacing several hard lines due to bad flares and fixing the wheel calipers...
    For those unfamiliar with the Tri-Pacer they use one SCOTT master cylinder that is tee’d under the aircraft and runs both main gear calipers... the master cylinder is operated by a Johnson bar and cable under the dash..
    Brian
    Penguin's Avatar
    Jul 2012
    KNFL
    141
    Hey Brian - if you happen to see this...
    Your kit arrived last week and is going in this weekend. So far, it's awesome. Thanks! When I was researching a few weeks ago I was able to find some good quality pictures of both the remote attach for the reservoir and method of pushing the reservoirs forward by using the 2x 90 deg AN fittings. I am prepared to do either, but can't seem to find those pictures now. I think they were here, but am coming up empty. Do you (or anyone here?) have pics of either?
    White City, Oregon
    967
    Yep…
    On a Cub…
    Same concept but on a Tri Pacer to clear the cross tube…
    Thanks for the feed back..
    Brian
    Penguin's Avatar
    Jul 2012
    KNFL
    141
    Brian thanks so much. Any chance of one or two showing a remote mount with tubing? Sorry to bug you. These are super helpful.
    White City, Oregon
    967
    Just a few… from a couple PA-22 install’s…
    Brian..
    ATP, CFII, A&P sdischer's Avatar
    Dec 2019
    COLLEGE STATION, TX
    144
    If I could hijack this thread for a moment. I’m planning to install Steve’s boosters and I am wondering if there are any tricks to install new braided stainless steel lines without cutting the fabric off landing gear? Are there any clips I could use to run them on the outside of the fabric or can they be threaded through the existing fabric without being secured inside (I am thinking no to letting them “flop around” in there)? How have others done this?
    21,305
    You could do like this guy but looks pretty amateurish to me. I would just use beaded from the master cylinder to the gear leg and if needed, bottom of gear leg to the caliper. There are Weatherhead to AN adapters.
    Likes DENNY liked this post
    21,305
    Like this.
    Dec 2019
    COLLEGE STATION, TX
    144
    I am thinking the copper lines in my gear legs won't handle the pressure.
    White City, Oregon
    967
    Quote Originally Posted by sdischer View Post
    Unless the copper lines are compromised they should more than handle the pressure... I have done the same as Steve Pierce on a couple of installs... The Adapter fitting is an Aeroquip part from Summit racing. Part number FBM 2930
    Brian.
    Thanks sdischer thanked for this post
    Likes sdischer, Gordon Misch liked this post
    Crash, Jr.'s Avatar
    May 2015
    Anchorage, AK
    747
    I was able to source the weatherhead adapters through the local Napa. They're used on old copper brake lines on antique cars/trucks. 252x4 is the part number I used. That's 1/4" inverted flare female to 1/8" NPT female. Allows for a standard flare nipple to be threaded in and Aeroquip brake lines to be hooked up.
    As far as copper brake lines I did a bunch of math at the time and looked up different copper line bursting strength. With the North River boosters I figured out you could theoretically burst the lines but you would have to exert several hundred pounds of pressure at the brake pedal. Not at all realistic. With my 75 year old copper lines I've had no issues.
    Likes sdischer liked this post
    Dec 2019
    COLLEGE STATION, TX
    144
    This all sounds like good news, easier than I thought.
    Here is a possible solution in one fitting: https://www.pegasusautoracing.com/pr...SABEgIK3PD_BwE
  1. Booster Brakes
    By jrussl in forum Modifications
    Last Post: 11-30-2008, 10:39 AM
  2. Question: Bodell Wheels & Steve's Booster
    By scubber in forum Super Cub Sick Bay
    Last Post: 10-20-2008, 11:08 PM
  3. Steve's Vented Brake Booster
    By Steve Pierce in forum Modifications
    Last Post: 06-05-2005, 06:57 PM
