Page 2 of 4 FirstFirst 1234 LastLast
Results 41 to 80 of 135
Thread: L-21 Javron
  1. #41
    G44's Avatar
    Oct 2011
    SW Michigan
    443
    A thought.... Buy extra inspection covers and paint them when you paint the rest of the airplane then put them aside so if you do need to cut a hole where you have a grommet you will have a cover all ready to go.
    Kurt
    Likes DENNY liked this post
  2. #42
    Apr 2008
    Michigan
    79
    Starting to look like something
    So do I use a 2 or 3 inch tape down the spine?
    sofar so good. Fun fun
  3. #43
    9,268
    https://www.faa.gov/documentLibrary/...-1B_w-chg1.pdf
    Page 2-9
    (5) For an overlapped and doped seam on the perimeter of a wing (except a leading edge), perimeters of wing control surfaces, perimeters of empennage surfaces, and all areas of a fuselage, on aircraft with a Vne speed up to and including 150 mph, overlap the fabric 1 inch and cover with a finishing tape that is at least 3 inches wide, centered on the outside edge of the overlap seam.
  4. #44
    Apr 2008
    Michigan
    79
    Page 2-9
    Thanks for the reply. Skywagon8a
    43.13-1B acceptable methods and techniques and practices. Used when no manufactures guidance is provided
    i see the drawing referenced above thanks Steve. Shows 2". I also have an L21 drawing that doesn't specify at least I can't find it anywhere.
    Just trying to see what others have done.
    Again my first kit lots of dumb questions to come
  5. #45
    9,268
    Quote Originally Posted by avnxtek View Post
ID:	37930 So do I use a 2 or 3 inch tape down the spine?
    Measure from the center line of the spine to the edge of the overlap. If it's close to 1 inch you will be happier using the 3" tape as it will blend in smoother with the fabric.
    Tape the leading edge of the fin first so that the fuselage spine tape will overlap the fin's tape. Blending the fuselage/fin junction can be a challenge.
  6. #46
    Apr 2008
    Michigan
    79
    Well I think she is covered
    On to the next phase.
  7. #47
    Apr 2008
    Michigan
    79
    Question for the Stewart System Experts
    The latest manual Tells me to cut the E610 EcoBond 3-1 with distilled water and apply over the fabric. I did this with the Tail feathers and am happy with the results.
    The manual also says that you can apply EcoFill without EcoBond First ??
    From what I have been able to gather this change was made to improve cooler temp. application
    All of the videos I have seen go straight to EcoFill
    So Do I Don't I?
    What have others done?
    Any other explanations for this manual change?
  8. #48
    Apr 2008
    Michigan
    79
    wow must not be many Stewart systems users
    anyway I went buy the book and got to the second brush on coat of Eco fill
    First Eco bond to fill the weave of the fabric. Brushed on in multiple directions and a very thin coat this stuff will run!
    I kept the surface flat until it tacked up
    Eco fill goes on real nice again I kept the surface flat until tacky and moved on
    I'm learning as I go and I hope this might help someone
  9. #49
    3,325
    First coats have to go on light, or they will for sure run! Furthermore, I've learned the hard way to not depend on flat orientation to accommodate putting the material on heavy. I ran into adhesion issues doing that.
    I've found that with Stewart's if I don't try to rush it, it works great. Fortunately EcoFill sands pretty well if (when!) needed.
  10. #50
    9,268
    Your first question was for experts. I've used it and like it but am certainly not an expert. I would need to get out the book again when I use it the next time. It's different than nitrate dope on Irish linen which is what I'm used to.
  11. #51
    Apr 2008
    Michigan
    79
    Yup should have used the words Stewart System users.
    Maybe I would have a few more responses
    going by the book and learning the system. Happy with the results sofar
    it's all fun
  12. #52
    Apr 2008
    Michigan
    79
    What a great day!
