Results 1 to 24 of 24
Thread: PK3500 B or C?
    Sep 2014
    Palmer Ak
    27
    PK3500 B or C?
    I've been looking at PK 3500 floats for my 185 and I've been told the Cs perform way better than the Bs or As. Is there any truth to this? If so what's the difference? I previously had 2960s and still have the rear blocks on the plane, do the PKs require different pork chops and rear blocks? Thanks.
    11,430
    If the pork chops and rear blocks are not with the floats be sure to reduce the amount of money that you give for the floats. Those parts are part of the float installation. Too often when a plane is sold separately from it's floats these parts disappear creating an issue and needless expense for the new owner of the floats.
    11,702
    What Pete said regarding the blocks.
    As to your other question, yes, the PK 3500 C floats perform MUCH better than the A and B model 3500s. The floats are really very different in design, with less V to the bottom, wider decks (if I recall).
    I flew a C 185 on the early model amphibs for several hundred hours. It was a humbling experience, but a good learning experience. You really have to be on top of your game to get those early floats to perform, and loads are critical. Essentially, you spend a lot of time praying for wind. I flew one 206 on these early floats and a friend mentioned to me one day after watching me depart: "You know, if it barks like a dog and drools like a dog, it might actually be a dog." Best compliment that plane got.
    In 1986, I was given the keys to a brand new 185 mounted on late model PK 3500 C floats (straight floats). I groaned, but as I gained experience with the floats, I began to realize that their performance was MUCH better than those 3500Bs.
    ten years later, I parked that plane on a mountain after the crank broke. The replacement 185 was equipped with EDO 3430 floats, which had always been my favorite float on these planes. I quickly realized that this plane got off the water with the same loads in almost exactly the same spot the plane with the PKs did.
    The key with the PK floats is learning to fly them. The sweet spot on step is very narrow, and can be hard to find and hold initially.
    But the PK 3500 C floats are good strong floats with good performance.
    Alex Clark's Avatar
    Feb 2004
    Life Long Alaskan
    3,247
    The A models really stink. A local 206 was stuck on them and it struggled to get out of the water in the best conditions.
    To me, the older PKs were salt water floats made for lots of room to take off and rougher (denser) water. As Mike said the C models are a different float.
    9,594
    Which is to say if you plan on abusing your bird in rough water all the time, might consider the early models.
    If that is your desire, also want to buy a case of sealant for the windshield.
    Alex Clark's Avatar
    Feb 2004
    Life Long Alaskan
    3,247
    No that is not what I was saying....It just seems to be what they had in mind back when they developed and tested the older models. Deep V, thicker skins, long take-off runs and a touch of nose-up AOA on the wing compared to the float deck. If you are stuck with an older model of the PK floats they will not seem all that bad when operating in salt water. They stink in calm fresh water.
    Plenty of 185s and 206s work in salt water until corrosion gets the best of them.
    The newer PK models are a general all-around improvement and the market value reflects that
    Although it is a good idea to check the installed weight compared to other manufacturers, since PKs tend to run heavy.
    Which is to say buy the best float model you can afford for your mission and circumstances. Personally, now that I have flown various mods, I would avoid buying the older PKs.
    11,702
    Bear in mind that the older 3500s were built by DeVore Aviation.....located in New Mexico. Lots of float ops around that neck of the woods.....
    The 3500 C and D floats are great floats in any case......a product of Maine.
    Alex Clark's Avatar
    Feb 2004
    Life Long Alaskan
    3,247
    The Great and Giant Lakes of New Mexico.... All you need is a time machine
    C-FIJK's Avatar
    Jan 2005
    Lewisporte N.L.
    424
    Here Buy These 3500L AEROCET FLOATS • $23,000 • AVAILABLENice set of 3500L Aerocet floats and rigging off of a 185. Located in Selkirk, Manitoba • Contact Kris Milbrandt , Owner - located Corman Park, SA Canada • Telephone: 306-321-5684 . • Posted May 9, 2017 Show all Ads posted by this AdvertiserRecommend This Ad to a FriendEmail AdvertiserSave to WatchlistReport This Ad
    Quote Originally Posted by 7GCBC View Post
    Alex Clark's Avatar
    Feb 2004
    Life Long Alaskan
    3,247
    Pee-Kay started out in International Falls Minnesota back in the mid 50s with Pete Kelner. In 1964 is was sold to Kurt Converse who was killed 4 years later. Then Gil DeVore ( who had helped design and build the K-3500 series) bought the company in 1968.
    In 1970 the manufacturing was done by Aero-Fab in Sanford Maine. Aero Fab was making the Lake Amphibs back then. My PK-2300s were made in Maine by Aero Fab.
    In 1988 or 89 production moved to Albuquerque, New Mexico.
