Page 2 of 3 FirstFirst 123 LastLast
Results 41 to 80 of 84
Thread: C180 Question: Monarch Fuel Caps.
  1. #41
    algonquin's Avatar
    Apr 2013
    Seldovia,Ak
    945
    I have the monarch caps on my 73' 185 and had problems with them when I first bought it. It had been sitting 8 yrs. on a grass field untouched.when I first flew it on 15 min trip I lost several gals of fuel and blue stains out of the cap. The O-rings were dried out and monarch robbed me for two rings for like $40.00. And found the vent on the right side was plugged 2-3' in , lots of mud dauber sin the area. Cleared it with a wire. Check vent alignment and never had another problem or water. If you get them to work for you it's a good system. I think Mike is on the right tract, it's not likely the cap. BTW, the flappers in the filler neck on mine are bent back because the fuel nozzles with the ring on the end hang up and are captured by them. You have to put a thin screwdriver in to get the nozzle out.
  2. #42
    180Marty's Avatar
    May 2004
    Paullina, Ia
    2,033
    I did that today, Marty-- held it inverted for about 60 seconds and it didn't leak a drop.
    Thank you. Saved me taking mine off because of my curiosity.
  3. #43
    Dec 2015
    235
    Not sure if this is related, but theyre talkin vent issues www.flyingmag.com/martha-lunken/where-did-gas-go
  4. #44
    10,749
    I would like to "thank", or "Like" some of your guys/gals posts... but that function seems broken right now... I sent SJ an email.... just know we are reading them and trying to show our appreciation...
  5. #45
    texmex's Avatar
    Aug 2008
    Hanging Rock, Australia.
    342
    My caps are like yours Hotrod180. And the seals on the outboard are the same V profile.
    Interestingly the inboards have an O profile ring. Why is it different?
    I'm sorry, but one peice of the equation I should have mentioned, is when filling the first time on the outboard openings, I look across and see fuel pouring out the inboard caps, over the wing and onto the ground almost as quickly. Subsequently I taped up the inboards.
    I was told by the previous owner that each wing had a single tank with two openings. I best scour the IPC and learn about this aeroplane.
    I remember as a kid, the family sitting on the tarmac, as Dad took the 180 up for some ag-pilot type turns to get water out of the tanks. He had already drained a few buckets out. But that water came from a contaminated fuel drum.
    Thanks everyone for your input.
    Are the flush caps the same as the Bonanza's. And if so how do they get away with it?
    Likes CamLoc liked this post
  6. #46
    9,751
    Quote Originally Posted by texmex View Post
    Your airplane has a seaplane kit with long range fuel tanks. The long range tanks have two fillers for convenience of fueling when on floats. They will hold a little bit more when filled at the outboard fillers.
    Try swapping the inboard caps with the outboard caps to determine if the "V" profile seal will also leak or not. Your "O" rings are likely just old and stiff. I don't know about Austrailia, but here near a big city I can get "buna-N "O" rings from a local bearing shop for a reasonable non-airplane price. They are identical to the airplane variety.
  7. #47
    2,934
    ... the seals on the outboard are the same V profile. Interestingly the inboards have an O profile ring. Why is it different? I'm sorry, but one peice of the equation I should have mentioned, is when filling the first time on the outboard openings, I look across and see fuel pouring out the inboard caps, over the wing and onto the ground almost as quickly. ...
    I wonder if someone in the past has switched out the seals on your inboard caps from the doube-v rings to something else?
    Hae you tried replacing them with the correct part from Monarch (not a standard o-ring)?
  8. #48
    Tom3holer's Avatar
    May 2012
    Cape Cod
    461
    I have Monarch aux tanks in my 185 with Monarch caps and have had no issues.
    My caps are more like conventional caps not the screw on ones.
    Not sure when they changed.
Size:  54.2 KBName:  IMG_0139.jpg
  9. #49
    180Marty's Avatar
    May 2004
    Paullina, Ia
    2,033
    Thanks for posting pic's. Didn't know they made them like that before.
  10. #50
    10,727
    Quote Originally Posted by 180Marty View Post
    I believe those are Monarch replacement TANKS, correct, Tom?
  11. #51
    180Marty's Avatar
    May 2004
    Paullina, Ia
    2,033
    I always thought the fiberglass replacements for the main tanks such as my slant ones used the same plate and cap as I'm using with my bladders. Thinking that cap goes on the 15 gallon tank that can be installed outboard of the originals. Wish I stlll had my brochure from Bill Barton.
  12. #52
    180Marty's Avatar
    May 2004
    Paullina, Ia
    2,033
    Found this on Hartwig's website. Must be the original install instructions. Notice plate fits bladder or plastic tank.
