Did you ever find out where the 1023 lb empty weight came from?
Sorry, got distracted.
We’ve finished four of the new airplanes so far, and the base weights range from 1,023 to 1,038 lbs. depending on paint and a handful of other choices. N363EX is wearing our Signature Plus paint scheme, which is heavier. Here is how the additional equipment on N363EX adds up:
Extended range fuel tanks, +23.6 lb
Extended Baggage Compartment, +8.5 lb
Garmin G3X Glass Panel, +14.4 lb
LED Lighting & Strobe, RH Landing Light & LEMO Headset Jacks, +1.9 lb
Elevator Trim rear seat, +1.0
26" Goodyear tires, +11.2 lb
83" Hartzell prop upgrade (80" standard), +0.2 lb
Seaplane Panel, +1.0 lb.
Garmin Autopilot, +3.4 lb
Oregon Aero Seats (F&R), +5.1 lb
Odyssey Battery upgrade, +6.0 lb
Halon Fire Extinguisher, +2.3 lb
Optional vacuum pump drive on CC363i, +0.8 lb
Headset Hooks, +0.1 lb
The economics of Cubs sure is changing. This new Carbon Cub will add very expensive Cubs to the fleet. 15 years ago nobody would have believed the market could support Cubs in the $250-$300K price range. Now they're common. The question is how many can the market support. Apparently the answer is more.
Unfortunately the economics of GA has changed. Cubs are not the only aircraft that have higher prices. We're proud of our continuing development and our workmanship, but we are always looking for ways improve efficiency and reduce costs. Today we track at 60ish airplanes each year, and in most industries, that's a custom shop.
