It won’t be any cheaper next year and it’s really not that hard. If you find someone who knows how to do it, you’ll be done by lunchtime.
PA-12 N418BSmike mcs repair liked this post
It won’t be cheaper but I’ll be more flush. I’m a federally employed fire pilot in the lean part of the year facing a government shutdown. I’ll have a local cub guy come have a look if he has time. Was hoping one could tell function/condition sans tail feathers removal.
HAVE FUN. DON'T DIE.
Judging by all that you've said, you really ought to remove the entire tail. The front where you have been looking does need attention as has been discussed. You also need to look at the pivot tube which connects the two stabilizers at the tail post. Piper just drills an oil hole which rarely gets lubricated with other than moisture. Rust slowly builds in the tube eventually "freezing" the cross connector tube in place. You don't realize this because the angular motion when you move the trim is very small. Because of this design and the fact the stabilizers are rarely removed for any reason, the connector tube becomes rusted into both the stabilizers and the cross tube in the fuselage. Many have welded a short tube or nut over the oil hole in order to install a zerk fitting for regular greasing. Just be certain the zerk doesn't interfere with the elevator control horn. Squirting oil in the hole may make you feel good, but it does a poor job of completely lubricating the entire movable joint. Thus the rust build up.
Do not be surprised to find the stabilizers both rusted to the connector tube and the tube rusted to the fuselage. Sometimes when this has not been addressed for years a hacksaw will be required. A liberal use of Kroil may save some grief.
Run the trim and see if the rear liner tube rotates or bends the stabilizer. Pretty easy to tell in my experience. If you watch the Annual Inspection videos I did here a few months ago there is a whole section on the tail. The play you have between the yoke and the carry-thru tube just needs shims and lube. Up and down play there can be a loose screw in the yoke or the screw could be loose on the fuselage and just need the nut on the bottom tightened a flat or two. The side to side play comes from the stabs being fit to the liner tubes with paint and stuff in between, it wears and they get sloppy side to side. safety wire in the groove fixes that. Also check your elevator bushings for play. Tension of tail brace wires. One worn thing seems to compound wear on everything else in short order.
Thanks Steve. I’ll watch those videos. Your advice as always much appreciated. The play is minimal but I’m all about minimizing even that.
barrow pilot thanked for this post
A quick easy check for the rear liner tube being stuck or not moving freely is to pull the 2 bolts that attach the front liner tube to the yoke assembly, when you are shimming them, then move the yoke assembly as far to the top of the travel as you can. You can now grab the front of the stabilizer and try to move it up and down by hand. Watch for the rear of the stabilizer to move and it should move freely. It could be rusted solid, but also could be gummed up and moving harder than normal. If not moving freely you can attempt to free it up with some kroil and exercising it up and down. If you can't free it up, removing the horizontal stabilizers is highly recommended.
Steve Pierce thanked for this post
Today I removed the bolts connecting the trim yoke to the horizontal, oiled the liner tubes both front and back and made sure they both have free movement. At first they were pretty tight but after working them a bit and re-oiling they freed up pretty well. Will install new bolts and shim as advised and she should be good to go back there for some time : )
Just weld it...
but be careful of making to much extra penetration on inside of tube you will need to grind off. Not fun grinding.
What brand trim pulley is that in picture? Experimental?
Good question. As I mentioned this is our first cub type plane so we are learning as we go. I was told a double pulley -18 trim setup was installed at rebuild.
Dakota cub double groove pulley
You’re the man Mike
