Helmetfire
Caldwell, Texas
Putting some new cylinders on the ole' cub soon, wondering what some of you have in your cubs as far as engine analyzers and such??
I don't have anything more than oil temp/pressure and feel it would be a good idea to have at least a CHT gauge installed to monitor the temps during break-in of the new cyls. Not sure I want to get all that complicated with it...keeping it light is always a factor.
I guess the upper end of the spectrum would be the EI CGR-30P. Lots of $$$ but full of functionality lets me throw out a few other gauges in the process...is it overkill for a cub?? I guess that's subjective, but kind of the point of this post. I do need a new tach also and this would take care of that problem, but a new tach is only a couple hundred bucks.
Lower end of the spectrum would be a westach cht gauge with the little selector for switching between cylinders...seems like you'd eventually get an idea which cylinder to monitor most of the time and easy enough to scan the others once in awhile during cruise or climb.
What's in your cub??
