Page 1 of 2 12 LastLast
Results 1 to 40 of 50
Thread: Favorite Cessna 180/185 Jack Pad
    19,249
    Curious what everyones favorite 180/185 jack pad is. I have some home made ones I have built over the years but a friend wants one for his 185 and trying to figure out which one is best. Was going to use a floor jack instead of a bottle jack. Wanting to swap between 8.50 whels and tire and 29" Bushwheels. I see Atlee has two.
    http://www.fadodge.com/cessna-leaf-gear-jack-pad-2/
    http://www.fadodge.com/cessna-jack-pad/
    and Bogert.
    http://bogertaviation.com/collection...table-jack-pad
    5,129
    I can't find the old thread where I had pics of my tripod stand and hydraulic jack to lift my 180 under the gear boxes. Dave Calkins had a similar tripod that folded closed. Very cool. WAY better than a gear leg fixture.
    Dave Calkins's Avatar
    Jul 2002
    Anchorage, Alaska
    5,401
    Photos of 24" bottle jack with folding legs coming shortly.
    Jackpads scare me on taildragger Cessnas since the gear flexes and moves over as you lift a side
    10,763
    my main one i used was a 2x8 with a piece of plywood on it, then a metal part to keep jack in place and spread load screwed to it, used under gearbox
    the clamp on leg one's I've made i like to add a pin across top...
    and i also wrap chain around tail wheel so it doesn't decide to roll away or swivel
    I've also seen one that sets right against fuselage under gear leg
    Nov 2003
    Thun Field, Washington
    786
    Av-Jack by Ace-Air
    Meanwhile,...
    5,144
    I have several, an adjustable gear leg pad (better than nothing), a welded custom gear leg pad that works pretty well for single side jacking and a whole belly Woden cradle that goes under the gear leg reinforcement boxes that is amayzing with a couple of jacks plus a tail cradle that goes under the stinger bulkhead that is really handy.
    May 2012
    52
    I use amsteel synthetic winch cable made into a continuous loop. Form a double prussic(sp?) knot around the gear leg and use a engine hoist or overhead winch to lift the gear leg. It looks and sounds crazy, but 3/16" amsteel has a 4900 pound breaking strength. Fast, easy and nothing in your way when changing tires. You can search for "cessna gear leg whoopi sling" and find a pic on BCP of how it looks.
    9,788
    Hoist on the seaplane lifting rings (if you have them).
    19,249
    Quote Originally Posted by Carey Gray View Post
    Av-Jack by Ace-Air
    Very nice.
    Likes L18C-95 liked this post
    19,249
    Quote Originally Posted by BTV View Post
    Sorry,can't find it.
    5,129
    Jacking from a gear leg gets scary when you switch the first 800 or 850 to a 29" Bushwheel. Changing the second one is really scary. Jacking under a gear box is much more stable. Big tires, skis, outdoors in the breeze, on ice or gravel... no problem. Another good option is a vee block that wedges between gear box and gear leg but I have hydraulic lines there so I jack from the flat underside of the gear box. My top pad allows some roll to compensate for the angle change as the plane lifts so no side loading on the jack. It works great. If I built another one I'd make the tripod legs fold in for stowing like Dave C's does. Maybe he'll post a picture.
ID:	29450   Click image for larger version.
    Sep 2006
    corvallis,or
    416
    very nice in more ways than one.
    I hope it will work on pa-18 3" extended with 29" bushwheels.
    i hope she answers the phone when I call
    Meanwhile,...
    5,144
    Very nice.
    A little spendy $495 but it does look stable.
    Aug 2003
    1,324
    Steve, Samson Rope sells this (or similar) under the trade name of Amsteel. There are lots of variations on Aramid cordage. Here's a link:
    http://www.samsonrope.com/Pages/Prod...?ProductID=872
    This is working its way into several applications which traditionally used steel cable. It's not a universal substitute however. Another interesting application is for winch launching sailplanes, and it's pretty much taken over in Europe, and at the (few) U.S. glider operations who winch.
    Thanks. cubscout
    Jul 2010
    Elizabeth, WV
    561
    I have wrapped the gear leg with a 1 inch by 24 inch nylon lifting strap and hooked that to my engine hoist. Once the slack goes out it stays put on a tapered gear leg. It is also handy to put through the lifting handle on a taildragger and run it back through the eye of one end. Absolutely no strain to my back when the hoist picks up the tail. jrh
    Thanks pfm thanked for this post
    19,249
    Brandt sent me the link.
    https://www.backcountrypilot.org/com...17878?start=60
Name:	Jacking 180 2.jpg
Name:	Jacking 180 3.jpg
    Jul 2002
    Anchorage, Alaska
    5,401
    Quote Originally Posted by N86250 View Post
    I try to not put too much weight on tail handles of a Cub. I am not saying you are overdoing it
    Thanks 18180 thanked for this post
    Jul 2002
    Anchorage, Alaska
    5,401
    More pics of that plane??
    looks like a beauty!!
    White City, Oregon
    902
    Very nice.
    Fist time I have seen this.... And that crazy mechanic in the video is my old buddy Brian Lansburgh out of Sisters Oregon...
    Brian
    Jul 2002
    Anchorage, Alaska
    5,401
    24" bottle jack. Welded aluminum folding base. Block of wood has a piece of conveyor belt "padding" that the airplane belly rivets kindof grip. Also. A short stub of 4130 tube is set into the block to "key" into the hole in the belly so it will never slip. I jack it nearly all the way up sometimes and attach the ski bungees with no need to stretch them. Super stable!!
