Therapy Project
RVBottomly
PATRON
Therapy time for me. I’m a sole-practitioner public defender and this has been an extraordinarily hard year. I just finished up a very hard trial and have another in 4 days. As I mentioned in the “Cry for Help” thread, I’m working to scaling back all of this in the coming year. I intend to divert some of that energy into building an airplane.
So, after agonizing, reading, ordering, and reviewing plans, (including shortwing disks and Northland Supercub drawings, etc.), I followed the suggestion of jimboflying and others--I ordered some materials from Wicks and started building tail feathers.
I’m pretty much settled on a Wag Aero 2+2. Many thoughtful people encouraged me toward a Super Cub, but my wife is fully on board with a side-by-side project. The other fleeting option would be a Wagabond with flaps, somewhat extended fuselage, and an O-233 or even an O-290.
But, I see floats in the future, and the 2+2 obviously is comfortable with those.
I spent 4 hours messing about in the shop and got a start:
I freehand bent the tube around my shop stump:
I already see things I need to change. For one thing, I will be looking for a better torch. My gas welding has come back after 25 years, but the consumer-grade regulators and clunky “all-purpose” torch handle are geared more toward cutting angle iron.
I’ll also improve jig arrangement and probably add some upper-level storage.
But it’s a beginning. Maybe, after next week’s trial, I’ll put together some elevators. And then, wait for more material and do whatever seems good to do next. It’s pleasant in my heated shop, too cold to fish anyway. If I rejigger my world for the coming year, I might even have some 20 hours a week to put into the project.
If you want a first class torch for aircraft ox/acet welding check out the Meco Midget sold by Tin Man tech.
Vic,
Congratulations on your decision and start. Building a plane is only one part at a time. Celebrate each part and then each page completed of the drawings. Eventually there are no more parts to build and no more pages. I too am building a 2+2 which is a PA14 replica. I had an original PA14 and found it to be a great plane. You might consider building a really flat and sturdy workbench to work on. I used floor joists and 2 layers of thick flooring material screwed to the top with 4X4 legs. Mine is 16’ long so you can build the fuselage straight and true. I also second the Meco torch but you might consider Tig as well. The money you save by building your own will justify lots of new tools. Good luck and keep us posted.
Here is something similar to what jimboflying is describing. Mine is 18 ft long. I use 3/4 particle board and change the top occasionally. Particle board is flat and cheap.
Vic,
Thanks for the encouragement. I'm working on a flat and sturdy platform with locking casters to move it around. I built a "strongback" on my boat project 2 years ago, and I still have material from that. I still need to organize space a little.
I see all sorts of people endorsing the Meco torch, from you and Cub Junkie and Christian Sturm. I'm leaning that way, even without trying one out.
I like how you've clamped things down. Looks very tidy.
buy a Tig, with a finger controller.....
Right. I should get with the late 20th century. But I'm curmudgeonly smitten by the therapeutic value of the gas-torch-weld-puddle-dance. It's sort of like an old guy trying the hula hoop. At least until my hands go too numb and my back gets too stiff.
Vic
Vic[/QUOTE]
Tig uses the same puddle dance. Instead of having flammable gas, you have one intert gas- plus the torch tip is quicker to clean if you have a belt sander.
Well, yeah. You and Mike and many others speak truth on advantages, but I have to look at my own nature. If I get one of these TIG gadgets, next thing happening is I'll want to do a bunch of pretty welds, which will lead to starting on custom intake manifolds for some hot-rod I don't own, which means a bigger shop, which means the airplane won't get done....
Etc....
Therapy is good. J'approve.
Merci! Et je suis d'accord.
Vic
Welcome aboard!
I have a Meco with a variety of tips and I use the light weight hose that really cuts down on arm/hand fatigue. You certainly need a TIG for steel and aluminum and I find I use my Lincoln 180 MIG a lot too. Sometimes just to make a quick jig or whatever and I don't feel like fooling with gas or the TIG. MIG be quick and only takes one hand. You need foot and finger control for the TIG. Also, go into the kitchen and steal the old cookie sheets to put between the tube and the wood when your welding on top of the wood. Also, paint your table top flat white...makes things easier.
Thanks for the welcome, Lowrider. I've enjoyed reading about your project.
