hunt/trapak88
I ran a 8436 with 10:1's in a 320. Did good, until i had engine probs
This discussion is like herding cats. I'll leave y'all to it. Have a nice day.
Time will tell if that is like a sudden stop but my 180 Cessna with MT has been shut down many times and still seems to run okay. When I shut my 150 hp PA12 down the Sensenich prop usually backs up against compression so that seems kind of abrupt too.The other dis-like was that when shutting down; the engine "slammed" to a halt. With the Mac and its flywheel effect shutdown was more normal.
My Whirlwind hollow carbon blades on an IO-360 stops quickly also. But I would not call it "slammed" to a halt. Quick but smooth, yes. I attribute this to the electronic ignition. Mixture is pulled at idle with no O-360 shake. The lightweight blades and lack of flywheel effect is apparent.The other dis-like was that when shutting down; the engine "slammed" to a halt. With the Mac and its flywheel effect shutdown was more normal.
For what it is worth:
I was visiting with a fellow last summer at Lake Hood who was doing some flight testing with his 180+ HP cub. He does various testing for STC purposes so his cub was in a temporary "experimental" category for these tests. He was currently on floats so I was quizzing him about various changes such as props. He said that he had run a Catto prop on this cub for awhile but wound up removing it. It was not that it didn't perform good, but that he got tired of having the engine "kick back" during startup which it did not do with the big metal MaCulley prop. He said that the flywheel effect of the big Mac prevented this. He had to replace two starters do to extensive damage. The other dis-like was that when shutting down; the engine "slammed" to a halt. With the Mac and its flywheel effect shutdown was more normal.
In the case of kickback, I have to wonder how many aircraft are being inadvertently started on both mags (assuming only ONE impulse). I've seen at least a couple of Bendix type switches that should've had the right mag shunt, that didn't. I've also seen a LOT of people hop in a plane with individual switches and flip them both on prior to starting.
??????Since they start with a key, they are both going to fire. As for the Carbon cubs, they have electronic ignition and both plugs are hot.
I have had to change a couple of starters on Carbon Cubs because the engine kicked back at starting. The lighter of the skytech starters breaks pretty easy. Never had more than a shear pin break with metal props.
Den,As for the Carbon cubs, they have electronic ignition and both plugs are hot.
Eddie that's one of those if we tell ya things... you just have to glean such knowledge by osmosis!Electronic ignition doesn't have static timing.
I started my Cub on both for a year before I knew not to. It's not in the POH or the Lycoming book.
This whole Cub journey has had a lot of osmosis.Eddie that's one of those if we tell ya things... you just have to glean such knowledge by osmosis!
all the Cessnas that I work on have impulse couplings in both bags. Since they start with a key, they are both going to fire. ....
Den,
Is there a possibility that the electronic ignition is not retarding the spark during the starting phase? Or that the timing is set incorrectly and that the retard position is still too far advanced? Electronic ignitions should not kick back during starting.
My only electronic ignition experience in airplanes is with the P-mag. The P-mags are timed to top dead center. After that they automatically vary the timing as appropriate for the condition. Perhaps the system in the planes which you are working on was not timed correctly upon initial installation? One of the big advantages of electronic ignitions is to provide a more automotive like start without kickback.I don't know how the electronic retards the spark for starting. There is no way to control it as far as I can tell. Just a hall-effect sensor.
