Page 3 of 5 FirstFirst 12345 LastLast
Results 81 to 120 of 195
Thread: Catto Propellers On Certified Super Cubs
  1. #81
    Dec 2007
    21
    Cubs with 3rd seat mod can't have a catto. Thats a bummer!!!
  2. #82
    2,091
    Quote Originally Posted by Fowlplay View Post
    Unazz the STC if that's a problem.
  3. #83
    txpacer's Avatar
    Jun 2011
    Iowa Park, TX
    720
    Leave out the seat belt attach fittings
  4. #84
    DJ's Avatar
    Jan 2009
    Bolivia
    210
    It's not a seat it's a baggage compartment
  5. #85
    Colorguns's Avatar
    Dec 2013
    Bloomfield NY
    350
    AC 35-1 12/29/08
    j. Fixed pitch wood propellers of conventional design. A propeller that has the following physical properties:
    • One piece laminated wood construction
    • Two or four blades
    • The surface coating does not contribute to the propeller strength
    • The surface coating only provides environmental protection
    A fixed pitch propeller with a composite shell over a wood core is not a conventional design when the composite shell contributes to the strength and frequency response of the propeller. A fixed pitch wooden propeller with a fabric or composite covering that does not alter the structure for environmental protection is of conventional design.
    It in the third n forth line. Surface coating that get you.
  6. #86
    9,971
    Quote Originally Posted by CattoProps View Post
    Although the prop is over 50% wood by volume it's not considered a "wood" prop reason being the composite is the structure. The wood cannot exist without the carbon and the carbon cannot exist without the wood.
    Quote Originally Posted by Colorguns View Post
    Yes until CattoProps provided us with the above statement, we didn't have the definitive answer.
  7. #87
    19,341
    I had called the Anchorage Aircraft Certification Office to see if anyone had recorded the webinair they did on props about a month ago. They called yesterday and I was on a conference call with two of the engineers there. Seems that drew at Above Alaska got this whole ball rolling when he wanted to get a Catto prop approved on the Airman raffle Cub. The Super cub is considered a Class I airplane according to the new Part 23 rewrite which means it is a single passenger aircraft. With this rewrite a prop dos not have to have a Type Certificate to be installed on a Class I aircraft as long as it meets the ASTM standards for light Sport aircraft, meets the CAR3 over speed tests and the engine manufacturers rpm ranges and proper prop to ground clearance. There were two expensive tests that were dropped in this Part 23 rewrite. One was the lightning test which probably wouldn't apply to a non-metal prop anyway and the other is the bird strike test. It does have to go through a 50 hour continuous run test and a similar test on a prop with repaired damage. there is also a flight test which can be done in a day. None of this was specific to the Catto prop because they could not speak of any specifics on anything in the works right now but I believe it is safe to say that is what is in the works. It was an educational conversation and I really appreciate them taking the time to get me up to speed on the process. Thought I would pass this information on to the rest of you that might find it as interesting as I did.
    Hope to eliminate more of this.
    Likes WanaBNACub, Hardtailjohn liked this post
  8. #88
    May 2011
    Eagle River
    269
    Thanks for checking on the Catto progress.
    Ya, filing down the prop is not the best weight lose method for a cub.
  9. #89
    Aug 2009
    Nikiski , AK
    380
    Got this message from Nicole yesterday.
    Hey! Saw the thread on SuperCub.org. The rewrite will only cover "simple aircraft" so many two seat aircraft under 250mph. So unfortunately the PA-20/22 and PA-12 won't be covered.
    So the PA22/20 colt can be covered. It is only a 2 seater. ?
  10. #90
    Meanwhile,...
    5,200
    Hope to eliminate more of thiClick image for larger version.
    Ouch, that looks like my brushhog blades
    Likes 180Marty, RaisedByWolves liked this post
  11. #91
    Dec 2016
    5
    Yes, if the P20/22 only has two seats it should fall into the simple aircraft category.
  12. #92
    3,563
    actually... the PA-12 has ONLY TWO seats... the back seat, just happens to be able to accommodate 2 passengers with using ONLY the ONE lap belt....
    I bet that will fly...
    The TCDS states "Number of Seats 3 (One at +6 and two at +34)Only one person permitted in rear seat when operating in Utility Category"
    If the plane were placarded "Utility Category only" or "only one person may occupy rear seat", would that permit the Catto?
  13. #93
    pa11driver's Avatar
    Mar 2010
    106
    [QUOTE=If the plane were placarded "Utility Category only" or "only one person may occupy rear seat", would that permit the Catto?[/QUOTE]
    I don't believe there is a utility category anymore in the rewrite. Not sure how that plays with airplanes that are already certificated under old regs.
    I'm pretty disappointed about how this looks like it's going to shake out. Once again I'm left out high and dry when it comes to my PA-14....