But I'm supposed to get a MIG, too? It took me 30 years of Lincoln AC buzzbox welding before I could finally convince myself to get a used Miller AC/DC stick welder. I'd been wanting one of those since high school and finally got one a few years ago. For me that's a quantum leap!
As for the cookie sheets, it would be a major challenge to pry those from my wife's grip. But leftovers of 22 gauge steel from making ribs seems to work pretty well.
No Sir...you don't need a MIG...you can do it all with the torch or the TIG... Buzz box...not so much.
Ref cookie sheets...I convinced my wife the old ones were possibly leaching alum molecules into the cookies and stainless steel would be much healthier and probably make the cookies taste better...worked well...feel free to use it if it fits.
Got through another week. Did some house chores, and got one elevator formed. I was hoping for two, but I remind myself I'm not on a clock for the project. Line by line, here a little, there a little...etc.
I still need to weld up collars and form horn assemblies. I'm waiting on another material order to proceed on that.
And I still haven't ordered a different torch. The Victor-styled medium duty torch works alright for now. All week I was pretty heavily occupied until this morning.
So far I'm learning quite a bit about metal working. The 3/8 tubing bends OK free handed, if you are very careful. The elevator shape could use a bit more fairing--then again, I've seen some pretty odd looking tail feathers at the airport.
Looking good!
Each welder has it's own place- a small Tig like MIller's Diversion 180 will give you a whole lot of options. I bought the finger control after watching gyrations of guys welding inside aircraft with foot controls. Duck taping the controller to your foot just seemed silly when I could be laying down and just flex my finger.
Keep up the great work there, and posting pictures. Should be a fantastic project, once finished fun to fly.
For torches, the Meco or the AW1 are both good alternatives. Try wheat works in your hand. I use a couple 1940 vintage Smith #2 torches, one was my grandfathers, the other I got on eBay recently with a bunch of “V” tips - soft flame for welding aluminum. The #2 is the predecessor of the AW1, but the tips aren’t interchangeable. The super flex hoses make a big difference in hand fatigue. Check out “the tinman” web site.
I’ve also got an Everlast 210EXT welder for TIG. Some stuff is more natural with the torch, others with the tig. The welding hood is harder to maneuver around in the fuselage than just a set of goggles. Either way, you can do quality welds that will keep your airplane together.
RV
Looks like a great start ! I got along fine with "consumer-grade regulators " but found this torch a "must have" when building my plane .
Doug
I've had my Smith torch since the mid 80's and love it!! I got my powerplant rating at Watertown, SD where they're made. One of my classmates' wife was a demo-welder for Smith back then... she could really weld with a torch!! We all ribbed Randy about not being as good as her.
At any rate, you'll love the Smith! Small, handy and still big enough to do what ever you need done!
Thanks dga and John. I found out one of our local weld supply shops carries Smith in stock. I'll take a look at one when I get a chance.
RV
FWIW, You have to decide how much you want to spend both money and time learning to weld........... Oxy-Acet is the lest expensive to get into and isn't too hard to learn. Getting "pretty" welds takes some practice. If I use MIG its only to tack up a project for convenience and use a small Lincoln, .023 wire and teflon liner with small torch. MIG is structurally OK but tends to leave welds unsealed even it the best hands. ....... Your Tube Seal will point this out quick. Gas welding is what I use most and don't see any drawback other than having to clean up more with the sand blasting. Things "move around" a lot more with gas but once you learn it, there are a lot of things you can do to prevent distortion. ....... Plus it's "traditional". TIG is the first choice for a lot of guys but I use it mostly for sub assemblies. For me its too cumbersome for getting around in a fuselage but it sure makes a clean weld. ......... The AW1 "Airline" torch as mentioned before is my preference with 3/16" light weight/flexible hoses. High dollar 2 stage regulators are nice but not necessary. I have tried the real short light weight Victor and a pistol grip Henrob and never use either one of them. So, I guess I would say I prefer gas over the electrics for most airframe work. Maybe its because I pissed on an electric fence when I was a kid and never got over it?? Plus you can weld when the power is off!
smith is what I have too... but the last time i used them to weld was in 2004(still on that same set of bottles..), and that was just so I could remember how to Oxy weld, after becoming spoiled by TIG.... night and day...