    Looks like I get to start on the cowling this weekend
    Just more Fun
    Likes mike mcs repair, Jim A. liked this post
  13. #53
    Apr 2008
    Michigan
    79
    I need to finish my upholstery project before I move on the the Engine installation
    This takes some time but is still fun
    All Weekend and I just got the back seat together
    And the harnesses came in this week
    Now on to the front seat
  14. #54
    flylow's Avatar
    Oct 2013
    36
    Cool seats! You making everything on this cub
    Fun watching your build.
  15. #55
    Apr 2008
    Michigan
    79
    Quote Originally Posted by flylow View Post
    Thanks Flylow
    It is my goal to do everything possible myself with this build
  16. #56
    Apr 2013
    Cloquet, MN
    135
    Nice job. Those look great! Envious of people with upholstery and sewing skills. Two inherited sewing machines in my shop, need to one day get results half as good as yours. Very nice.
  17. #57
    10,321
    Quote Originally Posted by Jim A. View Post
    When I was 17 I made a complete new interior for a car I was given before I even tried to get it running. Luckily my step fathers friend had a boat upholstery shop and gave me a few pointers and ordered the material for me in Naknek. My mom taught me how to sew when I was 5. Only one rule don’t sew over a finger. That was about it. Still have her sewing machine. And a monster fast big singer from the sail boat days.
  18. #58
    Apr 2013
    Cloquet, MN
    135
    Sounds familiar. Mom and I made the headliner for my first car, a 53' Buick. The machines I have are her old units. I was a hammerhead when I was younger, results were the most important, learning and remembering how to repeat them 30yrs or so later seemed less important at the time. Mom and Dad are still around, hoping to get them involved in my snail's pace build. Again, very nice stuff avnxtek!
  19. #59
    Apr 2008
    Michigan
    79
    Thanks Jim, Mike (and don't look to close)
    i remember doing some projects with Mom when I was young then in the 90s we had a 172C and the seats were falling apart so I got the old machine from Mom and made covers, at that time making them was the only option and they turned out pretty good. Still have that machine also. I found this big machine for this project and I think I could sew plywood together with this thing! And it can be way to fast if you don't watch it. Just like most things Prep,Prep, Prep and patience and you can do it.
    and it's all fun
  20. #60
    Apr 2008
    Michigan
    79
    Well got the front seat finished up today
    More fun begins tomorrow
  21. #61
    Apr 2008
    Michigan
    79
    A little more progress
    Likes jrussl, Riverking liked this post
  22. #62
    Apr 2008
    Michigan
    79
    Some fun with the cowling
    Top supports installed
    With the 2" lowered mount the Vetterman exhaust is a little tight
    I'm amazed at the quality of experimental parts. This exhaust is a work
    of art
    With my poster board mock up. I placed the lower cowl vents
    a little foreword to give me some clearance about a 1/2 inch
    A few little adjustments and I'll start on the real thing
    Thanks stknrddr thanked for this post
  23. #63
    9,268
    avnxtek,
    You should increase the amount of belly in your lower cowl. This will give you more clearance with the exhaust and also a larger hot air exhaust at the bottom aft end. You may even be able to eliminate those belly scoops with the use of a lip just ahead of the large opening.
    Likes DENNY, mike mcs repair liked this post
  24. #64
    9,268
    Also rotate that front clamp on the muff to prevent it from hitting the lower cowl support channel. It could tap the channel making you think that there is something seriously wrong with the engine.
  25. #65
    4,536
    L-21 Javron
    Mike made a form out of 2x lumber to press soft 032 into rounded-end scoops. I can send pics if you're interested.
    The project looks great. Thanks for sharing.Click image for larger version.
  26. #66
    Apr 2008
    Michigan
    79
    I'll probably do a combination of lower bottom cowl and cowl scoops.
