Page 2 of 3 FirstFirst 123 LastLast
Results 41 to 80 of 102
Thread: 185 vs Supercub
  1. #41
    Jan 2017
    King Salmon, AK
    52
    Ha, I don't think he does. Pretty sure he is on his 3rd engine in his 180. Its bare bones at 1800# and a carbureted 520. This year in Port Alsworth Fly in he had a 83' takeoff 10 kts of wind and my cub was 103'. Granted I was still pretty new but he is one hell of a Cessna driver. Almost makes me mad what he can do compared to my cub...
    On another note, the biggest plus I see to the cub is the ability to get into the tight spots but they really shine in the soft or rough stuff. Looking at energy distribution to the gear legs of a 180 vs the TK1 shocks on an exp cub is night and day. Plus I can taxi through and land with 35s at 4.5 psi way better than a 180 on 31 will do.
  2. #42
    9,268
    Quote Originally Posted by JohnnyR View Post
    Does he give lessons?
    J
    Just takes practice and a feel for the plane. Lots of practice, then more.
    You must fly the plane controlled on approach right at the lowest speed you can, and hit the spot perfect every time.
    I would be at 50 mph indicated on final, then slow to 40 short final and be holding brakes at touchdown. The tail is buffeting slightly, as in the yoke oscillates quickly forward and back a bit when that slow.
    You also have to be current in the plane, and have good air. Takes practice, and practice.
  3. #43
    Aug 2015
    ME, ID, AK - what time of year is it?
    480
    Practice, practice! I'm putting time in the saddle, slowly & carefully exploring the limits, trying to get the judgement along with the perspective and muscle movement. Just wish someone would pay me to do this!
    The Skywagon sure is a different beast at or near gross. While mine is 1,850 empty, it feels relatively light and responsive in the sub-2,000's compared to 3,200. Wallows like a water buffalo full of inertia.
  4. #44
    9,268
    That is heavy compared to what I had. My memory is 1620 or so empty. Horton Stol, no vg's.
  5. #45
    algonquin's Avatar
    Apr 2013
    Seldovia,Ak
    979
    I had a 56' that weighted about 1630 pure stock and at gross you could. Slow to 45 mph on short final, and at 42 it would land short in a river ,lol, or so I'm told. 6" of water and three feet or so short. After that I set the limit to 45 on approaches. I now have a 185 with a much higher gross but the speeds don't compare at all. I miss the 56' but no range with small tanks, still love flying the wagon.
    I can't wait to get my Husky done to play in the bush!
  6. #46
    Aug 2015
    480
    What are your stall speeds at ~3,000? I realize every airplane is different, but am curious. My perception is that my '73 is essentially an underpowered 185 in terms of flight characteristics. Hence the hunt for a big motor option. Thus far PPonk seems the best fit.
    J
  7. #47
    9,268
    The early models grossed out around 2,600, (been years since I looked at that number). Later models had beefed up wings and stiffer gear.
    Which tail do you have?
    No matter what you do to your 73, I don't think it will ever be the STOL plane the early models were. The control feel of the late models are that of a 206- when our DO flew the 185 for the first time she had a hard time pulling up because the force was way beyond what she was used to, and her brain was saying DANGER! That was just normal.
    Early models have control forces that of the 172s, light and nimble.
    For light and nimble you give up beef in structure, which means gross weight and strength.
    Great planes, but different.
  8. #48
    5,129
    Don't worry Johnny, your '73 will do fine. It just needs a power boost to let it comfortably get out of places it can get into.
  9. #49
    Aug 2015
    480
    185 tail w/ upgross to 3190. Don’t think I would have bought one without it, as our mission frequently requires 1,000+ lbs payload.
    Disconnecting the elevator return spring made a huge difference and it is now balanced and light. Not required for land planes, per Cessna MM.
  10. #50
    Aug 2015
    480
    Hoping for it this November! I have to talk to you about that Acorn exhaust...
  11. #51
    5,129
    There it is. Smooth flowing risers and collector running to a gutted muffler. The seaplane tailpipe is gusseted and the shroud is dammed off to vent that pesky crack area and not include it under the shroud. My old exhaust had the leaky clamped joints. This is a big improvement for leaks and the performance boost is a bonus.
    Thanks JohnnyR thanked for this post
    Likes JohnnyR liked this post
  12. #52
    10,000
    J
    This is less $$$ than more horsepower and gives improved short field landing performance with the throttle closed as well as take off, climb and cruise. https://www.wingxstol.com/html/products.html
  13. #53
    Aug 2015
    480
    I hear ya. However, I’m going to need a new engine shortly (low compressions and high time don’t justify just a top overhaul)and the delta between a well built 470 and the PPonk is likely less than the cost of WingX plus install. Either way, I need a new engine and since we fly heavy, high and short, with the promise of skis next year and floats in the summer, the HP increase just makes sense...
    J
    p.s. Shorter landings with throttles closed are news to me. How’s that occur? I’ve experienced the opposite and can land on the spot I want by dumping power held through final. Maybe another thread needed for that discussion...
  14. #54
    10,000
    Simple, more wing area, lower stall speeds, same (throttle closed) power, less runway required.
  15. #55
    5,129
    So why did you add a 550 to your own plane? It appears you subscribe to the power component. Just not for others?
  16. #56
    10,000
    Don't be arrogant stewart, My plane has had wing extensions and drooping ailerons for 35+ years. I made my own before the STC products were available.
  17. #57
    5,129
    I wasn't intending to be arrogant. It was a question.
