Results 1 to 8 of 8
Thread: Another why not to use ethanol gas
    Doug Budd's Avatar
    Feb 2015
    Crawford Nebraska
    167
    Found this video on utube, it's about boats but it does the same with planes. It's hard enough to keep water out of gas without the gas making its own water!
    https://youtu.be/xzFzYoxxA10
    Thanks pzinck thanked for this post
    Likes skukum12 liked this post
    Doug Budd's Avatar
    Feb 2015
    Crawford Nebraska
    167
    This another reason I am cautious about ethanol gas
    10,028
    I burned about 1000gls of ethanol gas when that was all I could get. I didn't have any problems except for a drip in the model A fuel gauge in the seat tank that I kept fixing. But I was flying every couple days. I went on vacation for 2 weeks and the plane sat during that time and the weather was wet the whole time. When I got It out to go flying I could only get about 1500rpm WOT. I thought that the muffler was plugged with a nest or had collapsed? I got a clear qt jar and drained some gas and out in the light I could see it was cloudy. Drained the tank and filled with new ethanol gas and it ran fine. I burned ethanol gas for the next 2 years but only with Startron added to it and never had any problems again. I carry a bottle of Starton in my floatplanes because sometimes ethanol gas is all I can find while traveling.
    6,959
    Do your pickup trucks have the same problem? Or is it a function of the size and shape of the tank itself?
    I have not had fuel contamination problems for over four decades. Granted, I fly every day, but my Mustang convertibles get run once a week, and sometimes sit for several months with deadly auto gas in the tank and carb. They do not seem to care . . .
    180Marty's Avatar
    May 2004
    Paullina, Ia
    2,033
    Bob, is the cap the only vent or does the fuel tank also have a vent. If you figure out where the vent is, just seal it between use. If there is not air coming and going, your problem should be solved. Like I said in the other post, the E10 fuel and oil I just mowed the grass with was mixed last Sept but the plastic jug it was in is sealed so when it was zero degrees this winter it was sucked in as the air cooled. Come spring it looked like a normal jug. If you're worried about your tank blowing out or sucking in, put a balloon over the vents.
    Doug Budd's Avatar
    Feb 2015
    Crawford Nebraska
    167
    For vehicles designed for ethanol it works great they have a sealed fuel system. for vehicles that have carburetors not so great used it in my 560 tractor and let it sit for a while ruined my carburetor. My 2004 Chevy pick up runs great on it my 1972 Ford pick up runs like crap on it.
    6,959
    My Mustangs are 1964 and 1966. I pay no attention to fuel vents, and find a carb overhaul necessary about every 20 years. Carb kits are getting scarce - usually the accelerator diaphragm goes out.
    The hose between fuel pump and carb used to be a problem, but lately I have not seen one fail. They are under pressure. The same size hose is made for Corvette fuel injection, and that hose is bulletproof. I use it under AC 23-27 for the Cubs. It was $7 a foot 15 years ago.
    Again, how come your pickups are not all stacked up alongside the road with plugged fuel filters? How come they no longer have gascolators?
    Thanks 180Marty thanked for this post
    180Marty's Avatar
    May 2004
    Paullina, Ia
    2,033
    Thanks Bob, I misread your post before and now understand your experience is similar to mine!!!!
  1. What About Ethanol?
    By Steve Pierce in forum Cafe Supercub
    Last Post: 05-01-2016, 05:56 PM
  2. 0-233 and Ethanol
    By Lasater in forum Cafe Supercub
    Last Post: 09-26-2012, 04:40 PM
  3. Ethanol
    Last Post: 01-31-2005, 02:09 AM
  4. Ethanol in N.Y. Mo Gas
    By scubber in forum Cafe Supercub
    Last Post: 01-03-2004, 07:58 AM