RV
I'm committed to gas welding. I learned the basics in the 70s in high school shop and kept it up through the 80s on things from thin sheet metal to plow repairs in the field. The only other welding I'd ever done was stick arc welding, though I played with an electric carbon arc a little bit. I'm happy "relearning" an old skill. I like the review on the Meco, but I'll probably choose the Smith because of nostalgia, if nothing else.
BTW, I was kidding about a MIG. I don't really think I need one. I'm working on reducing clutter in the shop and not inclined to add more equipment I don't need.
But guys like George and Mike keep encouraging me down the road toward TIG. They'll probably eventually succeed, but probably not until I've welded up most of a fuselage. I'm sort of happy reliving my second childhood...at least for now.
As for the electric fence--I've had the exact same experience.
Vic
Slow steps forward. I spent the morning fabricating a rudder horn out of .090 4130 plate. It took a couple of tries--the first time I followed the cut lines suggested by the WagAero plans, and when I bent the tabs, they did not come up parallel with the rudder tube. In hindsight it should have been obvious, but hindsight often is not foresight.
I got my start taking a pdf from the Northland drawings, turning it into a jpg, and putting it into a MS Word document so I could adjust the size. I ended up with a perfect full-size template to lay things out.
Then it was a matter of drilling, bending, trimming, and welding.
In the photo just above the last one, you might notice the horn is on backwards. I started to tack it that way and then had a little alarm-feeling. The drawings don't make it obvious.
But I had bookmarked Bill Rusk's build thread on my phone, so I could look at pictures. Sure enough, there was a sequence of nice rudder photos.
Armed with that information, I ground out the tack and set it right. Thanks Bill! You probably didn't even know how much pain you saved me.
Next step will be elevator horns and bending the 1" stabilizer leading edge tubes.
Shoveled the Christmas snow and had a few hours in the morning. Elevator horns:
After match drilling and before further grinding:
Aligning. It seemed easier using the floor because it was clear at the moment.
Tacking:
The snow is picking up again. I'm going to have to get the little plow going before dark. Therapy project set aside for another day.
Happy New Year! I hung up my new Supercub calendar, had a day off, and spent part of it working on stabilizers.
Well, the plan was to work on stabilizers, but I only worked on one. Things took a lot longer than expected.
And I learned some things, which is good, because I can continue to certify compliance with CFR §21.191 (g) ("undertook the construction project solely for their own education or recreation").
So, I learned that bending 1" 4130 is harder than I thought, even when filled with tamped sand. My first try ended up with a kink despite my efforts at using a nice round curved log. I got the bend pretty close, then I tried fitting it into my tabletop jig. One little extra push...Oops.
So, try again. This time I got it bent pretty close, slowly and in increments, and finished the bending with my new and improved variable-curved-moveable bending mandrel (cut from a 2X4 with a jigsaw). It seemed like the ticket.
I didn't take pictures of fabricating and installing the various ribs. I'd already spent most of the morning getting the 1" spar configured. Basically, I cut sheet metal with electric shears and bent them up with a cheap Harbor Freight brake, profiled them with a grinder, and tacked them up.
And put an elevator next to them to see how things fit. That caused me to want to adjust the upper rib angle a bit.
Being too tired and out of time to start the next stabilizer, I switched to cutting up parts for the hinges. The next thing I learned is I want a cut-off grinder. Free handing an angle grinder on these parts is kind of tedious and sloppy.
Then I turned back to my kinked spar and tried to see if I could salvage it. I put it into a vice and heated the kinked area to force it to expand. I don't know if I can use it. The kink will line up close to a rib. It seems like I could reinforce it with half a tube, but then I'm worried about falling into a barn-yard fix mentality.
So, that's the day. I'm also wondering about the hinge pieces. Both the Northland plans and the Wag Aero plans call for steel bushings. Really? Seems like bronze should go there.
But I'm new to all this. I'll follow the plans unless someone says there is something better.
It may just be an optical illusion. Is the stub of the front spar parallel to the rear spar (left side of the picture)? This is important as the stabilizer assembly needs to move smoothly with the trim system.
They are very close to parallel. It might take some tweaking.
I was thinking of leaving that last rib just tacked until I can get it all assembled to check for fit.
Thanks for keeping an eye out.
Vic
Steel bushings might be OK in the Mojave desert for a month or two, but for us in the rest of the world it is surely not a good choice. I use Delrin as a bushing material, bronze is OK but is rather old school by today's standards.
