Assume that you have an engine and prop mounted on a test stand where you could measure static thrust. Also assume the prop is fixed pitch and the engine is running at full throttle and turning 2500 RPM under no wind condition.
Assume the static thrust under these conditions is 500#.
How would the static thrust change with a headwind or a tailwind. Just say 15 KTS for example.
Obviously, if there was a 15 KT headwind blowing into the prop, the RPM would increase slightly and the engine would make more power so the thrust might go up. And the reverse may be true if there is a tailwind?
What if the RPM were kept constant at 2500? The power would have to be reduced to keep it there with a 15KT wind into the prop.
What if it were a constant speed prop and the RPM was governed at 2500 RPM?
