Page 1 of 2 12 LastLast
Results 1 to 40 of 54
Thread: Broken Jackscrew
    Todd long's Avatar
    Apr 2015
    Minneapolis
    107
    Broken Jackscrew
    So not mine, but a friend had this happen today while out flying. Said he noticed a vibration then some flutter. No doubt, right? Lucky as hell I'd say. Anyone else had this happen? Pa-12
    PerryB's Avatar
    Aug 2007
    Chico, CA
    2,017
    From the picture it looks like the lower bushing and the yoke don't line up very well.
    Todd long's Avatar
    Apr 2015
    Minneapolis
    107
    Appears that way. But that is just from the tension still on the trim pulley.
    11,733
    i've only seen them bent from accident.....
    maybe someone tried to straiten a bent one somewhere in it's past??
    Jul 2009
    racine,wi
    684
    My banner cubs get new ones every 500-700hours depending on how big the signs are.alot of times you look back and horiziontal is moving a lot,a blurr.but never had one break.
    3,623
    Is there a possibility that the flutter occurred before the break? Maybe that is what broke it?
    PerryB's Avatar
    Aug 2007
    Chico, CA
    2,017
    Or it could be 70 years old......
    n40ff's Avatar
    Oct 2009
    WV
    986
    There is vibration and there is actual aerodynamic flutter. If you can come home and suggest that it might have been flutter, it might not have been?
    But then again.......I wouldn't want to try to duplicate it again to find out if it really was. I'd be happy to get home!
    11,733
    are the bolts from the yoke to the stabilizer mount tube free moving? not binding?
    Dec 2015
    252
    Yep, I had one break on me towing a 65' tall panel, big ass banner, had to fly wide open the first hour til i burned off some gas, over the jersey shore and it broke, trim was stuck til i landed but noprob flying. Pa-18
    Thanks MainlandCub thanked for this post
    Jun 2007
    New Zealand
    491
    We have a local AD to inspect these for cracks every annual. They broke a few in the topdressing days I understand.
    Andrew.
    #JoeM8848 #JoeM8848's Avatar
    May 2019
    WA
    4
    Broke recently, but didnít know it at first because in the neutral trim position and just didnít move the stab when turning the handle- fully separated when we took it out of the water and was bounced around by the float truck- new Dakota parts on the way.Click image for larger version.
    PerryB's Avatar
    Aug 2007
    Chico, CA
    2,017
    Well then..... mine broke this morning. I was out goofing off around the valley and it was a beautiful morning. When I got home I decided to make a "carrier" landing, by which I give it about 5 turns up and carry a little power. I can really drag it in that way. Also good for the tailwheel only exercise. Anyway, it didn't perform as expected and touched down in a perfect 3 point at normal speed. Kinda disappointing, but wasn't dwelling on it. As I was rolling out I returned the trim and casually glanced down at the indicator button, which was now all the way forward. My first thought was that the indicator wire had broken. When I got to the hangar, the leading edge of the H.stab was all the way up. At this point things are feeling a little Twighlight Zone-ish, until I pushed down on it and realized what had happened. I guess flight loads kept it in place (down) until after landing when the elevator bungee pulled it up. I don't understand how it broke yet. I keep the threads lubed and it cranks very easy and smooth. I had the screw and yoke replaced 7 years ago at rebuild and it doesn't get used much except when making the aforementioned carrier landings and at annual when it gets a full range. This is strictly a land based plane hangared in the northern Sacramento valley. No salt, modest humidity. It'll be interesting to inspect the break when I get it out. -- I'll probably just replace the screw since the yoke is fairly new and has little usage. Any suggestions to expedite the job are appreciated. Yes I am going to zip-tie the cable to the pulley in a couple places.
    Jan 2016
    Eagle River, AK
    100
    Think the Charlie Center tail brace would help prevent that? I'm building a 180 PA-18A and heard the 180 really shakes the horizontal. Don't need to add any more weight but I'd rather have something of value in the tail instead of lead.
    20,371
    Please post some pictures.
    PerryB's Avatar
    Aug 2007
    Chico, CA
    2,017
    I'll do that Steve. It broke right at the bottom of the yoke, just like in post #12 above. I'll put up a good pic of the fracture once I get it out. It'll probably be a couple days before I get to it.
    Wolf Lake, AK
    5,781
    It broke at the bottom of the yoke while in a non-typical trim configuration? That may be worth investigating.
    PerryB's Avatar
    Aug 2007
    Chico, CA
    2,017
    It broke in cruise trim. It happened apparently when I attempted to crank it up. I had no indication it broke, no "pop" through the crank, etc. Just the stab didn't move.
    20,371
    Cable probably just started slipping and you couldn't tell the screw wasn't turning.
    Likes mike mcs repair, DENNY liked this post
    Wolf Lake, AK
    5,781
    Personally I'm more focused on the flying wires. My tail is big, the plane is longer and heavier than normal, and it has considerably more the 180hp. The tail shakes and it looks to me like the flying wires take the worst of it. Especially the top wires and that transfers to the fin.
    PerryB's Avatar
    Aug 2007
    Chico, CA
    2,017
    I have a double wrap trim syatem. It doesn't slip. The screw is broken.
    11,733
    Brand?
    PerryB's Avatar
    Aug 2007
    Chico, CA
    2,017
    Almost certain it was Univair, I'll have to look back through the rebuild documents.
    20,371
    I am referring to when it broke and you were trimming, figure the cable slipped and wasn't turning the jackscrew from the binding from the screw being broken.
    PerryB's Avatar
    Aug 2007
    Chico, CA
    2,017
    Ah, sorry I misunderstood. Actually the bottom half of the screw still turns just fine, just freewheeling in place. Dammit anyway....