  14. #94
    Meanwhile,...
    5,200
    Quote Originally Posted by pa11driver View Post
    Bummer but look on the bright side, there will be a plethora of used black props for sale when legal Cato's comes to market. Oh and by the way did I mention that mines in perfect condition especially compared to that gravel buster of Pierce's, but if that won't work well I've got a gray one as well.
  15. #95
    9,971
    How does the Part 23 rewrite apply to Part 3 airplanes? Once the prop is approved under the Part 23 rewrite it will be an approved prop. Then it should be a simple matter to install on Part 3 airplanes.
  16. #96
    pa11driver's Avatar
    Mar 2010
    106
    My understanding is that the certification standards for propellers on "class 1" airplanes (up to single pax) will be lower than class 2. So it's not as simple as being either Approved or not under part 23.
    Thanks white mountain thanked for this post
  17. #97
    Apr 2009
    AK
    114
    Got this in the mail last week- not sure if this went to all AK IA's, or just our area... sorry- not sure why it rotated...Click image for larger version.
  18. #98
    Apr 2009
    AK
    114
    Then received this in an email today:
    To All,
    I just wanted to follow up with a brief explanation on the CATTO Propeller letter. Please understand it’s an informational sharing letter, and not targeting anyone. Our ambition is ensure aviation safety. You all are an extension of the FAA and hope we all can work together.
    I believe in the FAA Compliance Philosophy, working together through issues and conversations, not enforcement. I apologize to any of you if I said something that might have miss-represented myself.
    Attached is some guidance that might help and the National Compliance Philosophy Flight Standard is promoting.
    Thank you,
  19. #99
    9,265
    Seems to me there is a shortage of Sensnich and McCulley stickers out there
    Likes RaisedByWolves, AKCRUISER liked this post
  20. #100
    2,091
    ...and several Catto pre-approval props suddenly for sale. Shake the bushes and bugs crawl out. Hope they get it all taken care of and approved soon.
    Likes cpa99 liked this post
  21. #101
    Meanwhile,...
    5,200
    Because fraud is always such a good approach to regulation...
    Likes mike mcs repair, moneyburner liked this post
  22. #102
    Aug 2009
    Nikiski , AK
    380
    So from reading this , I think we got a skunk in the nest, FAA lurking in the dark. In the name of "SAFETY" its ok on a experimental but OMG you cant put that on a certified real one. When it comes to logic they FAA is in the toilet.
    JOHN PERRY
  23. #103
    10,812
    Quote Originally Posted by eskflyer View Post
    JOHN PERRY
    That is a pretty ridiculous statement. I would hope that most of us understand the difference between certified and experimental. There are lots of things that MAY (or may not) work just fine on experimental aircraft, as far as we know, but can't be used on certified.
    i can think of one case years ago that involved several folks using a certified propeller on engines that the prop was never approved on. A mechanic pushed the propeller manufacturer to do a vibration survey on that prop/engine combination. They found some serious vibration issues, which were then solved by shortening the prop and adding a harmonic damper.
    in that case, if those gents had been running the prop on an experimental, it could have ended ugly. But that's part of the deal with experimental....we are allowed to experiment.
    Mr. Catto's props have not been certified yet. I have no doubt they will be at some point, maybe in their current form, or perhaps modified. But, for the moment, they are only approved on experimental aircraft. That is not the FAA's fault, but the FAA is tasked with ensuring the safety of certified aircraft.
    i hardly think any of us are being harmed in any way because we can't use a Catto prop on a certified aircraft.
    And, how fair would it be for the FAA to have required McCauley and Sensenich to have met the certification standards, but to permit Catto to skip them?
  24. #104
    Aug 2009
    Nikiski , AK
    380
    I am not advocating putting experimental parts on certified planes. Let's look at how many of these are out there . What better testing ground is there. Instead of just saying not airworthy. Let's see the failure rate or what issues . If any. Heck hook up a dynavibe and go fly . Look at the harmonics. Don't crush something good. Something that is working. If your gonna say it's not airworthy on certified how can it be airworthy on experimental.
  25. #105
    Sep 2010
    23
    By definition, they're not "airworthy" on any aircraft. Look up the difinition of airworthy in 14 CFR part 3.5(a). To be airworthy they'd have to (1) conform to an approved type design, and (2) be in a condition for safe operation. We all know they don't conform to an approved type design.
    Thanks eskflyer, Jim Hann thanked for this post
    Likes moneyburner liked this post
  26. #106
    May 2017
    648
    That would be fine if you surrender your Standard certificate, and decertify your airplane as Experimental Research and Development, because that is exactly what you are doing, R&D.
  27. #107
    Idaho
    222
    Is the Catto prop an improvement on the 0-360? And if so, which model?