    A 180 will land shorter than it'll take off. Horsepower is the best solution I know to equalize that. The heavier the 180 the more it helps. My own 3190# 180 needed the power boost to make the capacity useful.
  18. #58
    10,000
    I'm always in favor of the most horsepower one can practically install taking into consideration weight and balance. You can always pull the power back for economy purposes, but you can't push it further if you need it. Some, like the Lycoming TSIO-540-J2BD in the 185 are too heavy to be practical as they become too nose heavy requiring too much ballast. They do go upstairs fast though and they do love gasoline.
  19. #59
    Aug 2015
    480
    Are we talking about power off approaches? How can you land precisely with power off during final/short final?
    I ask because in short strips or off airport zones that don't give much leeway for error, a power-off approach leaves too many uncontrolled variables on the table for me, not least of which is the ability to control my glide path with precision. At least when flying a power on, stabilized approach you will have precise control over approach path, descent rate, and touchdown speed. And, how do I compensate for wind gusts, lift, sink and turbulence with the power off?
    My plane stalls at slower speeds with power on than power off. Doesn't yours?
  20. #60
    5,129
    I'm always in favor of the most horsepower one can practically install taking into consideration weight and balance. You can always pull the power back for economy purposes, but you can't push it further if you need it. Some, like the Lycoming TSIO-520-J2BD in the 185 are too heavy to be practical as they become too nose heavy requiring too much ballast. They do go upstairs fast though and they do love gasoline.
    I've never flown a 350hp Skywagon but it sure sounds like fun. Last I looked, Wup Winn had a Maule listed on his webpage with that 350hp motor. That would be a monster!
  21. #61
    10,000
    I'm not talking about piloting techniques, only airplane capabilities. Point being that in the landing phase, like airplanes will be the same no matter what the horsepower is. The one with the longer wing will do better landing. Take off is where the horsepower shines.
    Likes DENNY liked this post
  22. #62
    Nov 2006
    14
    Can you enlighten more on the legality of disconnecting the elevator return spring on the late model 180’s? When I enquired about doing this I was told “cant be done”?
  23. #63
    5,129
    He may be confusing it with the rudder centering spring that's part of the float kit.
  24. #64
    Aug 2015
    480
    Perhaps I am...
  25. #65
    10,000
    Quote Originally Posted by jagunson View Post
    I had one of those elevator springs break one time. It didn't fly very well without it.
  26. #66
    Dave Calkins's Avatar
    Jul 2002
    Anchorage, Alaska
    5,404
    Pete, I always equated the relatively heavier pitch forces of the latemodel 185's with that spring.
    Can you say a bit more about this and also why it didnt fly very well without it? thanks.
  27. #67
    10,000
    Dave, It was a long time ago and all that I can remember is that the elevators became so light that it seemed too light and perhaps too easy to over control.
    Are you saying that the older ones don't have this spring? If so, perhaps it became necessary when the bigger engines were installed in order to pass the balked landing test. It would help the pilot in pushing/holding the nose down when applying full power.
  28. #68
    Jul 2002
    Anchorage, Alaska
    5,404
    One early 1 I know of does not have it. I will check a parts book.
    I suppose it couldve been for the balked landing flight test, But full nose up trim provides the least tension on that spring. And thus the least assistance in that mode.
    Thanks Skalywag thanked for this post
    Likes Skalywag liked this post
  29. #69
    Aug 2015
    480
    Stancil's old "history of the Skywagon" tells me that it was introduced in the 1960 C model.
    "It was designed to improve longitudinal stability" and, per our maintenance manual, is supposed to be adjusted so as to "not induce any load on the elevator push-pull tube until the elevators pass through the zero degree (streamlined) position relative to the horizontal stab."
    It gives the truck-like feel and is a bear to hold full back stick during taxi for any extended period.
    Likes Bill.Brine liked this post
  30. #70
    10,000
    Then the balked landing is not the reason. That was just a quick thought. I'll have to look more closely at it.
  31. #71
    Aug 2015
    480
    I'd wager it was done to prevent pilots from over-rotating on takeoff as well as stalling during arrival -- a constant reminder of what to do... or not do, I guess. I'm not a fan.
  32. #72
    10,000
    I just looked in the parts manual. It is on all 180 and 185. Perhaps it is for adequate nose down trim at aft CG? Just like the Cub uses an up cable/spring for nose up trim.
  33. #73
    S2D's Avatar
    Montana
    4,155
    540 ? perhaps a typo
  34. #74
    10,000
    You're right, corrected.
  35. #75
    Jul 2002
    Anchorage, Alaska
    5,404
    It is not on all 180's Pete.
    The Skywagon 1 I flew had other anomolies, maybe it shoulda been on it. Great airplane without, tho
  36. #76
    10,000
    The parts manual doesn't specify 180 or 185 nor any serial numbers.
  37. #77
    Aug 2015
    480
    You're probably looking at the 3 FEB 1997 PM from the skywagons clubsite. Bet if you had one of the superseded pre-1960's PM's, you'd find that spring missing.
  38. #78
    10,000
    No, this is the expensive hard copy from Cessna of that same date.
  39. #79
    Aug 2015
    480
    Fancy! But the earlier pages would still have been pulled in the superseding PM...
  40. #80
    180Marty's Avatar
    May 2004
    Paullina, Ia
    2,051
    My 54 180 doesn't have any spring on the elevator system and never did. Early ones didn't. According to my parts book the spring on the elevator was for serial 50662(1960 yr model) and on. 182's were 52359 and on.
