duckhunter10
Stick forward or back?
I tried the round disc type of control lock on the top of the rudder once. I watched the rudder try to twist its top off in the wind so I pitched that lock and have never locked the rudder since. Come to think of it I haven't used a rudder lock on the Cessna since the big storm in 2003, either. Even when I've been tail to the wind it hasn't been a big problem. I could make an external lock for any airplane I own but I just haven't seen the need. Other guys may have different ideas. Bottom line is I'll always try to spin the plane nose to the wind. That eliminates 90% of any gust lock requirements.
...HIGH WIND WARNING NOW IN EFFECT FROM 10 PM THIS EVENING TO5 AM AKDT WEDNESDAY FOR TURNAGAIN ARM AND HIGHER ELEVATIONS
INCLUDING THE LOWER HILLSIDE...
* WIND...Turnagain Arm and Higher elevations...sustained southeast
winds 30 to 50 mph with gusts to 80 mph.
Lower Hillside (~1000 ft)...sustained southeast winds 25
to 40 mph with gusts to 60 mph.
Anchorage Bowl...sustained southeast winds 15 to 30 mph
with gusts to 45 mph.
* TIMING...Winds will first increase along Turnagain Arm and
higher elevations this evening. Around midnight winds will come
down the Hillside toward lower elevations. After midnight
southeast winds will come through all of Anchorage. The peak
of the event will be from around midnight tonight through
around 4 AM with gusty winds continuing through the day on Wednesday.
