Page 4 of 4 FirstFirst ... 234
Results 121 to 135 of 135
Thread: L-21 Javron
  1. #121
    Apr 2008
    Michigan
    79
    Right wing is ready for the paint booth
    Left wing is in progress just need to find the time to finish
    In my spare time I have been wiring up some Avionics
    Oshkosh might slow me down a bit but it's all fun
    Likes RVBottomly, stknrddr liked this post
  2. #122
    18,819
    Quote Originally Posted by avnxtek View Post
    I'm envious, nice set up. Looks like this isn't your first rodeo.
  3. #123
    10,490
    on my wish list is one of those magnifying units.....
  4. #124
    Apr 2008
    Michigan
    79
    I have been playing with wires on aircraft ever since learning the basics at NAS Millington back in 84
    Be careful with them magnifying things it seems that the more you use them the more you really need them
  5. #125
    18,819
    My Dad taught avionics at Millington in the mid 70s.
  6. #126
    2,563
    Lol. I was im Millington in 83.
  7. #127
    Apr 2008
    Michigan
    79
    Got the Paint booth together Now I get to spray some Paint
    I seem to have a hard time with dust. I guess I just need to clean better before spraying
  8. #128
    10,490
    Start fan on high an hour before painting, the turn fan down during painting(moves dust before you paint). Fast fan should have moved the dust. Also hang parts vertically or top DOWN(good side)
  9. #129
    Sep 2018
    19
    Where did you purchase the paint booth?
  10. #130
    Apr 2008
    Michigan
    79
    [QUOTE=mike mcs repair;754544]Start fan on high an hour before painting, the turn fan down during painting(moves dust before you paint). Fast fan should have moved the dust. Also hang parts vertically or top DOWN(good side)
    I think I need more fan to do that. The fan I have blows in through the filter. Maybe I should have one blowing out also
    I'll try it
  11. #131
    Apr 2008
    Michigan
    79
    Quote Originally Posted by Travelair3000 View Post
    shelterlogic.com. This one is 13X20X10.
  12. #132
    Jun 2007
    New Zealand
    486
    My suggestion is to not use a table like that. You will be blowing dirt off the table onto your component. You will never pay as much attention to cleaning the adjacent table as you do the component. Put them on trestles with the edges of the component clear of the trestles. If you do use a table, new paper for each painting session.
    Hanging is better, like Mike said, but might not be all that easy with a temporary booth like that. And then as it bobs around on the wires as you spray the component, it shakes the dirt off the ceiling and onto your job......
  13. #133
    Apr 2008
    Michigan
    79
    More fun with Paint
    And thanks for the advice I have added another Fan so now I can push 10,000 CFM through the paint booth on Hi and that seems to clear everything out.
    The table is gone and I am trying to paint everything vertical if possible.
    Now I have a Wing in the Booth
    My first go around with the Stewart Paint system Seems to be working for me so far.
ID:	45056Click image for larger version.
    I was thinking of adding another stripe with some color just behind the Black leading edge but the more I look at this the more I want to leave it as is.
ID:	45058Click image for larger version.
    Likes Cubus Maximus, Sam D, CamTom12 liked this post
  14. #134
    Bill Rusk's Avatar
    5,246
    Looks great. Thanks for posting.
    Very Blessed.
  15. #135
    9,459
    I have found that a 1/4" stripe separating the black and white or whatever your two colors are enhances the look, adding about a million bucks to the visual wow value. An alternate method is to leave 1/4" of the base light color separating the dark from the stripe. The third color should be a tone in between the two major colors which sort of softens the difference.
    If you do do this you will be saying to yourself "WOW am I ever glad that I took the extra time!".
    It doesn't sound like much, but it makes a big difference.
    If you look closely at the pictures of my 185 you can just make out the third color which is a light blue. https://www.supercub.org/forum/showt...mphib-For-Sale
  1. Building a Javron Cub
    Last Post: 07-02-2019, 10:04 AM
  2. New Javron Build
    By flyanozira in forum Cafe Supercub
    Last Post: 11-06-2015, 09:08 AM
  3. Jasperfield's Javron
    By Jasperfield in forum Member Projects in Progress
    Last Post: 06-18-2015, 03:49 PM
  4. Ron Building Javron Cub 1
  5. Who is building a Javron Cub?