    2,609
    With all the stab rocking the vert fin action maybe its bending the screw? Full up trim at the wrong time would be Oops.
    11,733
    Also if you had repairs that might have made stabilizer jam against yoke or screw in up position. Also check under rear stab attach fitting for cracks.
    Mauleguy's Avatar
    Aug 2002
    763
    I know of another broken one so I guess it is not that unusual.
    11,733
    Broken Jackscrew
    Quote Originally Posted by Mauleguy View Post
    Strange. Never heard of it, are they all newer parts/manufacture/hardness issue?? Brands??
    Maybe they tried to toughen them up to resist wear but got them brittle???
    Mauleguy's Avatar
    Aug 2002
    763
    The one I know about is out of a certified cub, probably the original one 79 vintage, 150 hp most its life.
    3,623
    Both pics,above, show the screw broken at max travel (extension). It looks to me like a pressure point due to side load. Either the screw/yoke are out of alignment or, like MCS Mike says the cross tube is bound and not free to move on the liner tube. If so, that will cause the yoke to 'pry' against the screw at max travel.
    behindpropellers's Avatar
    Feb 2003
    NE Ohio
    6,867
    My assumption would be the incorrect hardware is installed on the tailbrace wires. If the wrong hardware is installed they will not pivot and this places loads in other places.
    11,733
    I wonder if it was just getting into a real dirty part that doesnít get much use at top
    Hereís an old one removed at rebuild
    Wolf Lake, AK
    5,781
    Because the aft attachment of the stabilizer is static and the front attach moves up and down the travel of the leading edge is an arc. The tube that carries the stab is hung from tabs on the yoke. Does anyone check to verify clearance of that tube as it moves up and down on the screw? If the clearance was too close the tube could push back on the yoke and put a bending force on the screw. The place that potential is greatest would be when the yoke is high on the screw. I never thought much of it until I looked at how my trim actuator pivots. On standard Cubs the tab-tube connection is the only place the lateral movement of the leading edge can be compensated for.
    Stuff to think about when you have a few minutes of down time.
    Likes jrussl liked this post
    Kodiakmack's Avatar
    Sep 2020
    88
    Broken Jackscrew
    While weíre on the subject, Iím curious about some play in my yoke to horizontal connection. The most play is lateral, with very little vertically. The nut is cottered but as you can see the bolt is free to move. Is this intentional to allow movement through the arc of the trim? Iím still very new to this trim style and uncertain whatís supposed to move and whatís not.
    Sent from my iPhone using SuperCub.OrgClick image for larger version.
ID:	53111Click image for larger version.
    HAVE FUN. DON'T DIE.
  36. #36
    11,733
    Broken Jackscrew
    Piper did bother to counterbore that hole so itís still got the taper of the casting making it hard to shim correctly. Univair does. But there should not be slop there. It should be just snug and free to rotate. You can add washers between the parts
  37. #37
    KJC's Avatar
    Jul 2007
    Clear Lake, MN
    238
    This is a brand new Univair aluminum yoke and the old jack screw. If you look close you can see the light washers between the yoke and the carry thru tube.....
    The washers provide the proper shimming to keep it from moving side to side. Also helps fix the machining on the old original castings. You can see Univair finished them nice and flat on both side of the casting where the bolt goes thru. A finger of greesee on the casting faces, the bolts and the washers keeps it all moving correctly. Snug but not tight on the nuts. It has to rotate.
    PA-12 N418BS
  38. #38
    Kodiakmack's Avatar
    Sep 2020
    88
    Quote Originally Posted by KJC View Post
    I really appreciate that and will make it so. I see you have a zerx for the liner tube. I donít have this and doubt this liner tube has seen any love for several years minimum. Recommendations on making sure everything in this area is moving?
  39. #39
    KJC's Avatar
    Jul 2007
    Clear Lake, MN
    238
    Those yokes should be thrown away and replaced at rebuild. The inner part of the yoke which is cut for the acme thread just wears out after years of riding on that steel screw. Grab the front of your horizontals near the jack screw and see how much they move up and down. The Dakota Cub yoke is harder and solves this problem.
    Regarding the liner tubes, the best would be to remove the tail feathers and pull the tubes and make sure they rotate freely. That way you can clean all the old grease and oil out of the liner. Where my grease zerk is, you have an oil hole. A few drops of a light penetrating oil from time to time might help but I doubt it does much. The liner tube rides in two bronze bushings and I doubt the oil ever makes it out that far.
    Like this......
    PA-12 N418BS
    Likes mike mcs repair, flylowslow liked this post
  40. #40
    Kodiakmack's Avatar
    Sep 2020
    88
    Regarding the liner tubes, the best would be to remove the tail feathers and pull the tubes and make sure they rotate freely. That way you can clean all the old grease and oil out of the liner. Where my grease zero is, you have an oil hole. A few drops of a light penetrating oil from time to time might help but I doubt it does much. The liner tube rides in two bronze bushings and I doubt the oil ever makes it out that far.
    I was worried it would be that involved. Rebuild is not in the cards soon as it was done 7 years ago and Iím not looking for a project.
    As for pulling the tail feathers, Iíll have to just hope itíll make it to next annual. Iím 3 months into an annual on a plane I bought with a ďfresh annualĒ that needed to be made legit.
    Thanks for the info though!!
    Thanks toklat$1 thanked for this post
  1. More jackscrew
    By skukum12 in forum Super Cub Sick Bay
    Last Post: 05-11-2008, 10:49 PM
  2. Jackscrew Yoke
    By Skip in forum Experimental Cubs
    Last Post: 05-05-2008, 01:47 AM
  3. JackScrew on the PA-18-150
    By cubman210 in forum Tips and Tricks
    Last Post: 08-30-2005, 09:43 PM