  13. #53
    Tom3holer's Avatar
    May 2012
    Cape Cod
    461
    Those are on the outboard aux tanks.
  14. #54
    algonquin's Avatar
    Apr 2013
    Seldovia,Ak
    945
    I have flint internal tanks and the filler neck is under a sheet metal door right next to the wing tip. If the cover was removed the cap in the pic would fit.
  15. #55
    9,751
    Except that the diameter might be a bit tight in the well and the Flints do not have a vented cap.
  16. #56
    18180's Avatar
    Feb 2008
    Pennsylvania
    104
    The conventional style likely works better because there is no ratchet mechanism. Unless I very deliberately position the cap as I install it, it will ratchet before the o ring is properly seated. If not seated it leaks....alot. Replacing the $55...yes $55 o-rings often and keeping a bit of o-ring lube on them helps.
  17. #57
    mountainmatt's Avatar
    Dec 2010
    CO
    190
    you changing back to the flush caps??(that have the AD and put WATER in your tanks?)
    or the raised ones??
    or adaptors, like atlee sells? http://www.fadodge.com/category/cess...ystems-cessna/
    Slight thread drift...
    Any first hand experience with guys running these FA Dodge adapters? Any preference on either the Shaw or Wisco set?
    I have a friend that still has the stock "killer caps" and these look like a great solution.
    Thanks!
  18. #58
    180Marty's Avatar
    May 2004
    Paullina, Ia
    2,033
    Interesting, I have never had the cap cross threaded like that to where it ratchets prematurely. My caps are at least 26 years old and I've never replaced the rubber seal or put any kind of lubricant on.
  19. #59
    algonquin's Avatar
    Apr 2013
    Seldovia,Ak
    945
    Skywagons 8a right, sorry was referring to the two tabs not the screw in type on the reg monarch. Wouldn't go down in the recess.
  20. #60
    Oct 2010
    Lakeland, Fl
    122
    Same here, just looked up my paperwork, bought the tanks and caps in 1988 and seals still look new.
  21. #61
    180Marty's Avatar
    May 2004
    Paullina, Ia
    2,033
    Wingwrench, I take it you have the Monarch tanks too??? If so, are they plastic or fiberglass? I keep thinking how nice it would be to have tanks made out of the same material that my red 5 gallon jugs are. I've carried pure biodiesel, E85 ethanol, pure gas, and diesel in them for years and they still look like there is lots of life left.
  22. #62
    Oct 2010
    Lakeland, Fl
    122
    Monarch, and they are fiberglass. I'm not convinced plastic is the way to go. When I bought these Bill claimed these were chemical and acid proof.
  23. #63
    9,751
    Marty,
    It is my understanding that after the owner of the company died, the tank production was terminated. The caps alone are being supplied by: http://www.hartwigfuelcell.com/monarchcaps.php
  24. #64
    Oct 2010
    Lakeland, Fl
    122
    Marty,
    That was my understanding as well, hard to sell rubber bladders when you also sell a fiberglass replacement would be my guess.
  25. #65
    texmex's Avatar
    Aug 2008
    342
    63 posts about the shitty fuel caps on my aeroplane.
    Mike I hate to say this, because you and Steve are like Hare Krishna leaders to me. Your've both taught me so much.
    But after a night on the sauce with the previous owner (who agrees wholeheartedly) I'm ditching those caps and sending them to PIPER J5.5
    In my defence I live, after antarctica, on the dryest continent on earth. The aeroplane is hangared. And I've had 17,000 hours of analysing the risk of flying.
    They're gone.
    But does anyone have any idea of the o-ring part numbers of the seals on the original caps? Sorry there is a whole Cessna part number for the cap that I don't have handy.
    And the IPC had Stainless Steel screws AN507-428R7 for the inner fuel cap screws. Is there a cad plated version of AN507-428R7?
    Cheers,
    Denis.
  26. #66
    180Marty's Avatar
    May 2004
    Paullina, Ia
    2,033
    Thanks Wingwrench and Pete. Wingwrench, you don't happen to remember how the nipples for the outlet and vent are designed do you? Is it a metal tube molded into the fiberglass or like a tubeless truck rim where the threaded valve stem is squeezing the rim with two rubber washers(inner and outer) with a nut.
  27. #67
    9,751
    Quote Originally Posted by Wingwrench View Post
    I haven't made this mod but as I understand the process, it involved removing the wing and the root rib in order to slide in the fiberglass tank. As a mechanic I would rather change a rubber bladder at ten hours per bladder.
  28. #68
    180Marty's Avatar
    May 2004
    Paullina, Ia
    2,033
    As I remember, the big selling point was no more wrinkles that hold water. I don't have any wrinkles but some people must have.
