L-21 Javron
Another big step. Made it from the shop at home to the hangar
Ready for the wings
Going to have some fun now
yup. Working on wing root fairings
and a few other things
10.5 oz out of the step
the finish line is getting closer but still a lot of stuff to do
all fun
Where's our progress update???? :smile:
Ya I know
Things have slowed a bit since moving to the Hangar
I had to cover and paint the flaps and ailerons so they are done and ready to install.
A couple more things to paint Wing root fairings and a blue stripe on the tank covers.
Finished the fuel lines from tanks to fuselage last weekend so it's ready for some fuel and that first engine start.
So I have all the little details to finish up
Hopefully we will be flying this thing in the landing environment this spring
Ya I know
Where in Michigan are you located? Do you still need a DER or DAR? Love the colors and scheme!
Kurt
Kurt
Thanks Kurt
I'm at C04 Oceana County Come on over some Weekend
I do still need a DER I have a # for a guy Ted just need to make contact
I will have to do that. I’m in Kalamazoo area. I have a Blue and White Husky. Are you around on the weekends? Weekdays? What does your hangar look like?
Kurt
More fun with fuel lines and all the details
So I have been struggling to find a connection between the tank and fuselage other than the standard hose and clamp
I found these AN push lok fittings and think they will work without some hose clamp holding tight.
Antenna mount and wing root fairings
I wanted a little more support for this Com/GPS Antenna This backing plate should do the the trick
Inner wing root panel with Fuel sight gauges
Now that the Prop is on I hope to get to that first engine start real soon
Curious why you reinforced the antenna mount? Functionally, there are no great places to mount antennas on a Supercub type aircraft, as there are no metal panels with enough surface area to make a good ground plane. But, mechanically, the fairings hold antennas just fine due to antennas very low wind load.
Nothing wrong with your mount plate but you're going to need to pull the antenna off every time you remove the fairing (common item during maintenance).
I guess after mounting what seems like thousands of antenna on all types of aircraft and always using some type of backing plate and with this fairing being only .020 it really needed something. May be some more overkill but another 4 screws and it's off.
I use the pushlocks a lot in offroad world, they're great! We run them at 60 psi without issues
Interesting - Could you post the part number and source for those push lok fittings?
Got on some scales over the weekend
Just looking for a Sanity check
Doing my W&B There is no way I can load this thing up to 2300# without going out of CG aft real Quick
I'm using 60" forward of LE for Datum 62.5" * 1061 for main weight and 260" * 66 for tail weight and get a CG of 74
CG Range 71 to 81
I think if you play with it a little you’ll find you’re better off than you think. I just re-did my W&B and my numbers are close to yours. I found you will obviously have to limit your baggage to how far back you go (I have extended baggage), but I had little trouble getting to gross. Stayed right at the aft limit admittedly.
just had to paint one more thing
I'll get this back on and I believe we will be ready for final inspection
fun fun
What a great day
Boys and Girls we have a certified Airplane
Let the fun begin again
Congratulations! Really enjoyed following your build on SC.org. Thanks for posting so we could follow along. Have fun and Blue Skies!
Looks great and congratulations. I especially appreciate the checkered tail. I decided to do that and boy was it a lot of work!
Let us know how she flies.
First flight tonight
Sorry no video or pictures just Me and the plane with a great night to fly
And WOW perfect just perfect
much more flying to come.
