Page 5 of 5 FirstFirst ... 345
Results 161 to 186 of 186
Thread: L-21 Javron
  1. #161
    Apr 2008
    Michigan
    107
    Curious why you reinforced the antenna mount? Functionally, there are no great places to mount antennas on a Supercub type aircraft, as there are no metal panels with enough surface area to make a good ground plane. But, mechanically, the fairings hold antennas just fine due to antennas very low wind load.
    Nothing wrong with your mount plate but you're going to need to pull the antenna off every time you remove the fairing (common item during maintenance).
    I guess after mounting what seems like thousands of antenna on all types of aircraft and always using some type of backing plate and with this fairing being only .020 it really needed something. May be some more overkill but another 4 screws and it's off.
  2. #162
    Jun 2019
    Moab, UT
    52
    I use the pushlocks a lot in offroad world, they're great! We run them at 60 psi without issues
  3. #163
    Apr 2008
    Michigan
    107
    Quote Originally Posted by gahi View Post
    Thats good to hear It looks to me that they will work great. Time will tell the story
  4. #164
    Captain Ron's Avatar
    Mar 2004
    Les Cedres, QC, Canada
    50
    Quote Originally Posted by avnxtek View Post
    More fun with fuel lines and all the details
    I found these AN push lok fittings and think they will work without some hose clamp holding tight.
    Interesting - Could you post the part number and source for those push lok fittings?
  5. #165
    Apr 2008
    Michigan
    107
    Quote Originally Posted by Captain Ron View Post
    Try here https://www.jegs.com/webapp/wcs/stor...h+lock+fitting
    Thanks Utah-Jay, Captain Ron thanked for this post
  6. #166
    20,847
    Looks like what a friend is using on his Rans S21 build.
  7. #167
    3,833
    Looks like not AN fittings, but fittings that mate to AN flare?
  8. #168
    Apr 2008
    Michigan
    107
    The AN is (Army Navy) and suggests that AN fittings are built to a Specification. These fittings are made for AN sizes and 37 deg. flair
  9. #169
    Apr 2008
    Michigan
    107
    This is a big step towards the finish line
    First start. First video also hope it works
    Likes stknrddr, Dirt911, DENNY, supercrow, Riverking and 4 others liked this post
  10. #170
    Apr 2008
    Michigan
    107
    Got on some scales over the weekend
    Likes Taledrger, jrussl liked this post
  11. #171
    Apr 2008
    Michigan
    107
    Just looking for a Sanity check
    Doing my W&B There is no way I can load this thing up to 2300# without going out of CG aft real Quick
    I'm using 60" forward of LE for Datum 62.5" * 1061 for main weight and 260" * 66 for tail weight and get a CG of 74
    CG Range 71 to 81
  12. #172
    Dec 2018
    Rangely, Co
    49
    I think if you play with it a little you’ll find you’re better off than you think. I just re-did my W&B and my numbers are close to yours. I found you will obviously have to limit your baggage to how far back you go (I have extended baggage), but I had little trouble getting to gross. Stayed right at the aft limit admittedly.
    Thanks avnxtek thanked for this post
  13. #173
    2,387
    The smart guys can do the math for you. In general a belly pod will cure a lot of CG issues.
    Likes Steve Pierce, Utah-Jay liked this post
  14. #174
    Apr 2008
    Michigan
    107
    just had to paint one more thing
    I'll get this back on and I believe we will be ready for final inspection
    fun fun
    Likes RaisedByWolves, gahi, Taledrger liked this post
  15. #175
    Apr 2008
    Michigan
    107
    What a great day
    Boys and Girls we have a certified Airplane
    Let the fun begin again
  16. #176
    May 2016
    Charlotte, NC
    1
    Congratulations! Really enjoyed following your build on SC.org. Thanks for posting so we could follow along. Have fun and Blue Skies!
  17. #177
    aeroaddict's Avatar
    Mar 2016
    Boise ID area
    176
    Looks great and congratulations. I especially appreciate the checkered tail. I decided to do that and boy was it a lot of work!
    Let us know how she flies.
  18. #178
    Taledrger's Avatar
    SW Michigan
    1,010
    That's awesome!! Glad to hear all went well. Now the REAL FUN begins!! Can't wait to see it!!
    Bob D
  19. #179
    Bill Rusk's Avatar
    Sandpoint, Idaho
    5,436
    Congratulations!!!! Thanks for posting!!
    Very Blessed.
  20. #180
    Apr 2008
    Michigan
    107
    First flight tonight
    Sorry no video or pictures just Me and the plane with a great night to fly
    And WOW perfect just perfect
    much more flying to come.
    Thanks Taledrger thanked for this post
  21. #181
    Taledrger's Avatar
    SW Michigan
    1,010
    A great big Congratulations!! Well done my friend!! I could almost see the GRIN thru the phone line when you called!! Can't wait to get up there and see her for myself!!
    Bob D
  22. #182
    WWhunter's Avatar
    Aug 2003
    1,521
    Awesome!! Great accomplishment!
    Don't take life too seriously ... no one gets out alive!
  23. #183
    tedwaltman1's Avatar
    Jul 2011
    Denver, CO
    530
    Congratulations on persevering to get to this key finishing stage!
  24. #184
    Apr 2008
    Michigan
    107
    I have 5 hours on it now
    CHTs seem a little bit high but coming down a bit Oil temps are for sure under control
    For sure having fun with this thing
    Likes Taledrger, gahi liked this post
  25. #185
    2,387
    Might want to change the timing on the mags to help lower the CHT'S
  26. #186
    20,847
    Temps look fine to me.
    Likes skywagon8a, supercrow liked this post
  1. Building a Javron Cub
    Last Post: 05-11-2021, 05:03 PM
  2. New Javron Build
    By flyanozira in forum Cafe Supercub
    Last Post: 11-06-2015, 09:08 AM
  3. Jasperfield's Javron
    By Jasperfield in forum Member Projects in Progress
    Last Post: 06-18-2015, 03:49 PM
  4. Ron Building Javron Cub 1
  5. Who is building a Javron Cub?
