Page 4 of 4 FirstFirst ... 234
Results 121 to 150 of 150
Thread: L-21 Javron
  1. #121
    Apr 2008
    Michigan
    88
    Right wing is ready for the paint booth
    Left wing is in progress just need to find the time to finish
    In my spare time I have been wiring up some Avionics
    Oshkosh might slow me down a bit but it's all fun
    Likes RVBottomly, stknrddr liked this post
  2. #122
    19,638
    Quote Originally Posted by avnxtek View Post
    I'm envious, nice set up. Looks like this isn't your first rodeo.
  3. #123
    11,092
    on my wish list is one of those magnifying units.....
  4. #124
    Apr 2008
    Michigan
    88
    I have been playing with wires on aircraft ever since learning the basics at NAS Millington back in 84
    Be careful with them magnifying things it seems that the more you use them the more you really need them
  5. #125
    19,638
    My Dad taught avionics at Millington in the mid 70s.
  6. #126
    3,093
    Lol. I was im Millington in 83.
  7. #127
    Apr 2008
    Michigan
    88
    Got the Paint booth together Now I get to spray some Paint
    I seem to have a hard time with dust. I guess I just need to clean better before spraying
  8. #128
    11,092
    Start fan on high an hour before painting, the turn fan down during painting(moves dust before you paint). Fast fan should have moved the dust. Also hang parts vertically or top DOWN(good side)
  9. #129
    Sep 2018
    22
    Where did you purchase the paint booth?
  10. #130
    Apr 2008
    Michigan
    88
    [QUOTE=mike mcs repair;754544]Start fan on high an hour before painting, the turn fan down during painting(moves dust before you paint). Fast fan should have moved the dust. Also hang parts vertically or top DOWN(good side)
    I think I need more fan to do that. The fan I have blows in through the filter. Maybe I should have one blowing out also
    I'll try it
  11. #131
    Apr 2008
    Michigan
    88
    Quote Originally Posted by Travelair3000 View Post
    shelterlogic.com. This one is 13X20X10.
  12. #132
    Jun 2007
    New Zealand
    487
    My suggestion is to not use a table like that. You will be blowing dirt off the table onto your component. You will never pay as much attention to cleaning the adjacent table as you do the component. Put them on trestles with the edges of the component clear of the trestles. If you do use a table, new paper for each painting session.
    Hanging is better, like Mike said, but might not be all that easy with a temporary booth like that. And then as it bobs around on the wires as you spray the component, it shakes the dirt off the ceiling and onto your job......
  13. #133
    Apr 2008
    Michigan
    88
    More fun with Paint
    And thanks for the advice I have added another Fan so now I can push 10,000 CFM through the paint booth on Hi and that seems to clear everything out.
    The table is gone and I am trying to paint everything vertical if possible.
    Now I have a Wing in the Booth
    My first go around with the Stewart Paint system Seems to be working for me so far.
ID:	45056Click image for larger version.
    I was thinking of adding another stripe with some color just behind the Black leading edge but the more I look at this the more I want to leave it as is.
ID:	45058Click image for larger version.
    Likes Cubus Maximus, Sam D, CamTom12, stknrddr liked this post
  14. #134
    Bill Rusk's Avatar
    5,325
    Looks great. Thanks for posting.
    Very Blessed.
  15. #135
    10,216
    I have found that a 1/4" stripe separating the black and white or whatever your two colors are enhances the look, adding about a million bucks to the visual wow value. An alternate method is to leave 1/4" of the base light color separating the dark from the stripe. The third color should be a tone in between the two major colors which sort of softens the difference.
    If you do do this you will be saying to yourself "WOW am I ever glad that I took the extra time!".
    It doesn't sound like much, but it makes a big difference.
    If you look closely at the pictures of my 185 you can just make out the third color which is a light blue. https://www.supercub.org/forum/showt...mphib-For-Sale
  16. #136
    Apr 2008
    Michigan
    88
    Making some progress. This weekend Aircraft building sure can take some time.
    Wings are done and have made it to the hangar
    Working on the fuselage and other parts. Now if I could just figure out how to stripe it.
  17. #137
    Nov 2019
    27
    This build looks great. I like the idea of the portable building as the paint booth. I will need to do something like that myself.
  18. #138
    Apr 2008
    Michigan
    88
    Quote Originally Posted by Adam Gordon View Post
    Thanks Adam. The portable building has been working for me just load it up with lights and ventilation. This one is 20’ X 13’ was on sale at the home improvement store. Would be nice if it was bigger, really tight in their moving around the fuselage.
