Results 1 to 12 of 12
Thread: Extended Gear
    Jul 2013
    Brazil
    32
    Extended Gear
    Hello fellows.
    Could someone tell me the advantages and disadvantages of a extended gear on a PA-18? Is it mandatory for use with Tundra tires? Can we use tundra 31" without the extended gear?
    Regards
    AC Muller
    Thanks Orchevguy thanked for this post
    behindpropellers's Avatar
    NE Ohio
    6,801
    Quote Originally Posted by carlbrun View Post
    Hello fellows.
    Regards
    AC Muller
    Advantage - Higher AOA when on the ground.
    Not required for 31" tires.
    Required for small tires and an 82" propeller.
    Thanks carlbrun thanked for this post
    Likes carlbrun, DENNY liked this post
    2,059
    A disadvantage of extended gear and/or tall tires is loading people/gear into and out of the plane. Fueling can also be a bit harder depending on the setup. Bit of thread drift, tall tailwheel/spring units also hurt AOA/prop clearance.
    Likes carlbrun liked this post
    19,776
    3" gear helps the angle of attack, AOA helps take off run. The biggest thing to me is prop clearance. I operate on sand and gravel a lot and the prop takes a beating. When I bought my Super Cub I started out on standard gear and 700x6 tires, went to 29" Bushwheels, then 3" extended gear and then 31" Bushwheels. All helped.
    Likes carlbrun, cubscout liked this post
    Jul 2013
    Brazil
    32
    Very enlightening
    5,285
    The item that drove extended gear in my memory was the use of Borer props with skis. Guys would switch from big tires to skis and not have FAA required prop clearance.
    Extended gear has a wider track as much as taller stance. Guys like that as well since big tires can be a little wobbly. Atlee Dodge made the first extended gear that I remember and while 3” extended served the purpose for prop clearance he didn’t like and advised against using 6” extended gear. On counter point Wayne Mackey’s SQ-12s have something like 10” extended gear. Wing mods drove that, no doubt.
    May 2014
    661
    A bit of a weight penalty and defiantly some aerodynamic drag added.
    Hanging big tires further out and down affects AOA at cruise. I'm guessing 3-4 mph penalty, but curious what others think.
    19,776
    1 1/4" 3" extended Atlee Dodge gear is 1.8 lbs each side heavier that stock Piper gear from the ones I have weighed. I consider them a must on my airplane for my mission.
    Likes carlbrun, mike mcs repair liked this post
    9,299
    As you raise the front of the aircraft, bigger tires, longer gear, you also increase the force needed to lift the tail.
    When landing the extra tail weight is a good thing, taking off not so much.
    3" gear helped in most applications I used my cub in. It was really nice for skis, as the towers were not super tall, and as said before I could not meet prop clearance.
    Mar 2016
    1,506
    At what point when moving the weight back in 3 point will it increase the tendency for a ground loop?
    Regards, Charlie
    Mar 2015
    263
    I have the cub extended gear and AOSS on my Husky. Added fairings to both and gained 8mph. 5 mph for gear fairings, 3mph for AOSS streamlined 'teardrop' fairings.
    Going to add the fairings to my supercub extended gear/AOSS too, should gain some mph back. Probably not as much as on the Husky, but will see.
    John
    10,211
    Every 1/16"
    Likes ChrisZ liked this post
  1. Gear leg farings for extended gear
    By john schwamm in forum Cafe Supercub
    Last Post: 01-11-2017, 09:47 PM
  2. 3 x 3 extended gear
    By tempdoug in forum Cafe Supercub
    Last Post: 02-05-2011, 03:04 PM
  3. What is extended on an extended gear?
    By RYAN_WINGS in forum Modifications
    Last Post: 08-10-2003, 07:36 PM
