Several years ago I did the same thing. It had a "light" detent and I figured it would be okay. On the first takeoff after reinstalling it, I got to around 300' AGL before the engine quit. Fortunately I had enough flat ground in front of me to land without incident. I figured I had accidentally bumped it to the off position with my knee when doing the flap check on run up. So much for soft detents.After disassembling the Imperial fuel selector and lubing upon reassembly found that could not feel the detente?
I also need to overhaul my fuel valve and I would rather swap out the metal plug and position washer for this style Super Cub valve with the plastic plug, looks like a much better designed position washer, univair.com/content/PIP_SL0944.pdf
I cant find a source for this piper valve, has anyone installed one recently?
It may not be fancy, but I dont think outdated is fair, a very similar valve is listed on ACS today. This is the Piper valve from the sl944, it is an exact copy it looks like of a weatherhead valve at ACS that can be used on experimental aircraft only.
I don't agree with the "used on experimental aircraft only" comment. It is a standard part which Piper very likely purchased directly from Weatherhead. At the time that these airplanes were built the term FAA-PMA did not exist. I would have no qualms about using this valve, if as you say it is the same (very similar) as the original. I'm not suggesting that you not use a more modern valve, only that this particular valve doesn't need to be labeled "experimental". This is of course a judgement call.It may not be fancy, but I don't think outdated is fair, a very similar valve is listed on ACS today. This is the Piper valve from the sl944, it is an exact copy it looks like of a weatherhead valve at ACS that can be used on experimental aircraft only.
Urea thanks for the heads-up. You would not possibly have a photo of the one from Univair ? I would like to see weather the Univair one will fit the same as the old imperial? My cub is scratch built so a little different than certified one. I have 1/2" fuel lines to feed the 205 hp lyc.
It could well be that the defective valves I got from the auto parts store were not 'real' Weatherhead valves, but poor quality copies.The Weatherhead valves are made by Anderson Brass in South Carolina, they are good quality valves, there are cheap China made copies out there that are junk.
The John Denver crash comes to mind.
The one on the top appears to be a two position valve. Not sure I'd put that in a supercub.
Or at least change the brass washer and position washer with correct one
That is a sad story about John Denver, sounds like that accident could have easily been avoided. His medical was revoked because of a drug problem. He had just purchased the aircraft, the person that built it put the fuel selector in a spot that wasn't easily accessible while in the seat with the seat belt on. He took of low on fuel and ran out, tried to reach the fuel selector and crashed.
That top valve is the Piper valve that was installed from factory on PA-18 from 1979 to 1981
Look up Piper service letter SL944
Never seen one.
