Another way to look at it is that it is a quarter wave antenna that you pull out of the box, BUT there is no such thing as a quarter wave antenna. There are only, as a minimum, half wave antennas.
Therefore, it is up to you to turn it into a half wave antenna by adding the other quarter wave portion. You do that by mounting it to a ground plane . The ground plane does not have to be of a resonant radius because there only has to be one resonant element in your antenna , preferably the one you are feeding so that you can impedance match the feed to the antenna by using it as a matching transformer....the RF current, and therefore the magnetic portion of the electro-magnetic signal, is maximum right where the two elements join, so you need to make sure it's a good connection.
In order to radiate, the resonant part needs to be CLEAR of all other conductive structure, otherwise, everything within several wavelengths becomes part of your antenna circuit. A very lossy part. It de-tunes the antenna, causing power to be reflected back to the transmitter, heating it up. All of the steel near your antenna conducts part of the signal and due to the fact that it IS NOT copper, turns it into heat. Worse yet, it tends to act as parasitic elements, reflecting power in many weird directions, and NOT in the direction you want. The radiating element, the one you pulled out of the box, has to be CLEAR of surrounding metal structure, in line-of-sight to the satellite. If you mount it inside, the structure directs the signal in whatever direction it wants, and if the fuse is covered in metal-doped fabric, one TENTH of your power will make it through, just from the fabric attenuating it.
The path loss fade margin to the sat is approximately 35 db , so if you want to use it up doing stupid stuff, then go ahead. It's there as a safety margin. Treat it with respect.
Sheesh, I thought this was going to be short....and simple...