  28. #108
    Jan 2005
    Fowler, Ks
    561
    Craig Catto estimated certification in 4th quarter 2017 this last summer... Just got a note from Nicole, she said they are still chipping away and looking to be certified by late spring 2018.
    A question?? I have a Catto that is sitting on the shelf...Craig said it is identical to the upcoming certified prop...field approval?? I guess it's a FSDO question but I would think.... but since it wasn't built with FAA oversight ....but if they won't approve a identical prop then field approvals are likely a thing of the past.
    anyways, just a update.
    Steve
    Thanks KevinJ, OLDCROWE thanked for this post
  29. #109
    PerryB's Avatar
    Aug 2007
    Chico, CA
    1,943
    Quote Originally Posted by flynlow View Post
    Steve
    I hope they finally succeed. They've been after it for a long time. About 4-1/2 years ago I asked Craig his thoughts about getting a pre-cert. prop approved after the fact and he wasn't very optimistic.
  30. #110
    algonquin's Avatar
    Apr 2013
    Seldovia,Ak
    976
    I just read thru this and a note on the PA-12 , mine has a airwort cert. that state utility which makes the -12 a two seat aircraft .
  31. #111
    Feb 2006
    269
    I'm not trying to be the butt hole here, i have seen, waited, sign up, talked too...yaddad, yudda. On the catto props be cert for super cubs. Are we being played? Or just to impatient to have the process completed. I see a sign up sheet at Stoddards. What a joke. They had one started at the airman show "what" 2012, or 2014....I'm just positive they still have that list for the fools still waiting. NOT. I'll believe it when I see it.....but to be fair here, i have one on my cub and like it. But being played a fool for this meny year's? I think not....Scott
  32. #112
    19,341
    It was announced at the Airmen Show last year. Up until that point Craig was not committed. Had many conversations with Craig, Nichol and Sarah as well as the FAA ACO engineers in Anchorage. They have more business than they can keep up with as it is so I am sure it is not top priority.
  33. #113
    May 2017
    648
    Normal time for an STC is 2 years from application to issuance. Normal time for a TC and PC is about 5 years. Since they need to get TC & PC, then STC, I would think somewhere between 4 & 7 years is not out of the question. The wheels of progress (and the FAA) go slow!
  34. #114
    19,341
    This is a little different with the Part 23 rewrite and the fact that the FAA sees the Super Cub as a simple 2 place airplane. Less hoops to jump through than a full blown STC according to the two ACO engineers who called me about it.
  35. #115
    Feb 2006
    269
    I concur with both post listed above, but would add " they" have been telling us next year, soon, where working on it, sign up on the list to be first for what 5,6,7 plus years now. I'll take all bets the list I sign up for a cert prop at the airmans show in 12 and 14.....are not to be found. Unless you check the land fill. Scott
    Thanks Bowie thanked for this post
    Likes Bowie liked this post
  36. #116
    19,341
    I think if you go back to the beginning of this thread that was the first Catto announced anything. They had a questionnaire a few years ago and that is all I have seen. I have been following this whole Catto prop thing for many years and looking for a legal solution for my certified Super Cub and having been around this stuff for way too long don't tend to look at things through rose colored glasses.
  37. #117
    Feb 2006
    269
    No rose colored glass here, I'm a realistic, to be blunt, i know it takes time, but we have been snow ball or strung along with there own words and actions. It is not I or your self with the unknown statements of soon, next year, sign the list. Year after year. Bottom line, if you don't know when it will be Done? Then say so. It's a cruel if not being played the fool to sign any more list. But if it make some feel better. Feel free to sign up another year of a cert prop that's pending again and again...I'll not waste my time ...Scott
    Thanks Redwagon thanked for this post
  38. #118
    19,341
    I guess I have missed the list and any statements from Catto on any dates. Where is this information?
  39. #119
    19,341
    I guess what I am saying is that I look at all this stuff as it will happen when it happens. It seems to take a long time be it a prop, battery, new fabric system, shock etc. That is why experimental is so nice.
    Likes DENNY, Hardtailjohn liked this post
  40. #120
    gbflyer's Avatar
    Feb 2007
    PAGS
    736
    Damn fellas, unless they've taken your money to produce a prop on a certain date, I don't think you have any gripe coming.
    Sorry...Winter is getting to me.
    Likes aktango58, hotrod180, mike mcs repair liked this post
  1. MT Composite Prop certified but Catto not certified
    By slowjunk in forum Cafe Supercub
    Last Post: 04-11-2017, 06:15 AM
  2. Replies: 21
    Last Post: 11-03-2015, 11:32 AM
  3. IFR certified Super Cub
    By Paul Siegel in forum Modifications
    Last Post: 10-14-2002, 11:00 AM
