Results 1 to 8 of 8
Thread: Federal 2000A info request
    55-PA18A's Avatar
    Dillingham, Alaska
    598
    Are Federal A2000A's for 1.25 inch axles, or are there different bushings so that a set of skis could be used on either 1.25 inch or 1.5 inch axles?
    What is the center of the axle height for 2000A's (center of the axle hole in the pedestal)? I.e., are they legal to use on regular length gear with an 82 inch Borer prop?
    Interested in buying a set for my SC, but they're a long ways away and I need to know they'll work before committing.
    Jim
    Thanks Rick-CAS thanked for this post
    1,710
    I don't think they are legal with stock gear and 82 inch borer. Bushings for the smaller axles.
    cruiser's Avatar
    South Glens Falls, NY
    1,441
    Nothing on the Federal drawings about 1 1/2" axles. Most fab a bushing out of a rubber hose or machine a UHMW rod to fit. Anything on the 1 1/2" axle paperwork about this? The hole is 2" (+-) and is 8 1/2" (+-) to the center high. Does the Borer STC address the use of skis? I have heard of folks using an 82" prop and having adequate, reasonable clearance on A2000A's. Jim
    Likes cubnut liked this post
    Cubus Maximus's Avatar
    1,812
    I run a set of 2000's with 1.5 inch axles.
    S2D's Avatar
    Montana
    4,063
    don't have the drawing in front of me, but federal had a rubber and steel insert for 1 1/2 inch axles. they then had a a bushing to insert in that for the 1 1/4 axles.
    Thanks pfm thanked for this post
    1,691
    nanook's Avatar
    Aug 2002
    northern alaska
    1,653
    You don't want to use that 11A109 sleeve, it will bell out the inner side hole on the pedestal. Use a straight sleeve of steel inside the rubber bushing. Use one large area washer on each end. Your axle spacer that keeps your wheel bearings centered needs to be removed and one about 1/2 the length installed.
    55-PA18A's Avatar
    Dillingham, Alaska
    598
    Thanks for the good information.
    Jim
  1. Federal 2000's vs 2000A's
    By jgerard in forum Ski Flying Forum
    Last Post: 01-27-2012, 03:35 PM
  2. A request of info on PA18-90 on floats
    By CesareBaj in forum Cafe Supercub
    Last Post: 01-06-2004, 11:26 AM