ID:	29462   Click image for larger version.
    10,763
    Av-Jack by Ace-Air
    thats pretty slick looking.... would be a fun project to make one like that
    Jul 2010
    Elizabeth, WV
    561
    Would it make a difference if it broke off in your hand or hanging from a strap? The tail weighs the same both ways. jrh
    Jul 2002
    Anchorage, Alaska
    5,401
    You are so right jrh. Sorry. I said the first thing that came to mind. Then retyped it. Shoulda erased it!
    Jul 2010
    Elizabeth, WV
    561
    No, that's OK. You made me think and that's supposed to be good. jrh
    Ken Kennedy's Avatar
    Dec 2008
    Lubbock , Tx
    56
    +1 for the engine hoist and strap method. We just use a 1.5" wide strap wrapped around the gear leg.
    Thanks JohnnyR thanked for this post
    May 2012
    52
    The av-jack looks good. Anyone know if it has enough travel to switch from 8.50's to 29's without setting the axle down on a block and adjusting the jack?
    Nov 2003
    786
    As I recall, Vern's first version of the Av-Jack wouldn't. He then did a little redesign work so it will do 31s as well as small tires.
    If you want to talk to Vern directly, PM me and I'll send his cell number.
    Meanwhile,...
    5,144
    I'd like to know as well, see if you can get him to post here...
    180Marty's Avatar
    May 2004
    Paullina, Ia
    2,033
    Probably not a big deal, but I try not to have a lot of fuel in the tanks. I have terrain just outside the hangar that I can put the fuel selector on both and run fuel to the opposite side I want lift and it might help lighten the lift a little.
    RaisedByWolves's Avatar
    Feb 2005
    3,936
    Couldn't get in touch with anyone for the av jack so I built some. Will lift a 600-6 off a 180 and put a 31 on. Works great on 206's too. I've got four made. Powder coated too.
    Meanwhile,...
    5,144
    Did you make a knock-off of their model to?
    Nov 2003
    786
    I think Vern has a patent on the design. I'm pretty sure it's not even acceptable to copy them for your own use.
    I'm not a patent attorney, but I have talked to patent attorneys about competitors copying equipment that I designed.
    Might want to be careful.
    SpainCub's Avatar
    Feb 2009
    612
    You think he might? Nice job on the "New Design"
    I'm not a paten lawyer, but having paid one before... I can see so many reasons that would make it very difficult to receive a paten certificate... What's so special about a lever that is actuated but an undercarriage on wheels, be it manual, hydraulic, or electric? And even if you got it, you still have to go to trial and see what the court thinks... To me (and I mean no offence to any lawyers out there... you serve us all selfishly with your deeds ) a lawyer is like a hammer sales man, all problems look like nails...
    Happy holidays!!!
    1,898
    A patent keeps you from selling the product not from building for personal use.
    Nov 2003
    786
    Our patent attorney told me that not only can't you sell it, you can't build it for your own use.
    He enlightened me after I said, "Well, it keeps me from building it and selling it, but it doesn't keep me from building one for myself."
    The same attorney told me that really nobody had invented anything in a really long time, people just rearrange things.
    I know a guy who has a patent for putting casters under a surface grinder. He didn't invent grinders, he didn't invent casters and he certainly wasn't the first to put casters under a surface grinder, but he has a patent.
    The only thing special about Vern's gizmo is that people are still having airplanes fall off other gizmos.
    It's just an actuated lever on an undercarriage that keeps a Cessna from falling over, that apparently wasn't thought of before.
    I bought one and gave it to a buddy with a Cessna because some of the other stuff is scary.
    Jul 2002
    Anchorage, Alaska
    5,401
    Does the Abjack work on uneven surfaces or soft stuff?
    Ddoes it scrape the paint on the bottom of the gear leg?
    I didnt watch the video, but I think I see these two issues.
    I dont wanna get sued for using the name of the contrivance, so I spelled it wrong!
    19,249
    I got their phone number off the Av-Jack website and called and ordered one today. Just got my shipping confirmation. Talked to Vern about his Super Cub adapter as well. Looks like a way better way of lifting Cessna's and Cubs than the way I have been doing it. My Bogert jack for the Cub is scary and not everyone has lifting rings which is my preferred method of jacking. Had an employee drop a C180 once with the seat on a table under the wing. Not a simple fix. I think the Av-Jack will me a nice addition to my tool and equipment collection.
    19,249
    Smooth surface isn't a problem for me. I will have to see how it will work but I have some pretty good rubber I use under my other jack pads to address the paint scratching.
    5,129
    You were considering one of those jack pads for a smooth floor hangar? Nobody uses those things inside hangars, do they? Whatcha gonna use when some Skywagon driver needs you to fix a flat in the real world?
    10,763
    i didn't see any mention of a patent on website....
  1. Jack Pelton retires from cessna.
    By ndill in forum In The News
    Last Post: 05-06-2011, 09:09 AM
  2. Jack point?
    By Bassackwards in forum Cafe Supercub
    Last Post: 05-16-2008, 09:59 AM
  3. Jack screw
    By pa19guy in forum Super Cub Sick Bay
    Last Post: 05-16-2005, 09:57 PM