  19. #139
    Apr 2008
    Michigan
    88
    Some more progress
    A little color on the fuselage
    Before the boot cowl goes back on. The Avionics and behind the panel wiring is done and tested
    I have a temp plexiglass panel to locate everything and working on this sweet Carbon fiber panel from Randy at Carbon concepts
    got it all cut out now just working on labels
    and one more thing before the boot cowl Firewall blanket
    so now the engine is back on and I’m working on everything up front
    Hope to start on windows next week and keep moving to the finish line
    Likes stknrddr, CamTom12, Lowrider, Bill Rusk liked this post
  20. #140
    Lowrider
    Nov 2012
    Idaho Panhandle (ID05)
    1,700
    Now that's real progress and it's beautiful!!
    I have considered a temporary building for painting but I need to build another to house my tractor and associated stuff anyway so I think that will coincide with my need for a paint booth and thanks for the sizing comments. I was going to do a 16' x 24' but 20' wide is a better size I think. This idea will go a long way to convincing my wife I need another building. She has this silly idea I can just paint in the shop. Might even convince her we need heat in there too.
    Thanks Sky for the "pin stripe" idea!!
  21. #141
    11,092
    My booth area is only 10’ x 22 useable.
  22. #142
    Apr 2008
    Michigan
    88
    One more step closer
    Panel is in and checked out.
    Likes CamTom12, Bill Rusk, Sam D, Alanfrease liked this post
  23. #143
    Apr 2008
    Michigan
    88
    I like aluminum fittings and used them 100% on my Cub. Piper used rubber hose with a clamp on each end. If the clamp isn't tight there is the possibility of a leak. Rubber hose can deteriorate so when the connection is in a blind area there will always be some doubt.
    100% aluminum fittings? How did you hookup the tanks and sight guages? Got any pictures
  24. #144
    10,216
    100% aluminum fittings? How did you hookup the tanks and sight gauges? Got any pictures
    This is what I have.
ID:	49100 Click image for larger version.
    That was a poor choice of color for the background plate on the fuel gauges. I just grabbed a rattle can off the shelf. One of these days I'll slip something lighter behind the sight tube. The tube is just a length of plastic tubing from the hardware store.
  25. #145
    Apr 2008
    Michigan
    88
    I have actual sight gauges from Javron. I'll probably have to use a couple of AN842's with a piece of hose or something like that.
    Looks like you have AN822's in the tank Do the lines go directly to them or do you have a shorter piece of tubing between the tank and fuselage?
  26. #146
    10,216
    I too have the sight gauges from either Javron or TCOW. These are new never used if anyone is interested. My kit was made by both companies, so I'm not sure where the fuel gauges came from. No matter, I could not get them to fit to my satisfaction so elected to go with the clear tubing, keeping it attached to the wing. In lieu of an interior panel I used clear plexiglass. The fittings in the tank are AN840.
    The fuel feed lines are hard connected to the tank. There is a long (either 4" or 6" ??) brass nipple screwed into the tank. An AN916 elbow is connected to the nipple, then an AN816, An818 and AN819 to the flared tubing. No rubber hoses at all.
    With the clear plexiglass interior panel I can see everything at any time so there will be no surprises.
  27. #147
    Apr 2008
    Michigan
    88
    Ok I see what you have sounds like that would work.
    Thanks for the info
  28. #148
    Apr 2008
    Michigan
    88
    Fun with some windows, Autopilot Servos, and we are on Gear for the first time.
    Soon I'll be heading to the Airport Hangar to put wings on.
    Anyone know A DER close to Michigan ?
  29. #149
    10,216
    Look here for starters. https://www.faa.gov/other_visit/avia...ind_designees/
  30. #150
    Jul 2007
    227
    Friend of mine used a guy out of Detroit area. I nice guy I will see if I can get you a name and number tomorrow.
  1. Building a Javron Cub
    Last Post: 04-13-2020, 11:19 PM
  2. New Javron Build
    By flyanozira in forum Cafe Supercub
    Last Post: 11-06-2015, 09:08 AM
  3. Jasperfield's Javron
    By Jasperfield in forum Member Projects in Progress
    Last Post: 06-18-2015, 03:49 PM
  4. Ron Building Javron Cub 1
  5. Who is building a Javron Cub?