    That's the value of poster board lot's of trial and error to go
    Thanks for the ideas
    pictures are very deceiving lots of space between the lower support and the clamp
    When I get to final assembly everything will be positioned for max. clearance for sure
  27. #67
    4,536
    How do you lower the bottom cowl without changing the nose bowl?
  28. #68
    RaisedByWolves's Avatar
    Feb 2005
    3,770
    When I made my lower cowl I used mikes advice, and when it’s flat, extend the distance between cowl attachment holes if that makes sense. Drops the air filter scoop down. Most stock cubs the cowl is touching the air box, on round filter cubs
  29. #69
    Apr 2008
    Michigan
    79
    So you mean a little more distance between mounting to the lower support rail on the aft end only, giving a bit more bow to the lower cowl?
    you can't change the front or it won't fit the nose bowl
    My engine is 2" lower than stock and has thrustline built in so the air box is a couple inches below the lower cowl at least the way I have it now
    with my poster board mock up
    Likes skywagon8a, mike mcs repair liked this post
  30. #70
    4,536
    Exactly. My nose bowl is lower below the prop opening than most. That provided clearance for my Vetterman mufflers. The dual scoops in my picture went unused so they morphed into a full width cooling lip instead. My muffler clearance is close to the cowl but so far so good. The only nuisance is reaching the quick drain in between two hot mufflers to drain oil. I can live with that. Scoops should work fine.
    What suspension will you use? Beware. Your exhaust will dump right onto your TKs or ACMEs. It's a recurring maintenance issue to remove exhaust residue.
  31. #71
    Apr 2008
    Michigan
    79
    I have TK's so that issue has been on my mind Any one make covers for them?
  32. #72
    Feb 2005
    3,770
    http://www.supercub.org/forum/showth...-amp-PDF-Files
  33. #73
    1,655
    Consider moving the lower cowl vents forward another inch or so. You want some room behind them in case you need to add seaplane lip to add cooling.
  34. #74
    10,321
    [QUOTE=avnxtek;730947]So you mean a little more distance between mounting to the lower support rail on the aft end only, giving a bit more bow to the lower cowl?
    /QUOTE]
  35. #75
    4,536
    Lowered engine mount. The "rules" have changed.
  36. #76
    Apr 2008
    Michigan
    79
    I'll give that a try with my mock-up and see where things end up
    All great information Thanks.
    [QUOTE=mike mcs repair;730957]
    /QUOTE]
  37. #77
    Bearhawk Builder's Avatar
    Aug 2012
    In the woods
    639
    I did the same, that little bit makes a big difference in clearance.
  38. #78
    Apr 2008
    Michigan
    79
    It looks good with paper.
    I think I'll go for it with aluminum
ID:	39656Click image for larger version.
  39. #79
    10,321
    I'd leave out the bottom scoops at first... run it & see if they are needed... wildcatcub turned out ok without them, just a lip in back..(we had them all made)
  40. #80
    4,536
    L-21 Javron
    Using the stock nose bowl the slope on the top cowl will increase and the bottom cowl flattens out. Cutting a relief and shielding that with a scoop may be necessary. Or add domes for clearance and skip the scoops. Or morph domes into scoops. Maximize cooling. Experiment. Improve. Bottom line? Do whatever you want. This is the fun part!
  1. Building a Javron Cub
    By Bill Rusk in forum Member Projects in Progress
    Last Post: 07-02-2019, 10:04 AM
  2. New Javron Build
    By flyanozira in forum Cafe Supercub
    Last Post: 11-06-2015, 09:08 AM
  3. Jasperfield's Javron
    By Jasperfield in forum Member Projects in Progress
    Last Post: 06-18-2015, 03:49 PM
  4. Ron Building Javron Cub 1
    By ron cope in forum Member Projects in Progress
    Last Post: 05-25-2015, 05:31 AM
  5. Who is building a Javron Cub?
    By Jasperfield in forum Experimental Cubs
    Last Post: 12-18-2014, 10:43 PM