    In 1999 the company was bought out by Alton Bouchard, who moved the manufacturing back to Maine. He died around 2013 and a skeleton crew stayed in place selling parts.
    In 2015 the remains of the company were bought by SR Aviation and they are now back in business.
Name:	2012-12-31 002 (1024x711).jpg
    Likes C130jake, DENNY liked this post
    11,430
    Kurt was killed in an autogyro crash near New Bedford Mass.
    Alex Clark's Avatar
    Feb 2004
    Life Long Alaskan
    3,247
    Turns out my PK-2300s were made in 1976 or 1977. So I have 41 year old floats on my 41 year old plane.
    Skycop's Avatar
    Jan 2009
    Hibbing, MN
    308
    I have a set of B's with pork chops and blocks. Good condition...Cheap.
    Ryan
    218-969-7786
    Sep 2014
    Palmer Ak
    27
    Anybody know the difference between B's and C's?
    11,702
    The A and B floats were one design, the C and D floats were a somewhat different design. The B's are straights if I recall correctly. The C's are straight floats as well. The later 3500 floats (C and D) have less V in the bottoms, and designed in "hydro boosters". Many of the early floats (A and B) had hydro boosters added to the forward bottoms as well in an attempt to improve performance, with limited success. There are other differences....essentially they are completely different floats. And the performance is also very different.....the A and B 3500 floats are really poor performers. The 3500 C floats actually perform quite well, but they require a bit of practice to figure out how to make them perform heavy. Once you figure that out, the C's will perform about as well as any float of similar size off the water. They are also really tough floats.
    3,020
    I mentioned somewhere else my dislike for early mid-70's PK3500's. Doggy off smooth freshwater and want to drop the bow on landing as the wetted area increases. Looking today at a nice set of later 3500's on a 206 it appeared they have a visibly variable bottom dead rise...not sure if the early ones did as well. Relatively steep sides at the bow that laterally flatten as they reach the step, plus the usual adornment of boosters.
    I should get off lazy tomorrow and take a pic to show what I think I saw. The dog was eating a fresh caught vole so I was soon distracted.
    11,702
    Gary,
    Yes, I believe you described one of the primary differences with the later floats. I didn't know quite how to describe the bottom geometry, but that is the big difference from the older floats.
    Still chasing those Airdales, eh? I'm working with an eight month old Brittany.....a piece of work there.
    Aug 2015
    AK, ME, ID - what time of year is it?
    643
    Anyone know if the post-2018 PK 3000’s have changed since the “C” variant?
    11,702
    Quote Originally Posted by JohnnyR View Post
    The 3000 PKs are an entirely different float than the 3500s being discussed here.
    Aug 2015
    643
    Not sure how I got my wires crossed, but obviously posted in haste.
    Likes mixer liked this post
    TurboBeaver's Avatar
    Jun 2009
    Northern Maine
    920
    Although for strange reason , probably because of the poor performance of the early 3500's. One of best 185
    Performance Floats ever offered: the PK 3000's; have never caught on in Alaska. These and the sister model 3050 Amphibs are excellent performers, this has been
    demonstrated dozens of times: at the "Seaplane Fly In" ever fall in Greenville, Maine. Both the latest models of the 3000 and 3500 series feature twin hydro boosters instead of just one on most conventional designs. When we flew out
    the open ocean out of Nadi Fiji, it brought new meaning to
    The term " rough water"! We had Whips , Edo 3430's and PK's. The PK floats stood more than the 206's could stand!
    The cabins would streach and twist enough that after a 1000 hrs, none of the doors would stay closed when landing in big stuff........ The ONLY float that was there in the end were PK's. The 3430's would pound and streach the rear cross wires out till they would bottom out in the yokes, we had a huge pile of discarded cross wires in the back of the hanger. Don't forget the Aerosets are basically a direct copy of 3430 Edos but composite.
    11,430
    I agree with TurboBeaver. Back in the days when the PK 3000s first came out I was competing at Greenville with my 185 on EDO 2960s and doing very well. Got the champion trophy. The PK 3000s gave me a run for the money. I did beat them, but not by much. They are a good float, not at all like the PK 3500s. I would have no reservations in installing a set.
    The PK 3500s are great in really rough water, not so good in smooth water. They get on the step quick enough in smooth water, but then do not accelerate as quickly as the EDO 3430s. I had a 900 foot pond which I used for launching floatplanes. The PK 3500s are the only floats which I thought were going to kill me. I made it with a 206 using trickery, but not by much. The EDOs went out of that pond with no issues.
    Aug 2015
    643
    Well, sorry for switching this old 3500 discussion over to a “new” 3000 discussion. Sure appreciate the input, though!
    11,702
    For the record, I've only flown one 185 on PK 3000s, and didn't fly them a lot. But, I was very impressed with them.
    The later model PK 3500s would do just about as well as EDO 3430s, but in rough water, PK floats are king.