  29. #69
    9,751
    True, With the set which I recently installed it was rather easy to ensure that the wrinkle situation did not happen. The nipple at the quick drain was a bit long promoting wrinkles. Once it was trimmed, no problem.
  30. #70
    18180's Avatar
    Feb 2008
    Pennsylvania
    104
    The Monarch plastic tanks are still available and STC'd for all but the early slant tanks. Inquired about this recently.
  31. #71
    Oct 2010
    Lakeland, Fl
    122
    It's an aluminum bung glassed into the tank.
  32. #72
    Oct 2010
    Lakeland, Fl
    122
    I had my airplane apart so it was fairly simple install.
  33. #73
    180Marty's Avatar
    May 2004
    Paullina, Ia
    2,033
    Hartwig????? Was perusing their website and can't really find fiberglass tanks for sale although one topic was "Caps and Tanks". Thanks
  34. #74
    2,934
    Quote Originally Posted by 18180 View Post
    The Monarch plastic tanks are still available and STC'd for all but the early slant tanks. ....
    It's my understanding that the Monarch replacements for early "slant tanks"were discontinued because of installation issues due to inconsistent dimensions on the early Cessna wings.
  35. #75
    May 2016
    Olympia, WA
    17
    They're gone.
    Cheers,
    Denis.
    Denis - the AN507-428R7 was a cad-plated steel screw. New number is MS24693S293. The AN507C428R7 is the stainless version - aka MS24693C293
  36. #76
    2,934
    There's a recent discussion thread on the BCP site about leaky Monarch caps.
    Looks like the mysterious problem has been pinpointed.
    Here's a clip:
    "he suggested I try "one more thing" and showed me an example of a cap that had the cut-out for the chain attachment punched to high in the throat of the assembly therefore not allowing the cap to seat flush and have gasket contact. That made sense to me but seemed like a stretch..... Well, just got home and sure as **** when I pulled the cap off and looked in the throat of the assembly I could clearly see where the cap had been hitting the cut-out for the chain attachment. I removed the chain and in about 30 seconds took a punch and flattened out the cut-out to be flush with the throat and sure as ****- the cap now fits tight and flush. I can now feel the gasket contacting the top."
    For the full discussion:
    https://backcountrypilot.org/forum/t...=unread#unread
    And if you want a set:
    http://www.supercub.org/forum/showth...p-kit-for-C180
    Thanks 18180, Ken Kennedy thanked for this post
    Likes mike mcs repair, 18180, Ken Kennedy liked this post
  37. #77
    Dave Calkins's Avatar
    Jul 2002
    Anchorage, Alaska
    5,399
    Glad that was found
    I never ever ever ever had problems with them and recommend them to all!
    Likes 180Marty, mike mcs repair liked this post
  38. #78
    18180's Avatar
    Feb 2008
    Pennsylvania
    104
    Problem Solved.....Chain attach tab improperly located in filler neck. Cap thread hits tab before fully seated. Remove tab, problem solved. A previous post led me to this and sure enough. Hartwigs' continued insistence that this was an airplane problem is the most frustrating part. When I suggested the tabs might be an issue (after reading post about this find), they acknowledged that some times the tabs don't get punched just right. Their advice....grind the cap! Don't do this as it will not solve the problem. It is the treads that hit the tab.
ID:	32116Click image for larger version.
ID:	32117Click image for larger version.
ID:	32118Click image for larger version.
    Thanks mike mcs repair, 180Marty, Ken Kennedy thanked for this post
  39. #79
    2,934
  40. #80
    texmex's Avatar
    Aug 2008
    342
    Piper J5.5 - I sent you a PM there a few weeks ago but no response. If you still want those caps there yours. My friend travels to LA regularly and will post them from there as it's a long way from Australia.
    New Years Resolution - To read Mike's posts more thoroughly. It turns out that there are also vent issues. The other day with full fuel, looking across to the LHS the vent would occasionally blow off an atomized puff of fuel. Even after an hours of flight. The vent on this side sits right behind the wing strut and not out in the free stream air.
    I assume it needs to be in the free stream air more. But then again, Googling Cessna fuel vent issues I see McFarlane has vent modifications so maybe this is a common issue.
    Any stories of similar vent issues?
  1. Question on Monarch aux tanks in 185
    By Tom3holer in forum Everything Else (formerly:My Other Plane Is A....)
    Last Post: 01-19-2016, 11:26 PM
  2. Fuel caps
    By Zk Boy in forum Cafe Supercub
    Last Post: 10-03-2011, 06:42 PM
  3. Gooseneck fuel caps.
    By marker60 in forum Member to Member
    Last Post: 11-20-2006, 08:02 AM
  4. Fuel Caps on 150 HP PA-12
    By MikeJ in forum Modifications
    Last Post: 01-29-2004, 12:19 AM
