Results 1 to 7 of 7
Thread: STC'd alternative replacements for an PA18-150 O-320 A2B?
    pfjay52's Avatar
    May 2007
    Port Lincoln, South Australia
    148
    My original first life engine ( 2300 hours, 1977) was recently stripped for an overhaul. Corrosion on the crank and movement of the main bearings in the case tunnel may mean I need a new crank and line boring. It's a wide deck and conical mount. The type certificate for the Cub specifies an A1A or A2B. CubCrafters have an STC covering numerous engine model alternatives but all with a 'Conical' mount. Anyone know of an STC that would allow me to instal a Dynafocal mount and alternative model O-320, and where I might get a PMA'd Dynafocal mount? This might give me more options for a half life engine. I know that an O-360 is an option, but I'll be selling the aircraft once I get my new Javron kit airborne and I'll never recoup my costs. I just need a viable alternative. I'm really looking for something out of an aircraft that has failed the SIDS inspection.
    Thanks in advance for any suggestions.
    Cheers,
    Phil
    19,235
    Wag-Aero sells the mount and the CC STC covers the install.
    Nov 2016
    77
    What are the advantages of Dynafocal over Conical mount, or vise versa?
    Cub Builder's Avatar
    Mar 2011
    North Central AR
    668
    If you buy a Wag Aero Mount, check when it shows up to see if it's built correctly. That's the mount I bought for my Cub Clone. It showed up with a huge amount of down thrust in it... on the order of 8°+. It sat in the box for some time before I looked at it. By time I was ready for it and actually checked the measurements, the only thing to do was cut it apart and build it back up correctly.
    -Cub Builder
    Likes Orchevguy liked this post
    skysigns's Avatar
    Jul 2002
    seattle wa 98053
    325
    cubcrafters STC calls out a P/N for the mount and they don't make one Aero makes one
    i have 2 wag aero mounts 1 came off a cubcrafter EXP cub setting in the hanger
    pfjay52's Avatar
    May 2007
    148
    Thanks everyone for the fast responses. I've got a good handle on it now.
    cheers,
    phil
    Aug 2010
    7
    I’m looking for a dynafocal Mount for the cub Crafters 160hp stc. I’ve got a good O320-D2A that id like to install on my PA-18A-135 but want it to be legal. Seems like the same idea of this thread. Thanks!
  1. Replies: 2
    Last Post: 11-09-2004, 11:25 PM
  2. Alternative Engines
    By Russ Kaye in forum Modifications
    Last Post: 09-16-2003, 04:20 AM
  3. Bungee replacements
    By K.S. in forum Modifications
    Last Post: 05-11-2003, 02:58 PM
