The big dorsal was part of the factory float kit on J and K models. You should also have a rudder centering system in there.
Can you tell from this photo? It has a vee brace above the glare shield. 77 180K
Also on the doubler about a foot behind the repaired bottom skin you can see the factory installed bolt holes for the rear float fittings. This one has never been on floats since there are only two holes. It should have the V brace which came with it which may or not have been installed at the factory. Installation was a factory option. On those which were not installed the parts were stowed in the plane upon delivery.Can you tell from this photo? It has a vee brace above the glare shield. 77 180K
The V brace is installed.
No. I read that thread. Think the seller priced it way too high initially. He is asking $120K now.Eddie, yes that same plane was mentioned as being for sale with fresh paint on this site back in 2011. Has it been painted again recently?
That is not a LIGHT plane, nor will it feel like a sports car.
That is a heavy hauler, will perform ok, treat you well. If you are looking for a short strip plane, one that you can dance with like the cub, that is not it.
Those girls are a truck plain and simple. Load it up and go. But you will need arm strength to fly her.
I'd have said it's "that new retract mod.".It got the right wing.
EOW 1863 Full IFR and autopilot, -50 engine
Pics are post repair and pre paint.
With the right prop, good brakes, big tires, and a couple of hundred hours of practice that plane should do fine in and out using 500' at mid weights. Does "using" 500' mean a 500' strip with no runout? Probably not. Will it feel heavy? Mine doesn't unless it's loaded heavy. Late model Skywagons are great airplanes.
